Question about Makita 7" Electronic Sander - Polisher 9227CX3
MAKITA 9227C? I AM LOOKING FOR A SWITCH FOR MY MAKITA 9227C?
    Novelist:
  • 152 Answers
Copy and paste this link in to your web browser search.
www.ereplacementparts.com
You should find it there.
Good luck...
Posted on Feb 24, 2009
3 Suggested Answers
joboo1
  • 257 Answers
SOURCE: a makita 9227C does not work
Hi, Unfortunately there is no external test, It has to be opened and troubleshot with a multimeter. Especially something with a variable speed controller, power cord, brushes, switches, ect. It could be several things. If you are technical enough to take it apart let us know we will try to help. Good Luck to you!
Posted on Feb 20, 2009
rowdy45176
  • 2176 Answers
SOURCE: Makita 7" 9227c I
the part number is 224517-1 and you should be able to find it at any hardware store that sells Makita tools or you can buy it online from "makitausa.com" they also have a service center locator that you can use to buy it locally. Let me know if you need more assistance.
Posted on Jun 19, 2011
Makita 9227c problem will only run upside down. I
...Jon sounds like broken cable in side the wire its self usually were the cable joins to the handle its self if u move the cable about u will b able to check this out wihlst running it .. i had this on mine i cut out the bad bit and re wired the it been fine now 1 1/2 years now
Sep 13, 2013 | Makita 7" 9227c Buffer Polisher Sander Kit...
Makita 9227c polisher started clicking and i smell smoke
sounds like you have a problem with the armature. To easily check UNPLUG tool and turn the spindle by hand and listen for the clicking. It sounds like it may be a raised commutator bar. You can also remove the brushes and look into the brush tube with a flashlight and look for a major discoloration of the bars or one that is raised.
Dec 18, 2011 | Makita 7" 9227c Buffer Polisher Sander Kit...
Makita 7" 9227c I
Jun 17, 2011 | Makita 7" 9227c Buffer Polisher Sander Kit...
I need an instruction manual
Here is a link. Look in the left hand sidebar for the user manual link. It downloads a so you will also need Acrobat Reader at the least.
Sep 27, 2010 | Makita 9227c Polisher Electronic Variable...
Cord wrapped around unit while polishing and shut down. cannot restart
possibly ripped the wires from switch or broke the wires in the cord itself. You can go to Makitatools.com for a breakdown on this tool, but would have to guess at the above.
Aug 31, 2010 | Makita 7" 9227c Buffer Polisher Sander Kit...
A makita 9227C does not work
Feb 20, 2009 | Makita 7" Electronic Sander - Polisher...
Makita 9227c stall
Hi hope to help
Have you tried this unplug the machine! then cut the cable about 6" from the machine then strip the machine and rewire the long length of cable back to the switch. The 6" that has been cut from the machine discard it.
The problem i used to get is where the cable is clamped in the handle the wire inside the insulation cracks so that when the machine is in one position is ok but then when is moved it goes off again.
It also could be the field coil (part of the motor) if it gets hot then cuts out the field could be braking down!!!
hope this helps.
Feb 29, 2008 | Makita 7" Electronic Sander - Polisher...
Makita 7" Electronic Sander - Polisher 9227CX3 Logo
181 people viewed this question
Top Makita Tools & Hardware - Others Experts
Jim Thurston
John Porter
Are you a Makita Tool and Hardware - Other Expert? Answer questions, earn points and help others
