Question about Kenmore 64254 / 64252 / 64259 Top Freezer Refrigerator
Makes a shuddering noise when compressor turns off
  • 21 Answers
It sounds like the suspension spring has broken inside the compressor so when it shuts off it rattles against the case. If the refrigerator is still operating normally I would recommend not repairing it. It could run for years like this without any further problems and a compressor change would be very costly.
Posted on Feb 24, 2009
My fridge knocks when running
Your fridge's compressor motor is suspended inside the compressor housing on three or four springs. These springs are designed to hold the motor load in a vertical position. Transporting a fridge on it's side can stretch or break these springs which can cause a shudder stop condition (the fridge makes a shuddering banging noise everytime the compressor stops and sometimes when it starts).
It's a good idea to let a fridge sit for a bit anytime it is moved. Over night won't hurt but an 8-10 hours is more than enough time some say less.
the internet consensus seems to be that you should limit the amount of time the unit is not upright. And as stated above, leave it upright at least overnight before starting it. Apparently damage can arise from mixing of lubricant and coolant, so damage is more likely in an older unit with worn seals.
Apr 11, 2015 | Hotpoint HSS25GFP Side by Side...
I moved a fisher and paykel upside down fridge freezer to a new house, I turned it on a half hour after it was in my new home but it has not gotten down to a cold enough temp, if I turned it on too so
It is possible damage will result. Your fridge's compressor motor is suspended inside the compressor housing on three or four springs. These springs are designed to hold the motor load in a vertical position. Transporting a fridge on it's side can stretch or break these springs which can cause a shudder stop condition (the fridge makes a shuddering banging noise everytime the compressor stops and sometimes when it starts).
It's a good idea to let a fridge sit for a bit anytime it is moved. Over night won't hurt but an hour is more than enough time.
Jan 18, 2015 | Fisher and Paykel Refrigerators
Dryer making shuddering noise GE DPSR475GW0WW
Dear Mike:
I had the same problem with miner.
After listening to the shudder for several months, I opened the top up and put a tiny bit of grease (automotive) on the front of the drum where the slides are rubbing it. and the shuddering stopped.
That was 5 months ago. I have had to regrease it once, about 1 month ago.
Recommend only about a 1/2 teaspoon of grease, and wipe it on with your finger or a rag.
Be blessed
Feb 11, 2013 | Dryers
Squaking noise on turns
cv joint look and c if the boot is broke if so need cv axtso
Mar 19, 2012 | 2002 Subaru Forester
My fridge has become increasingly more noisy when the compressor kicks in. Any thoughts on why and how to fix this?
The only way to eradicate the noise, is to replace compressor. Some make shuddering noises on start up and some on switch off. Basically, in the compressor dome are 4 rubbers equally placed holding the internal motor. If one of those rubbers disslodge, then the noise starts.
Jun 05, 2010 | Whirlpool ES5FHAXS Side by Side...
1998 Honda CR-V makes low pitched shuddering or growling noise intermittently when turning sharp right or left at very low speeds.
YOU should find that if you let off the turn a bit and not turn on hard full lock,, now do this stopped and someone sitting in the drivers seat and bonnet open and turning the steering wheel with engine running in idle
if the noise goes and the shuddering goes then its the powered steering pump is either low in fluid or airrating or if belt driven then see if belt is trying to stop on full lock and if it is then try a new belt or other wise its the pump faulty.
Oct 14, 2009 | Honda CR-V Cars & Trucks
My one year old whirlpool shudders when it goes
Shuddering (cool word) happens when one of the motor support springs inside the compressor , either breaks , comes loose , or never connected . I would suggest having the compressor replaced while still in warrenty , where there should be no cost to you , except for MAYBE a service call . Usually , 5 yr warrenty on the compressor and sealed system (no cost to you for parts and labor ) . Compressor knocking when cycling off is a creditable compressor replacement cause .
Aug 28, 2009 | Whirlpool Refrigerators
Loud noises, bangs and sounds like water falling
if it’s a banging sound--- I know one of the noises the system 2000 will make is a bang or rattle at the end of the run cycle, which we call "shudder stop". If this is your noise then I have to give you some bad news here. Sorry....... The only way of repairing this is by having your compressor replaced as it has to do with an internal problem in the compressor itself. There may be a silver lining, though, if you are the original purchaser and you have the receipt. Some of these systems came with a 10 year warranty on the compressor, so you might want to check this out.good luck
Dec 10, 2008 | Kelvinator 12 cu. ft. / 340 liter Chest...
When I turn off my new Olympus E520 it shudders, and make a noise like there's a motor off balance. Is this normalforthe camera?
It is because "Image Stabilization" and it is normal. Turn it off and it will not shudder.
Jul 09, 2008 | Cameras
Kenmore 64254 / 64252 / 64259 Top Freezer Refrigerator Logo
1,009 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
