Question about Kenmore 78812 / 78814 / 78819 Gas Kitchen Range
Kenmore range Can you still buy Kenmore ranges with black front and bisque top?
  • 8,197 Answers
Yes but you have to special order it.
Good Luck and Please Rate FixYa!
Posted on Feb 24, 2009
I'm getting a F-13 code in the display of my gas range and it will not let the oven work
Posted on Mar 09, 2010
  • barberjames Aug 30, 2011
    F-13 means the memory has been corrupted. You can try to unplug it for a few minutes then reapply power. If this does not clear the F-13, you will need a new EOC (electronic oven Control).
My kenmore oven model 316255311 want come on at all but the top of the stove works fine
I suspect the heating element might have burned out - does the broiler work? If "broil" works but "bake" doesn't, then replace the lower heating element.
Jul 31, 2014 | Ovens
Ihave a ge ceramic top stove,everytime I self clean the oven it stains in the front of the oven get worse.I have tried everything.My stove is bisque and the stains are an ugly yellow.
Use DeBruce Polish, we use DeBruce Polish on all of our stainless steel. DeBruce Polish also works on glass cook tops. We get DeBruce Polish at debrucepolish.com.
Jan 06, 2010 | KitchenAid KESC307 Electric Kitchen Range
Oven and oven display do not work or light up, but stove top and over light still works
Check if there both hot wires and the neutral are ok at the control board.
You should have 110-120v between each hot wire and neutral, and 220-240v between two hot wires. If power is ok, replace control board (the display unit is on the control board).
Part numbers:
White: 74009221
Black: 74009223
Bisque: 74009222
Repairclinic.com has pictures of the parts.
Oct 14, 2009 | Maytag MER5775Q Electric Kitchen Range
Hoow do I remove the top froma maytag range?
there should be two small screws on the corners thay are black so you really gotta look
once removed your top should flip up
Sep 30, 2009 | Maytag 30" Self-Cleaning Freestanding...
On my Kenmore Elite #106.56683501 the refrigerator door is loose
Depending on the model, and the color, here's your fix.
Stainless with stainless handles- you'll need a hex key. The tiny hole is on the inside of the handle, close to the center. Turn the key until it's tightened.
Stainless with black handle/white/bisque/black- push the door handle up. Careful not to scratch the finish! once the handle pops, pull it straight off. Take a phillips head screw driver, tighten the top screw A LITTLE BIT and then attach again. Insert screws on the door into the holes on the handle, slide down. (will need to be a little tough with it.)
Sep 03, 2009 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Almond or Bisque Color the same??
Your range is almond. The AA at the end of the model number is the color code for almond. Paint on a range may be affected by high heat be sure to use one that is tolerant of high heat. Almond is more yellow and bisque is more white, not the same color.
Jan 02, 2009 | KitchenAid KESC307 Electric Kitchen Range
WHIRLPOOL DUET HT FRONT LOADING WASHER
This is a strange problem. I work on these all day, and never have a problem getting these boards. Might want to try and calling local part houses for this part.
Oct 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 78812 / 78814 / 78819 Gas Kitchen Range Logo
342 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
