Question about Whirlpool Duet GHW9150P Front Load Washer
Old duet washer -error message F - 01 flashing
Error message F - 01
  • 52 Answers
An F1 is almost always a defective main control board. Could try unplugging the unit for a few minutes and see if it will reset. The part # for the board is W10110072. Sears sells it for $119.46 or you could check E-Bay.
Posted on Feb 24, 2009
Duet dryer is giving me a F01 error message
f 01 is control systemand board fault cheaper to replace
Aug 17, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Flashing an error code F-01
I am sorry to tell that your control board is bad. That is not a cheap fix.
Nov 24, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Will not drain or wash F-01 error message
unplug to reset,,,if this comes back you have to replace the control board...onthejob
Jan 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Intermittant trouble with code d 11
Answer Duet HT®
Duet®
duet_f_dl_actualsize.gif Duet SportTM
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service.
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Flashing F
check out this link for the error codes u receive and how to resole it manually
http://www.applianceaid.com/duet_washer.html#duet
good luck thanks.
Oct 26, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet dront loader washer
Welcome to Fixya,
Try this,
The manufacturer recommends unplugging the washer for at least 30 minutes. This will often fix momentary glitches with the washer.
Let me know,
Huuum
Please remember to leave a rating
Oct 07, 2008 | Whirlpool Duet GHW9150P Front Load Washer
THE MODEL # IS WFW8300S WHIRLPOOL DUET SPORTS WASHING MACHINE
a power glitch can cause this promblem first push pause cancel twice to clear this error code then try the washer on drain spin and listen for the pump to come on if it does then clear the machine by pause cancle twice then try to start again if code resets then the promblem is most likely the ccu or the board but try clearing the error first if that dont work get back with me and we will run diagnostic mode
Dec 28, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
122 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
