Question about HP OfficeJet 6110 All-In-One InkJet Printer
HP OfficeJet 6110 xi Self Test "Align Cartridge" Failure
I just turned on an old HP OfficeJet 6110xi that hasn't been used in a long time. I put in new inkjet cartridges however I keep getting "alignment failed...please try again". Any ideas on correcting this alignment issue? Thank you. George
  • dayvellen Apr 08, 2009
    My 6110 prints a little skewed. When I copy something, it wants to align cartridges, tries that, and fails.
  • Anonymous May 04, 2009
    hp dj officejet 6110 all in one scanner failure turn power off then on again
  • 25 Answers
Hello there,
Try cleaning print cartridges from HP toolbox
or reset process
Please see note at bottom re: powering on and off
1) If you know you are going through the re-set process. Ensure there is nothing in your printer que already when you want to power on again.
2) Plug printer/scanner directly into the wall, not a power bar or UPS... Read at one point, it has something to do with the electricity (KW or Voltage or Amps) factor and power requirements to the printer/scanner. However was very technical and don't remember enough details to explain properly, sorry... Anyhow, directly into the wall.
This is what has worked for me. Got original re-set process of solution from sillygirl.
3) Disconnect all cables from printer.
4) Clean the glass on top with alcohol and cotton swabs.
5) Then go through the reset process (press # 6 while plugging the power back into the printer).
6) If you have the CD for your printer it doesn't hurt to put it in your CD carriage in case your printer is looking for files or drivers. If CD starts to go to a un-install or full re-install just cancel and leave in carriage.
7) Sometimes helps if you first plug printer in.
8) Re-boot pc before powering on printer. Once re-boot has started and PC will start to look for printer.
9) Power on printer (press # 6 while plugging the power back into the printer to re-set).
10) Watch for point where your printer icon usually appears and plug the USB into the PC.
_____________________________________
11) If this does not work then take the printer apart and clean the underside of the glass as well. Unfortunately need to go through re-set process again. May need to buy a set of screw drivers for removing the glass. They are different. (Torx)
12) In another solution it states - you must clean all the mirrors inside the scanner assembly q-tips work well (black box closed with two locks) also the lens and the delicate spaghetti-like lamp. Generally this works... Not everyone has done this part but worth a try when the printer is already open.
13) There is a black and white strip at that end of the scanner. Check to ensure the strip is there, in tact and placed correctly. This is what the scanner carriage aligns itself with.
Just so people know. I have posted solutions to this before that have worked for me. However, I really do think this comes down to a driver issue (do we all have XP, mine is actually XP Home Edition). Since HP no longer updates these printers not sure if we will ever see a driver that works perfectly. Once you get it going again it will all work great. The problem lies in powering on and off. Once you get it going without the scanner carriage jamming, leave it on! Even in the case of a power out I usually have to re-set again but can get it going, eventually (it can be very frustrating). Sometimes need to re-boot PC and plug USB into the PC while booting up and just about to look for your printer. This is to ensure it finds the printer/scanner. Also, when really desperate uninstall and re-install the hardware. Sometimes can try for quite some time to get it working again and eventually have to just leave it off for a few days then can get going again afterwards. Not sure if this has something to do with memory.
Posted on Feb 28, 2009
  • Jo-Anne Feb 28, 2009
    You may want to try cleaning print cartridges through HP Toolbox at one point once you get it going too.
  • 20 Answers
Fiend your solution direct from hp. Here is your solution...
http://www.hp.com/printer/prob676ijt65/solution
a19
Posted on May 28, 2009
Changed cartridge in printer few weeks back - took several attempts to get cartridges to align afterwards. Now say to remove and check cartridge (appears to be problem with colour cartridge!). When put...
It might mean that your cartridge has become demagnetized. That happened to me and I had to replace the cartridge. The little brass covering at the front of the cartridge is very delicate and can become demagnetized if handled incorrectly. You can buy refurbished ones on line and they are not as expensive, but that is entirely up to you. Good luck.
Jan 05, 2011 | HP OfficeJet 6110 All-In-One InkJet...
My hp officejet 6110xi all in one won't align ink cartridges
the reason that it wont align is you are either out of black ink or the tricolor ink ctg needs to be replaced
Jun 05, 2010 | HP OfficeJet 6110 All-In-One InkJet...
I bought a new color print cartrige and since then my printer align cartridge keeps failing so I can't use my printer. I have reincerted them many times and ran the align cazrtride and I get the same thing...
Sorry to ask a dumb question but did you remove the protective tape on the cartridge when you installed it? If yes, then proceed to the following HP help page where the align cartridge error is outlined along with several solutions. Best of luck!
Greg
OfficeJet k60 Align Cartridge
Nov 06, 2009 | HP OfficeJet k60 All-In-One InkJet Printer
My printer stopped printing
your senser is off you have to tak it in for minor repairs
May 05, 2009 | HP OfficeJet 6110 All-In-One InkJet...
Won't allign cartridges
Reinstall old one let it run through it's cycle then reinstall the new one. This usually works.
Dec 27, 2008 | HP Officejet 5610 All-In-One InkJet...
HP 6110xi cartridge align under Vista Home Premium
it is necessary to place the allign page in the scanner and then press the enter button and the scanner will read the allign ment page as it will take 2 minutes and then it will display the message allignment complete message then it will become normal as it was .so after u get the allignment page place it in the scanner unit of the printer and then press enter.
Oct 01, 2008 | HP OfficeJet 6110 All-In-One InkJet...
I receive a consistent message that alignment of cartridges failed.
Ensure you are using original HP cartridges. Using refilled/generic inks can cause this problem.
If you are using original inks, try cleaning the contacts of the cartridges gently with isopropyl alcohol. Should it still fail, get them replaced.
The above solution was Comment by IrishDruid, posted on Jun 01, 2008. I tried it on my HP officeject 6110xi (using alcohol swabs). It worked perfectly.
Jul 10, 2008 | HP OfficeJet 6110xi All-In-One Thermal...
Alignment after new cartridge
Hi I think that you will need to clean the gold dots on the printer carriage or if not done so remove the blue tape from the cartridge or if you are trying to use refills install some originals as this may help.
Hope this helps'
Please rate me
Cheers J
Dec 30, 2007 | Apple HP Officejet G85xi InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
2,132 people viewed this question
Seeker5211
Seeker5211
