Question about Car Audio & Video
I am installin a Clarion DB185MP auto source unit. It's on but no sound, when I turn volume control it says "amp ground" on screen- a code not in manual. I have reset unit but get "amp ground code". Unit was hooked up with and without external amp, same message. Thanks
  • 5778016 Feb 24, 2009
    Hi I have Clarion DB185Mp car stereo I get "amp ground" error code when volume control is turned, no sound at all but lights, clock etc work fine. Unit is wired with factory harness and no external amp connected. Does this code mean unit is damaged? Unit is grounded to chassis @ factory harness. Thanks
  • 495 Answers
This might help you
www.5starcaraudio.co.nz/pics/manuals/DB185MP_ENG.pdf
Posted on Feb 24, 2009
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Check the speaker wires of the Clarion unit with an continuity tester/ohmmeter or a DVM/VOM. None of the speaker wires should read 0 ohms to ground with or without speakers connected.
Pls post back results/updates. Good luck and thank you for using FixYa.
  • Louie  Role
    Louie Role Feb 24, 2009
    Pls confirm that the following wires are not grounded, exposed:
    • blue/white stripe = amp turn on lead
    • brown = phone mute lead
    • blue = power antenna lead
    Additionally, verify that the wires from the Clarion connects as below indicated in the factory harness:
    • Yellow is constant 12V
    • Red is ACC
    • Black is ground
    • Purple rear right +
    • Purple black rear right -
    • Green rear left +
    • Green black rear right -
    • White front left +
    • White black front left -
    • Gray front right +
    • Gray black front right -
    • and that no wire would read 0 ohms to GND other than the black.
    You may also want to add an extra ground strap from the body of the Clarion DB185MP to the firewall or metal brackets under the dash.
    Brigadier General:
  • 5,158 Answers
Run a ground wire from the ground on the back of the unit to the screw on the power plugin.... that should take care of the ground issue
  • Roberta Smith
    Roberta Smith Feb 24, 2009
    misread that... you need to ground the amp... same method but on the metal of the body of the car
  • 13,433 Answers
Hi
It sounds like its wired inproperly, get a amp and note that everything is set up and wired properly, I assume the speakers are working fine could you test them with another unit?
When i turn the volume it says amp ground, I pulled the deck out and made sure the ground had a good connection, but it still says it. What else could it be?
Most of the time that means that one of the speakers is grounding out and it shuts off the amp to protect itself from getting fried. Most likely one of your speakers is blown out that is causing this. If you're not familiar with using a multimeter you can disconnect them one by one until it stops doing it.
Mar 09, 2011 | Clarion DB185MP Car CD/ MP3 Player
Wiring diagram
http://www.clarion.com/us/en/MungoBlobs/837/700/DB165-inst,1.pdf
This is the closest that I could find you may want to take a look at the website yourself.
Jan 13, 2011 | Clarion DB185MP Car CD/ MP3 Player
I have taken the head unit out of my old boat, would like a wiring daiagram, to installin my new boat!
Red = switched power
black = ground (earth)
yellow = bat power (on)
blue white striped antenna turn on
solid blue remote turn on for amp
(speakers)
(all will have one with black/white stripe if all sets have black = ground if all sets white = hot/+
green = rear
( cant remember left/right)
purple = rear
white = left front
Red = Right front
all of this should be on the bottom of the stereo
Dec 14, 2010 | Clarion M255 AM/FM Marine CD Player
I turn up the volume and it says amp ground the car doesnot have an amp?
Pull the deck out and make sure that your ground wire is attached to a solid ground and that your wiring is intact and sturdy. The deck itself has its own internal amplifier which powers the vehicles speakers.
Dec 11, 2010 | Clarion DB185MP Car CD/ MP3 Player
Connect color-coded wires properly;especially the
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
pls rate people arnt rating hope this helps
Apr 22, 2010 | Clarion DB245 CD Player
Clarion DXZ385 problem with error message amp grnd
once the ground is no longer sensed, the error will no longer come up.
Dec 29, 2008 | Clarion DXZ385USB Car CD/ MP3 Player
Need a wiring diagram for a clarion db185mp
Clarion uses the industry standard wiring colors. Not every unit will have all of the listed wires
SPEAKERS:
White = Left Front +
White/Black = Left Front –
Gray = Right Front +
Gray/Black = Right Front –
Green = Left Rear +
Green/Black = Left Rear-
Violet = Right Rear +
Violet/Black = Right Rear –
POWER/ACCESSORY:
Yellow 14ga = Battery Main/Memory
Yellow 18ga = Battery CeNET Power/Memory
Red = Accessory (ignition on)
Black = Ground
Blue = Antenna Turn On +
Blue/White = Remote Turn On (amps) +
Orange/White = Dimmer
Brown = Phone Mute
Orange or Mint Green= Parking Brake Video Lockout
White/Red = CCD (camera) input instant on +
RCA Cables:
Gray = Front Output
Black = Rear Output
Purple = Non-Fade or Subwoofer Output
Dec 27, 2008 | Clarion DB185MP Car CD/ MP3 Player
I need to install a max385vd in a 2002 pord f-350, do i need an install kit?
Regardless of whether this is an amp or a head unit, an install kit is either very helpful or necessary. If it's an amp, you'll need it for sure - you can't power an amp with 18 gauge factory power wiring like a head unit can use. You need to get at least 10 gauge power and ground wire, 18 gauge remote turn-on wire, and RCA patch cables to conduct the sound. If you have a factory head unit, you'll also need a line-level adapter to give you a source for the RCA patch cables.
If this is a head unit, you'll need the adapter harness to plug your existing stereo harnesses into the new head unit. It makes it simple - the wires on the new head unit are color-coded for what they do, and the adapter harness is identically coded. Match the colors, then plug it in. You may also need an antenna wire adapter (some cars require this).
Aug 10, 2008 | Clarion Car Audio & Video
Amp guard
Other sites I've read about this problem suggest that first you try checking the wiring to the speakers for a fault to ground OR you have speakers with too low impedance. If those check out ok, the unit needs to go back for service.
Apr 14, 2008 | Clarion DXZ645MP CD Player
Car Audio & Video Logo
183 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
