Question about Kicker CVR12 Car Subwoofer
Stereo stations wont stay set
I have a JVC KD-S25 cd player. I preset the stereo stations but when I turn the key off the stations will no longer be set. I am having the same issue with the EQ setting. There is NO memory wire
  • 8,197 Answers
If you have a yellow wire that is the memery wire. It needs to be hooked to a constant hot. If you do not have one you need to get a new plug for the back.
Posted on Feb 24, 2009
Testimonial: "Thanks for the help. everything works perfect "
I have a jvc kd g845 and everytime i set up my presets and then turn the car off the radio presets reset themselves how can i stop this from happening. any help would be much appreciated.
Make sure the yellow wire is going to a source that still has 12 volts going to it when the key is turned off. The yellow wire controls the memory of the deck.
Jul 31, 2011 | JVC KD-G830 Car CD/ MP3 Player
The memory on my new jvc car stereo model kd-s17 does noty work whenever i turn the key off then on i have to reset the clock and presets all of my wires are connected
need to check the yellow constant power wire on wire harness to see
1. connected to battery with constant 12 volts
2. if wire has power 12 volts
if no power check fuses to see if blown
with out this wire working right you will never have pre set station on radio or clock
with correct time
Dec 22, 2010 | JVC KD-G801 CD Player
I installed my JVC KD-SX650 and it works but it will not keep the radio station settings and the clock setting once I turn my truck off and back on again, what could be the problem?
you need to make sure the yellow wire is going to a constant power source.. the yellow wire controls the clock and preset setting memory.
Jul 13, 2010 | JVC KD-SX650 CD Player
My car stereo a jvc kd-s6060 losses pre-set stations when its been turned off.
Your wires are probably backwards. the yellow one is for memory and it gets wired to direct battery voltage to hold the memory. The red wire is for power when key is turned on.
Oct 06, 2009 | JVC KD-S6060 CD Player
Turns on then off right away
Hello headbanger42,
First I'd check all of the wiring and connections. Make sure that there's no bare wires, no cut or frayed insulation and no wires contacting metal on the vehicle or other wires.
If everything is connected properly and there's no shorts, press the reset button on the panel holder using a ball-point pen after detaching the control panel. (The clock setting and preset stations stored in memory will be .)
If that does not work, there's most likely an internal fault and the receiver needs service.
Hope this helps.
Jun 02, 2009 | JVC KD-SX980 CD Player
JVC kd-s590
you need to have whoever installed the unit connect the YELLOW (memory) wire on the back to a constant 12 volt power source. It is hooked up right now to only have power when the key is on. this is why when you turn off the key, you loose memory.
what kind of car is this in... I can tell you what wire goes to what color if you cant figure it out.
Jan 12, 2009 | JVC KD-S570 CD Player
Jvc car cd/radio
The radio was improperly installed; there are two 12V leads, one services the radio when on, the other, only the circuitry for the clock and presets.
Eventually, this shouldn't be needed if the manufacturers ever think about using a little bit of flash memory for the presets and a coin cell for the clock.
You didn't give any model number so researching the manual is impossible.
If you can find the model number, look for a user's (or installation) guide on line to find the wiring info.
Aug 25, 2008 | JVC AM FM CD DET FACE CAR STEREO
Jvc kd g521 car cd player
Have you checked the cables? It appears that you have connected the wire for ignition directly to the power in and the direct +12v to the ignition cable. When turning ignition off, the memory is then emptied.
Jul 06, 2008 | JVC AM FM CD DET FACE CAR STEREO
Kicker CVR12 Car Subwoofer Logo
177 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
