Question about HP Compaq Presario R4000 Notebook
Compaq Presario R 4000 to dark when on battery only.
I checked power options and set to minimum battery. Also pressed f5 ( moon icon key) and arrow up key, nothing. Please help. HP tech support charges for any kind of help. I will never buy another HP product again.
  • pontelemon
    pontelemon May 11, 2010
    When you plug AC adapter, is LCD getting brighter?
    Problem Solver:
  • 3 Answers
The R4000, or at least mine will appear to be brighter when on battery also. If you press the function key and then the f8 key it will brighten the screen.
Posted on Apr 18, 2009
HP Compaq Presario R4000 (PN495AV) PC Notebook How
Yes, go to Start>Control panel>Power Options. There also should be a screen brightness key on your key board, that looks like a sun shining, with arrows pointing up & down. To use that key, hit the FN key, right next to the Ctrl key. Push & hold the FN key, while pushing the up arrow. That should increase the brightness of your display. Good luck.
Jul 06, 2011 | HP Compaq Presario R4000 Notebook
Is there any way to brighten my screen on my acer aspire 5601 lap top
Examine the keyboard. There should be a symbol on most of the function keys (F1, F2, etc.). Look for one that looks like a sun or lightbulb, either with an arrow pointing up or with the sun/lighbulb filled in. Hold the 'Fn' key, and tap the up/bright sun/lightbulb key a few times. The screen should increase in brightness.
If you cannot find the specified keys, you may be able to adjust brightness from inside Windows. Right click on the battery icon in the taskbar and open 'power options'. Look for a sun and moon with a sliding bar between them. You might also be able to adjust brightness by customizing your desktop (right click on the desktop and look for the proper menu).
Mar 22, 2011 | Acer Aspire 5600 Series 5630-6951 Laptop
How do I adjust the brightness on my laptop? Its a Compaq Presario V2140US
1. Press down the Fn key at the lower left end of your Compaq Presario keyboard. Keep the button held down and tap the F7 key to decrease the screen brightness by one step.
2. Tap the F7 key again with the Fn key still depressed to further decrease the brightness by one step. Continue hitting the F7 key until you reach the minimum LCD screen brightness.
3. Hold down the Fn key and tap the F8 key to increase the Presario's LCD screen brightness by one step. Keep pressing the F8 key until you reach the maximum brightness for your screen
Mar 01, 2011 | Microsoft Compaq Presario C501nr Notebook
Set up bios hp compaq presario v2000
1. restart you computer and enter bios screen by pressing f1 or f10 at first screen
2. set bios as you like, or press f5 tkey to load the default bios configuration
3. select yes using arrow key, and then press enter
4. press the f10 key to save the setting and exit
5. select yes using arrow keys and press enter
for more isformation about hp compaq bios see this page
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=120&prodSeriesId=409741&prodTypeId=12454&objectID=c00220813
i hope this helpfull
thanks for using fixya
Jan 27, 2011 | HP Compaq Presario V2000 Notebook
I have a Compaq Presario F700, how can I activate s-video out?
On most laptops it a simple case of pressing two buttons together, usually th 'FN' or 'Function' Key and 'F5' (press fn first, hold down then press f5) Yours maybe slightly different and use a different F key ie F3.
Nov 22, 2009 | Compaq Computers & Internet
My Compaq keyboard has a key with an icon shaped like a moon. What is that for? Also, ovedr the number pad, there is a light on the right that has an arrow pointing down. What is that light for. Also, my...
The Moon key is for putting your computer to sleep, the keypad light is probably the NUM LOCK LIGHT. When your screen blacks out will it come on again if you press enter on click the mouse button? if so, go into the control panel, click on the power options and look for the icon marked 'Screen' or something similiar. Change the timing to an hour or so...
Jun 03, 2009 | Computers & Internet
Laptop screen goes dark.
Is your computer setup to go to sleep when you close the lid?
Click on start -->control panel-->power options and then check the option that says choose what closing the lid does. You have to change this setting to 'do nothing' if you want the computer to stay on when you close the lid.
May 19, 2009 | HP Compaq Presario C700T
My computer has no sound .i have compaq presario c700.windows xp
You should have the speaker wire plugged into the green hole.
You need to have the correct speakers. Powered ones are best, but they need either batteries or an AC adapter.
You need to be sure the sound drivers are installed on your computer. You can go into the control panel and click on the "sounds and audio devices" icon. It should tell you at the top what audio device is installed, and then check to be sure the volume it up over 1/2 and also that the "mute" box is not checked. Then go to sounds tab on that window. The sounds are listed at the bottom of the window. Any sound with a little speaker beside it should play a sound when you press the dark arrow to the right of the sound. If the arrow is not dark, then there are no sound drivers installed on the computer and you'll have to find out why--but that's another issue.
Jan 29, 2009 | Compaq Audio card Sound Card
Everything on my compaq presario cq50-215nr laptop got really big after i accidentally hit a couple of buttons on the keyboard and i dont know what i hit. how do i make them go back to normal size
Choose Screen Resolution For higher legibility of documents on screen, you can adjust the screen resolution of your monitor (for monitors that support more than one screen resolution option). The higher the number of pixels, the more information you can display on your screen and the smaller items appear. Lower screen resolution makes items appear larger and can benefit people with vision impairments. This procedure tells you how to adjust screen resolution through Display Properties in Control Panel.
Mouse actions Keyboard actions 1 On the Start menu:
  • Select Control Panel
Display the Start menu by pressing CTRL+ESC (or the Windows logo key winkey.gif).
  • Select Control Panel by pressing C.
2 In Control Panel:
  • Be sure you are in Classic View (all Control Panel icons are showing).
  • If not, under Control Panel in the left pane, select Switch to Classic View.
  • Select Display.
In Control Panel:
  • If not, under Control Panel in the left pane, select Switch to Classic View by pressing TAB.
  • Press ENTER.
  • Press the RIGHT ARROW key, and then the LEFT ARROW key to select Display.
  • Press ENTER.
3 In the Display Properties dialog box:
  • Select the Settings tab.
  • Move to the Settings tab by pressing CTRL+TAB.
4 On the Settings tab, under Screen Resolution:
  • Select a screen resolution value by moving the slider arrow.
  • Select OK.
On the Settings tab:
  • Move to the Screen resolution slider by pressing ALT+S.
  • Choose a screen resolution value by pressing the RIGHT ARROW or LEFT ARROW key.
  • Press ENTER.
5 To close Control Panel:
  • Select the Close button.
  • Press ALT+F, C.
screenresolution.jpg Control Panel: Display: Settings tab: Screen resolution
Jan 02, 2009 | Compaq Presario 5000 PC Desktop
Compaq Presario R3000 dim screen but not dark
Sounds like the auto-dim in the BIOS is set too low. Fortunately the Compaq R3000 allows you to adjust the brightness right from the keyboard. Hold down the [FN] function key while tapping the [F8] key will brighten the screen, while [FN]-[F7] will dim it. The settings are different for running on AC power and battery, so you must do each individually.
Dec 31, 2008 | Compaq Presario 700 470024-192 Notebook
Computers & Internet Logo
93 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
