Question about Compaq Presario X6000 Notebook
Laptop screen turns white
I have a compaq presario x6000 laptop. It seems like a lot of games I try to play, even though I met the specs for them, make my sceen turn completely white. I then have to manually restart it because it freezes. Is there anyway to stop this from happening?
  • 23 Answers
You can put your laptop on top of a icepack, cause your Graphics card is probably getting to hot. Thats why your screen turns white(probably only when gaming).
It is likely one of your fans is broken
Posted on Feb 24, 2009
I have a compaq presario x6000. every time i place the laptop on my bed and turn it on it cuts off within 5 minutes. but when I place it on a desk and turn it on it does not cut off. do not understand why...
The reason is because when the laptop is placed on the bed the cooling vents are blocked and the CPU overheats and shuts down. When the laptop os placed on a flat surface there is sufficient clearance between the bottom of the laptop and the flat surface of the desk to provide sufficient air circulation.
If you wish to use the laptop in bed then place the laptop on a flat surface and not let the bed clothes cover the laptop's cooling vents.
Aug 12, 2010 | Compaq Presario X6000 Notebook
I have Presario X6000 keyboard problems
it is doing so because of the faulty keyboard ..pls see the backspace button is stuck or not ..you can clean the keyboard by removing it ..
Thank You
Dec 07, 2009 | Compaq Presario X6000 Notebook
My compaq presario is not charging and I bought a new charger for it and it still wont stay on for longer than a min it just cuts off if I fiddle with the power cord a little the screen changes from a dim...
common problem,power cord gets pulled on accidently,causes plug inside computer to pull loose from the motherboard.will need to disassemble,then usually just touching the connections with a soldering iron to remelt them is enough to fix it,leave this to qualified tech.or if under warranty then send for repair hope this helps ,aloha from maui todd0708
Oct 22, 2009 | Compaq Presario X6000 Notebook
By connecting external display through hdmi port from my laptop, can i play demanding games!if yes then give some examples! specs....... compaq presario cq60 209TU, it has Intel(R) Graphic Media...
You wont be able to play a "demanding" game on any integrated graphics chip. While you may be able to start the game and load into it, it will be unplayable, or a painful experience at low resolution at best. I play World of warcraft, which isnt very taxing on a system, unless you put settings on ultra and high shadows. I can play it on my laptop with the same chipset that you have, but i am forced to play at the lowest resolution, and turn all settings to off/lowest, and it still only gives me 20ish frames per second. Ideally you would want to never dip below 30 to be playable As far as the HDMI port, that is just how the video signal is being sent after leaving the video card/chip. Even with the HDMI, your lack of dedicated graphics will be your limiting factor, and will not get any better by sending it through HDMI.
Sep 16, 2009 | Compaq Computers & Internet
Compaq Presario Laptop powers on but turns off in less than a second
Before I can help you ,I need the model number or the "service tag" number off the bottom of the computer.
Whenever you ask a tech question you must always begin with a model number / part number,etc. HP makes hundreds of different model Presario Laptops and each has it's own quirks. Only with a model number can an accurate diagnoses be made.
Aug 19, 2008 | Compaq Presario X6000 Notebook
Changed DVD drive in Compaq Presario X6000
Put a spare hard drive into the machine, installed XP onto it (the original OS for this laptop)...ran the HP bios update in XP and now it recognizes the DVD and is working OK.
May 14, 2008 | Compaq Presario X6000 Notebook
No screen on starting laptop
try to re-seat the memory, the memory might loose
Jan 20, 2008 | Compaq Presario X6000 Notebook
Boot problems
When you boot up your notebook, keep pressing F8; this will take you into safe mode. Look down the list for 'LAST KNOWN GOOD CONFIGURATION', and highlight and press enter. You notebook will then re-boot and hopefully start as normal, if not come back to this post.
Dec 17, 2006 | Compaq Presario X6000 Notebook
Compaq Presario X6000 Notebook Logo
408 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
