Question about Sony Cyber-shot DSC-W50 Digital Camera
There is no recording of sound why i do a movie, can you help?
The movie is ok, however, the microphone is not picking up any sound from the persons being filmed.
    President:
  • 1,223 Answers
Some cameras doesnt support all shooting modes with sound try to change resolution of the video and see if the sound works , does sound works on like pc if u take this clip to pc will it work there , if yes then ur tiny speaker in the camera is faulty if there is no sound on pc as well then 2 things either select a different lower res and try or the built in mic is not working
pls rate me according to my response
Posted on Feb 24, 2009
What do you do if the built in microphone for the Toshiba Satellite M305D-S4840 is not working (not picking up sound)?
SKYPE MICROPHONE PROBLEM
If the person cannot hear you then, either your microphonedriver not installed or not working OR the microphone is not configured inSkype.
To test your microphone then click on Start - All Programs - Accessories -Entertainment - Sound recorder. Then record your voice and then play it back.If this is OK then the microphone need to be configured in Skype.
To configure the microphone - Open Skype - Tools - Options -Audio Settings for the Microphone THEN click on Save.
May 20, 2012 | Toshiba Satellite M305D Notebook
Tip
SKYPE MICROPHONE PROBLEM If the person cannot hear you then, either your...
If the person cannot hear you then, either your microphone driver was not installed or not working OR the microphone is not configured in Skype.
To test your microphone then click on Start - All Programs - Accessories - Entertainment - Sound recorder. Then record your voice and then play it back. If this is OK then the microphone need to be configured in Skype.
To configure the microphone - Open Skype - Tools - Options - Audio Settings for the Microphone THEN click on Save.
on Oct 23, 2010 | Computers & Internet
In my laptop hp compaq cq45 with os windows xp microphone is not working plz solve my problem...
Mar 04, 2012 | Computers & Internet
Lenovo B500 microphone (built in) not picking up sound plug-in microphone not picking up sound playing sounds through built in speakers eg cd, dvd etc - OK
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
hope this helps
Jul 01, 2011 | Computers & Internet
Cannot get laptop microphone working
Double click on the little speaker icon on the Desktop toolbar at the bottom right of your screen. The volume control window will open. Click on options then properties. Next check the small round recording button. Now make sure he microphone box is checked then click ok. Now a window will open that will show your microphone recording level. Move the slider up about half way and make sure to check the small "Select" box near the bottom of the slider. Open up sound recorder or whatever application you are using and try to record. If this does not work I would get an external microphone plug it into your laptop and try recording again. If the external mic works then I would think that you internal microphone is not working. There are some very cheap external mics on the market that sound very good. If you are doing any serius recording you may want to invest in a USB microphone. The USB mic should come with it's own software and setup should be pretty simple. I hope I have been helpful.
Mar 16, 2009 | Compaq PC Microphone (Black or Beige)...
Olympus sp510uz no sound on video
From SP510 camera switched off:
1. Turn dial on top plate to movie mode (selections from the menu screen apply to the mode the camera is set in);
2. Switch on SP510 power;
3. Press "MENU" button on back plate;
4. Select "Camera Menu" from screen if not already on it, using navigation buttons on back plate
5. Scroll down yellow "Camera menu" tabs to microphone picture (below "Digital Zoom"), which may be showing "off". Select OK and toggle yellow tab from "off" to "on", then press OK button.
6. Microphone tab should now show "on".
7. Return to main menu (press MENU button).
8. Return to image screen (press MENU button).
9. Test to see if video now records sound.
10. If is still doesn't record sound, try "reset" from video menu screen (this will reset the movie mode to factory settings, including microphone on).
Dec 21, 2008 | Olympus SP-510 UZ Digital Camera
QUICK CAM E1000
The problem is that the camera is just a camera... there is no microphone on it.
Oct 25, 2008 | Logitech QuickCam Communicate STX Personal...
IT DOES NOT WORK ECM-MS907 Professional...
Just in case you have having the same problem as me....
The reason why my microphone was giving mixed results was because I was using the wrong setting. The microphone slider says "90 degrees" and "120 degrees." I assumed that these angles refered to the area that the microphone picked up. So for a single narrow sound source, like my voice, the narrower, 90 degrees setting seemed appropriate.
Now that I have looked at the manual I see it is the reverse (weird but true. Perhaps the angles refer to the angles that the microphone ignores completely under each setting?).
I have been recording my voice. I noticed that sometimes the sound was good and other times the sound level was too low. I think that the reason is because sometimes I inadvertantly set the microphone to the 120 degree setting, which picks up my voice well, while at other times I set the mic to the 90 degree setting which attempts to pick up sound from a wider area, giving the central source less prominence.Setting the microphone to the 120 degree setting cured my problem. I hope it cures your problem too.
The manual is here:
http://www.docs.sony.com/release/ECMMS907.pdf
Aug 24, 2008 | Sony ECM-MS907 Professional Microphone
How to disable microphone / sound on Samsung Digimax A503 Camera while recording movie
no i cant even turn the sound on...can sum1 please tell me how you get the camera to record sound when i record a video.thankyou :)
Jun 13, 2008 | Samsung Digimax A503 Digital Camera
Im confused
The microphone may not work because of a hardware or configuration problem. To determine if it's a hardware problem, test the microphone in Sound Recorder.
  1. Click "Start," > "Programs" ("All Programs" for Windows XP) > "Accessories" > "Entertainment" > "Sound Recorder."
  2. Click the Record button and speak into the microphone of the camera. You should see the green line move, indicating the application is picking up sound.
  3. Click the Stop button.
  4. Click the Play button. If there is no sound at playback, check to make sure the correct device is selected.
    1. Click "Edit," then "Audio Properties."
    2. Make sure Logitech is listed as the Preferred device for "Sound recording."
The microphone may also be defective. To test this, try the camera on another USB enabled system.
If you can record sound in Sound Recorder, but not in the QuickCam application, try setting the Logitech Microphone as the Preferred device in Audio Properties.
Multimedia Keyboards:
A multimedia keyboard is a keyboard that has a button which can automatically control your computer volume. If you have a multimedia keyboard installed, the software for the multimedia keyboard may need to be uninstalled in order for the camera's microphone to work properly in Windows. Please contact Logitech with the make and model of the multimedia keyboard that is causing the problem. While we will not be able to assist you other than to advise to uninstall the keyboard software, it will help us determine the root cause of the incompatibility.
Mar 13, 2008 | Logitech QuickCam Communicate STX Personal...
Sony Cyber-shot DSC-W50 Digital Camera Logo
70 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
