Question about Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television
Sharp Aquos 4.5 yrs old had an audible pop and no power
Audible pop when I went to turn the TV on. The control box has got power to it but no power to the monitor. Checked all the connections everything looks good. What's up?
    Problem Solver:
  • 13 Answers
There are a number of things that could be wrong.
The basic first thing to try is to replace the cable(s) that feeds your TV signal; sometimes the connection with the connectors on the end goes bad.
HDMI or what ever feeds your signal. You can make your own RCA or traditional F type coax connector with the connectors from this site or you can buy what you need for composite or RCA at your local store. This could be the problem if the signal has just stopped coming over. hopefully that is the problem.
Next is the bulb in the bulb should be checked. In an LCD it can just happen. the light dies. if you are getting no sound and no image the bulb is likely not the problem.
You may have a short or bad resistor or transistor. the board that controls your TV might not be getting proper power, be it too much or too little. If you suspect this is the case leave the TV off, that pop could be a power surge flowing over the components of the TV. and could do further damage.
Depending on the value of the TV you should consider recycling. Replacing a TV under 300 or 250 is worth it. a warranty is included. an involved repair could run 300-400 dollars or more, but on a big screen TV that costs over 2,000 a repair is a good value.
-good luck-
Will
Posted on Feb 24, 2009
My Sharp tv remote will not turn on / off tv. It will turn on by the main power switch on tv but not by remote.
From page 8 of the manual:
The POWER indicator on the AQUOS television should light GREEN indicating you have power to the AQUOS television.
If the POWER indicator on the AQUOS television still does not light up, press TV POWER on the remote control to turn the power on.
IMPORTANT:
IF THE UNIT DOES NOT POWER ON - UNPLUG THE AQUOS TELEVISION FROM THE OUTLET AND REPEAT THE INSTALLATION STEPS.
IF YOU STILL ENCOUNTER NO POWER, PLEASE CONTACT US AT 1-800-BE-SHARP
http://www.nemsworld.com/theater/LC46_52D62U_Manual.pdf
Dec 04, 2015 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Tv does not start up at all but there is an audible beep when you press the manual on/off button
my advise is to disconnect the sky box and any other ancillares. and see if the tv works as a normal tv only. if not the tv has a fault.if it now works connect your other ancillaries ie skybox one at a time if the tv gives up then just backtrack what you have just done it may just be a faulty cable
Nov 27, 2017 | Polaroid Televison & Video
Have a vertical green line on my sharp led aquos, it is only 4 months old. how do i get rid of the line
I'm assuming you have a high definition cable box connected to this television with an hdmi cable a motorola perhaps. If that is correct then with you motorola cable box power turned off press the menu button on it. Yes I just stated that you turn off your motorola cable box and then press the menu button on it. A hidden menu will pop up on your television screen. Yes the television should be turned on but the motorola box should be turned off when you press the menu button. I am sorry for reiterating that so many times but there have been numerous persons that have been more concerned about why this works in this way than just getting it to solve their problem. So you navigate down to the color space setting. You will be able to navigate left or right to choose a different setting under color space. You will see maybe RGB of YCbCr 4:4:4. Choose the one that your cable box is NOT set to currently and the green line should go away.
Sep 20, 2011 | Sharp AQUOS LC-52D82U 52" HDTV LED TV
Audible pops through my speakers every 30 seconds
Your computer may be overloading the speakers, in volume control turn the master volume down a bit and see if that is helping.
May 20, 2010 | Sony VAIO PCV-RS411 PC Desktop
A "Critique show" text message keeps popping up
This is definitely not a Sharp Aquos feature. Any show related functions come from Dish Network. It might be a channel specific function which the Dish Network support staff does not know how to deal with.
Jan 31, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos LC C3242U - Intermittant Sound Switching from Mono to Stereo
Not sure if I just got lucky or if the problem is solved..I hooked up my Sharp Aquos LC-32D64U the other night and I had the blue audio box pop up. Mine was only in Mono and would not switch to Stereo...Well, Local cable company is of of Hi-Def boxes but I thought what if my Digital box is bad/old or has some sort of problem. I went down to comcast cable company switched to a different digitial box..came home, hooked it up and so far no blue audio box, plus now it shows that it's in stereo..good luck
Aug 30, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Sharp Aquos 32"
TV is under warranty. Get a tech to look at it. It could require a new IR sensor, a firmware upgrade or a system reset that only a tech can do called an Industry Initialization that is in the service mode only
Jun 24, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Audio Problems with Sharp Aquos T. V.
Just talked to a fellow at Audiotronics regarding Sharp Aquos.
This is a widespread problem with audio on their TV's, The tech. said there may be a full recall regarding this problem!!!
Nov 10, 2007 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Tv codes
YES throw that old sony remote away .
Jul 15, 2017 | Sharp Aquos LC-32D40U Television
Sharp Aquos Won't Power On
I have the same problem with my My LC-42D62U WHen i watch certain DVDs, (so far it happened on SAW III and RUNNING SCARED) during certain parts of those movies my TV will turn off and i cant turn it back on unless i unplug it and plug it back in. It only turns off on specific parts in the movie, i have no idea why...like the same exact parts...so i pretty much have to pause the movie with my remote once my TV turns off then when i power the TV on again just resume the movie and its fine...but if i rewind to that part again it'll power off again SAW III only had one part like that....but RUNNING SCARED had about 3-4
Apr 09, 2007 | Sharp Aquos LC-20B4U-S 20 in. LCD EDTV
Sharp Aquos LC-32G4U 32 in. HD-Ready LCD Television Logo
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
