Question about Canon ZR85 Mini DV Digital Camcorder
Can't format 4G card for use in my Canon ZR85
I bought a 4G card for my Canon ZR85, in order to record longer video, but it will not format the card and keeps saying card error.
  • Anonymous Feb 28, 2009
    Same problem, only I have an 8G card
  • tommy77 Mar 02, 2009
    I have the same problem I just bought the pny optima SD HC 8GB card and it will not format. "Card Error". It's not the lock. Help PLEASE.
The ZR85 does not support any memory card larger than 512 mb.
Sorry : (
Posted on Mar 03, 2009
  • 423 Answers
What kind of card do you have? Your camera only takes SD cards or MMC cards. The amount of GB doesn't matter. I prefer the SD card.
Make sure you have the switch in the unlocked postion. If the card is locked, you won't be able to do anything with it. And, no offense, but everybody makes mistakes...make sure you have it installed correctly!
Let me know if that fixes you're problem. It should work. If I you need anything further, let me know in a comment. If my solution works for you, don't forget to rate it a fixya, and thanks for coming to FixYa.
Rob
Posted on Feb 24, 2009
I can not get a new the SD card to format
What size card? Are you sure you have an SD card, 2GB or smaller, and not a higher-capacity SDHC card?
Jan 03, 2013 | Canon ZR85 Mini DV Digital Camcorder
My canon ZR85 mini DV camcorder used to be able to take photos, now it doesn't when i try taking one. Any help???
Just a guess, but is there a card inserted to record the images? Also, does the card have space available on it? Maybe it's full and just not telling you that.
Also, try the Canon support website to see if others are having the same problem and have found a solution.
Dec 24, 2010 | Canon ZR85 Mini DV Digital Camcorder
My canon zr85 mini dv camcorder the screen is black when on record even if the side screen is close the eye unit is also black.
It is known problem of ccd imager chip failure in Canon ZR85 camera and ccd imager chip will be replaced to fix the issue.
Local camera repair shop will help you to replace ccd imager chip because solder work is involve.
Thanks.
Jul 21, 2010 | Canon ZR85 Mini DV Digital Camcorder
My canon ZR85 Digital Video Camcorder will not record and you can not view anything through the viewfinder or on the screen. Both are black. I can play tapes but can not record anything.
I had the same problem and canon fixed it no charge,there was a recall on this check out the link and follow the instructions
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=227&modelid=9739&keycode=2112&id=48266
Feb 06, 2010 | Canon ZR85 Mini DV Digital Camcorder
I can playback the tapes but now I can't see anything on the screen when I want to record. The screen is just black. Is something not set correctly?
If your camcorder is Canon ZR85 then it has bad ccd imager problem and that part will be replaced to see live view in camera mode for recording.
Canon offers Free of Cost repair for ZR85 model.
Click Canon CCD Imager Support for details.
Apr 07, 2009 | Canon ZR85 Mini DV Digital Camcorder
My Canon ZR85 has no light in the view finder for recording images. It will play back tapes, but no images when you want to record. Battery is fully charged.
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Jan 12, 2009 | Canon ZR85 Mini DV Digital Camcorder
Connecting zr85 to vcr to record vhs tape to dv or sd card
I also have a Canon ZR-- left of the lens and the built-in microphones, there is a small panel that opens to reveal several ports. The middle yellow one is the AV In/Out. You can plug in the cable that came with your camera. One end looks like a microphone plug, the other has 3 RCA type plugs- red, white and yellow. These get plugged into your VCR's OUT plugs on the back of the VCR. Place a tape in the camcorder, open the LCD panel and push the REC PAUSE button. On the VCR, press the Play button. When the tape reaches the point you want to begin recording, press the camcorder's Play/Pause button. When you want to stop recording, press the Stop button on the camcorder.
This is also detailed on page 82 of your manual, manuals are available online at Canon.com. Your specific manual is at: http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=174&modelid=9739#DownloadDetailAct
Hope this helps.
Nov 20, 2007 | Canon ZR85 Mini DV Digital Camcorder
No picture when recording
call canon tech support. my zr85 had the same problem and they fixed it free of charge. there is a recall on all cameras that have this problem. good luck.
May 07, 2007 | Canon ZR85 Mini DV Digital Camcorder
Not able to record the image
I had a similar thing happen to me...the video would not come one when I turned it on, but the audio would work, and it would play back tape fine. I happened upon the following solution (though I don't know how long it will last). I charged the camera, and then noticed it worked fine when the charger was plugged in. As soon as I unplugged it, the video would go black. So...I plugged it in, turned it to record, and unplugged it, and it worked! Almost like something got reset. I have no idea how long this will last, or if it means the battery is going...but, give it a try!
May 06, 2007 | Canon ZR85 Mini DV Digital Camcorder
Canon ZR85 Mini DV Digital Camcorder Logo
447 people viewed this question
Top Canon Video Cameras Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
Steve Mason
Are you a Canon Video Camera Expert? Answer questions, earn points and help others
