Question about Hobart H600 Stand Mixer
HOBART H600 Leaks oil.
When the unit is running the mixer leaks oil out the Accessory attachment. I had a service tech from a local company look at it and he told me it cannot be fixed. Something about it is worn out and cannot be repaired. Is there anything I can do to stop the leaking? It is not bad, just really annoying. Oh and the oil level is full right at the line in the middle of the glass. THANK YOU IN ADVANCE FOR YOUR HELP.
  • tfcpgamble Feb 25, 2009
    I trust you are correct, but the tech who looked at it for me said there were no o-rings... I honestly thought that would be the problem myself then he told me no. Please help.
  • winterj Mar 17, 2009
    When looking at the attachment shaft facing down when you say screw did you mean bolt? If so do I need to worry about alot of oil coming out of the bottom? Also what bolt is it to drain the oil?
  • 640 Answers
There's an o-ring that goes around the attachment shaft,if you get a flashlight and look into the hole you will see a screw (left handed threads),remove screw and pull out shaft.Put the o-ring on and install the shaft and screw.
Posted on Feb 24, 2009
  • anthony james
    anthony james Mar 02, 2009
    Was he a hobart tech???I can give you the part #.Give me the exact model #,ml/spec#.
What oil should I use for the Hobart Mixer P660?
A good standard 90 wt oil is what is ok for the gearcase. This is an old email from a hobart service tech and they recomend a special oil ordered from them. So you can decide which you want to use. "EXXON SPARTAN EP-150 (6 oz)" in the M802 planetary. Hobart part #102973-13. This IS NOT a food grade oil. If you mixer is leaking you shouldhave it serviced. Service, parts , lubricants and information canbe obtained by contacting your local Hobartoffice in Pittsburgh@ (412) 788-5380. Steve Davis Field Engineer -
Sep 23, 2011 | Hobart P660 Stand Mixer
What oil can you use for the hobart h600
on the hobart h600 we use 120 oz of 140 weight gear oil.
Mar 04, 2011 | Hobart H600 Stand Mixer
What type of gear lube should I use for my Hobart H600 mixer?
Hi, btperduell
below is a copy of an e-mail from Horartservice.com. I searched the web forhours for the correct oil and could not find any info so I e-mailed Hobart. The Planetary is a different part from the transmission andthe sight glass on a M802 is for the oil in the transmission. The answer that Hobart gave is not an NSF oil. Ineeded the oil for the planetary section on a model M802. Even the directionssay that it is normal for a drop of oil to occasionally drip from the seal.That is where the dough hook attaches. I am in the process of researching the oil and Exxon / Mobildoes make a NSF version. I just need to find somewhere I can buy less then a 55-gallondrum. The above mixer only uses 6 ounces. Take care and stay safe Thank you Mike Hobart E-mail follows ============================================================== Mike, Hobartuses "EXXON SPARTAN EP-150 (6 oz)" in the M802 planetary. Hobart part #102973-13. This IS NOT a food grade oil. If you mixer is leaking you shouldhave it serviced. Service, parts , lubricants and information canbe obtained by contacting your local Hobartoffice in Pittsburgh@ (412) 788-5380. Steve Davis Field Engineer - Food Machines Product Service - Tech Support
b>
Jan 15, 2011 | Hobart HL600 Legacy Stand Mixer
About how many time you must change the oil.
For most applications once every two to three years should be fine.
Feb 02, 2010 | Hobart H600 Stand Mixer
Only have two phase power power company refuses to install three phase can i run my hobart h600-t mixer serial#31-1068-582 ml# 104385 with just two phase?
first thing, there is no 2 phase pwr. there are only single phase or three phase.you have 2 choices either you can convert mixer from 3phase to 1phase which will be expensive, or you can get a rotophase which will make 1phase pwr to 3phase pwr to run mixer, dont go with static phase inverter, only the rotophase inverter
Jan 19, 2010 | Hobart H600 Stand Mixer
Oil
the part# for the oil is102973-71, that can be bought @any hobart office in your area
Jan 13, 2010 | Hobart H600 Stand Mixer
How to change oil in 20 quart hobart mixer and the type of oil
on a a200 there is no oil. this mixer requiers grease. if mixer is leaking oil it is because the grease is broken down .you have to pull tpo cover off mixer remove trans. parts clean out old grease clean all trans. parts reassemble put top cover back on .then make sure mixer runs in all 3-speeds before putting 1.5 cans of -47grease back in grease can be bought @any hobart office
Dec 20, 2009 | Hobart H600 Stand Mixer
Moving our mixer
Offer a free pizza night to your biggest & strongest friends and as they walk in the door tell them they can eat all they want but, they have to move your mixer in return. Most of your larger, well known rental places should have what we call in the business as roller skates or appliance moving casters. They are a tripod type heavy duty caster that is placed under each corner of the mixer and can either be strapped or bolted down. You could also call a local commercial kitchen equip service & install company like Ecolab GCS, they move & install equipment. 800-822-2303
May 15, 2009 | Hobart H600 Stand Mixer
Hobart h600 60qt mixer leak oil
call me. 626-579-3580. Ill fix it.
Mar 25, 2008 | Hobart HL600 Legacy Stand Mixer
Hobart H600 Stand Mixer Logo
255 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
