Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
I have a GE PDW 8200 Dishwasher and there is standing water in the bottom of the tube. Why is there standing water after a complete cycle?
  • 81 Answers
If it is older, the pump may not be draining the machine completely. The impellers, which is what acually moves the water could be clogged with yuck and could be cleaned if you can take the machine apart. If you call the repairman, he will likely replace the pump and motor.
Posted on Apr 24, 2009
My GE GSD4060Dss still has standing water
Make sure ur dishwasher is level if it isn't it will not drain all the water u can adjust the little legs on the bottom of dishwasher hope this helps
Apr 09, 2013 | GE GSD4060D Full Console Dishwasher with...
GE dishwasher won't drain or cycle
TRY TO UNPLUG THE UNIT FOR AN HOUR TO RESET THE ONLOAD SETTING THAT PROGRAMMED INTO IT..
KEEP ME UPDATED
Sep 28, 2008 | Dishwashers
Smelly water in the Dishwasher to coil if not
if you're not using the d.w. for a couple of days and water is still coming into the d.w. you have a bad water valve on the bottom left hand side of the d.w..the valve isn't closing all the way allowing water to enter the d.w. even when it's not in use.you can try shutting off the water valve under the sink and see if this stops the water from going into the dishwasher,if it does then you definetly know it's a bad water valve on the d.w.let me know what you find
Jul 24, 2010 | GE 24 in. PDW7880JSS Built-in Dishwasher
I have a GE mokel PDW 7300 dishwasher. I recently
Hello. Disconnect the dishwasher drain hose from the disposal and look into the disposal tube where you will see a plastic plug that you will need to knock out with a screwdriver and a hammer. Regards, J.
PS kindly rate my answer. Thank you. Joe
Feb 07, 2010 | Dishwashers
After cycle is complete my dishwasher doesn't fully drain water.
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
Concerning the Film(slimy looking substance).
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there, Try Dishwasher Magic.
Aug 20, 2009 | GE Nautilus 24" Built-in Dishwasher
Dishwasher not filling with water. It is not the float. GE PDW 8480 Dishwasher
It could be the fill valve or that the power is not getting to the fill valve. Pull the bottom panel and find where the water line hooks up to the valve. There should be an electrical connector on the valve. First, listen when the dishwasher is at the cycle where it should be calling for water, to see if youhear a click of the valve opening or water running in. If not, and you have a volt meter, pull the electircal connector and check for AC voltage across it when the dishwasher is off - it should be 0, and when the dishwasher normally would fill - it should be something above 0 - it might even be 110v. If the voltage is ok, but the valve is not working, you need to replace the vavle. If the voltage stays 0, then something is wrong in the timer/control circuitry.
Mar 13, 2009 | GE Dishwashers
GE Nautilus Drain Problem
I had the same problem (water remaining in the bottom) after the rinse cycle. FYI my GE Nautilus is 7-years old.
(1) I disconnected the drain tube at the garbage disposal unit (in the sink) and, using a wire coat hangar freed a 'plug' of sludge located at the spot where the drain tube clamps onto the garbage disposal. I blew into the drainage tube to further clear other 'plugs' I observed but could not reach w/the coat hangar.
(2) I unscrewed the Filter/Strainer on the inside (bottom) of the dishwasher; and further removed the inner filter; cleaned both out.
(3) Re-ran the dishwasher thru complete wash/rinse cycles (to check for leaks. There were none.
Finally, upon completion of the w/r cycles there will always be a small pool of water (residing in the filter area). However my dishes are clean and (after 7-years) checking the drain tube and filters was a breeze.
Hope this helps
Jul 04, 2008 | GE Nautilus 24" Built-in Dishwasher
Will not drain
the selenoyd is bad take front bottom cover off you will see the problem selenoyd with 2 wires conected to it
May 03, 2008 | GE 24 in. Profile PDW7800 Built-in...
Dishwasher not draining
try pressing the cancel/drain button.Do you hear water draining into sink freely?? if not i would disconnect drain undersink look for a clog right there first
Feb 22, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
487 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
