bypassing renkus heinz p1500 potentiometer.
I need to bypass the potentiometer on my amp. I cant get parts and the pots are bad. I just want to bypass them and run the amp full out. can you advise?
As the pots are part of the necessary feedback loop for the final stage, I would recommend that you jumper the wiper of each respective pot to its "full on" position. Problem solved!...accordianman
My surround (rear) channel stopped working. I tried the same speakers and speaker wire on the front...
(More)
My surround (rear) channel stopped working. I tried the same speakers and speaker wire on the front channel and they worked fine. Since this happened immediately after the speakers were disconnected to allow for a re-arrangement of our main floor, I suspect when the banana plugs were pulled that it could be a continuity issue between the circuit board and the connectors. Interestingly enough, my extended 5 year warrantee expired last month.
When I try to power it up it comes on momentarily and then goes to standby. The manual suggest...
(More)
When I try to power it up it comes on momentarily and then goes to standby. The manual suggest resetting the microprocessor by unplugging and then holding in the power button and plugging back up. It doesn't help. Any suggestions?
