Question about Better On-Line Solutions Computers & Internet
Network cable is plunged but pc is not in network.It doesn't ping to another pc and in workgroup it shows only this pc
    Genius:
  • 1,605 Answers
Do you have a device on the network rounning as DHCP? if so,
go to
start>> run
type in "ipconfig/release"
when you get a prompt, type in "ipconfig/renew"
try to pin the other computer.
if not, then you need a router or modem can act as DHCP.
Posted on Mar 03, 2009
Not Sharing pc for win 7
It may be because of the workgroup setting. WINXP uses a default workgroup value of MSHOME. WIN7 uses a default of WORKGROUP. What happens then is that all computers can connect to the network and access the internet, but shared files and folders will not be seen due to the two different workgroups,
To change the workgroup in WIN 7:
Click START.
Right click on COMPUTER, choose PROPERTIES.
In the SYSTEM window, choose ADVANCED SYSTEM SETTINGS
in the SYSTEM PROPERTIES window choose the COMPUTER NAME tab.
Observe "Workgroup" name.
To change, click the CHANGE button
Put the new workgroup name in the WORKGROUP block
(WINXP default is MSHOME)
Click OK
Close all windows
You will need to restart PC to set the new workgroup
Nov 11, 2013 | Computers & Internet
I changed the network to workgroup and shut down the computer. now my password doesn't work because it can't find the network
download and run offline nt password and registry cleaner from here: follow the walk though and you can remove the password and start over. :http://pogostick.net/~pnh/ntpasswd/
Jun 05, 2012 | Dell OptiPlex 170L PC Desktop
My lan is not working properly? so what can ido for it????????
Ensure that LAN card Driver is Installed Properly.
Check Proper IP address is assigned. and workgroup is same in networked computer
Run PING Command to check connectivity to other machine.
If ping Reply is not showing then Re-Crimp Cable after verifying IP address, Workgroup are Correct.
Mar 23, 2010 | Computers & Internet
I am with WinXP sp2 i am having problem with lan network access to other PC, but the Ping is working to other computers
1. Check that you are in the same workgroup (My Computer -> Properties -> Computer Name tab -> Workgroup 2. Check the firewall status on the other computers. You may be blocked because of this.
Feb 21, 2010 | Lannet Computers & Internet
How do i get connected to another local computer with wire
you need either a "crossover" cable or both plugged into an ethernet switch, with network settings the same but i.p. addresses off by 1 digit. eg. 192.168.1.3 on computer "a" and 193.168.1.4 on computer "b".
Oct 25, 2009 | Computers & Internet
Not ping
Is this computer in the same workgroup as the other computers?
Does this computer have the same IP address range as the other computers?
Is the network card on this computer working and enabled (check device manager)?
Use ipconfig command from the DOS panel to check the IP settings on this computer. Also run ipconfig on the other working computers and compare the IP settings. Each computer's IP address should all be the same except for the last group of numbers, eg. 192.168.0.xxx
Get back to me if you still have problems.
Jul 15, 2009 | Compaq Presario 700 470024-192 Notebook
I want to connect two pcs via a rj45 cable.... what is the wiring that is required?
There are 2 ways to do it--
1)You can connect two PC's via a hub switch or a router Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} using Ethernet cable or
2)Directly using lan cable (crossover) Normal 0 false false false MicrosoftInternetExplorer4
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1)Be sure that both computers are logged in to Windows.
2) Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Connect each end of the crossover cables in to the network cards of each computer.
3)Boot up both computers and assign PC,s the static IP add eg
assign one PC IP Address as 192.198.0.1 and another as 192.198.0.2.
4)Both machines shuld use the subnet mask as 255.255.255.0, Go to Start>> Control Panel>> Network Connections>> Right click your Local Area Connection and select Properties. Scroll the list for the entry titled: Internet Protocol (TCP/IP). Click the entry and select Properties. Under the General tab, tick the box titled: Use the following IP address. Enter the IP address and Subnet mask that you would like to use. Repeat the steps above for the second computer system.
5)Make sure both PC's have common workgroup name eg MYGROUP, Go to Start>> Control Panel>>System. Select the Computer Name tab. Click the Change button. Change the Workgroup name. Repeat these instructions on the second computer ensuring that both computers are named exactly the same.
6)Reboot both the systems
7)Next, open a command prompt on one of the computers by going to Start>>Run. Type in: command [Enter] or click OK.
8)Type: ping 192.198.0.2 (if you are using the computer assigned with 192.198.0.1) press Enter.
9)Five replies to your ping should be indicated.
10)Now you can enjoy the benefits file sharing,printer sharing,Internet connection sharing, network games etc
Jun 21, 2009 | Computers & Internet
INternet connection
install drivers for lan card
open run cmd
ipconfig/all
it will show u ur ip adress
then ping to gateway
Jan 27, 2009 | Dell Ethernet Card Network Adapter
2wire blocking traffic between hosts on internal network?
Are both computers part of the same workgroup/domain?
Nov 28, 2007 | 2wire HomePortal 1800HG Router...
Printer Pinging problem?
Make sure your wireless workgroup/domain are the same as your wired network. If they are, you should reinstall the printer from control panel. Choose add network printer, choose the proper workgroup/domain, you should see the available printer, select it, it may need to download drivers and install them. Tim
Jan 29, 2007 | HP Color LaserJet 2600n Printer
Computers & Internet Logo
43 people viewed this question
Top Better On-Line Solutions Computers & Internet Experts
David Payne
David Payne
Are you a Better On-Line Solutions Computer and Internet Expert? Answer questions, earn points and help others
