I have a Brothers MFC-490CW printer. On my computer task bar is an icon that says the printers OFFLINE. The control panel printer shows my Brothers printer as default printer, has the check mark, but shows "error". How can I get the Printer ONLINE instead of offline. How did it get to the OFFLINE status?
  • masenme01 Feb 24, 2009
    I tried Elke's solution, but it didn't work.
    I don't know how to change the port.
    I haven't tried Ajkill's solution but will try it.
  • 19,396 Answers
The printer can go offline for several reasons.
If the printer has not been set online by the user, or by a software, the printer goes online because it is not detected by the computer or because the printer is not functional.
Do the following:
  1. To start test the printer on a different USB port, and try using a different USB cable.
  2. Try unplugging the printer from power for two minutes, this will reset the printer.
  3. If still no luck , unplug printer USB and reinstall printer software from printer CD or from download (see instructions below). The software setup wizard will tell you when plug the printer to computer.
  4. If it still does not work after reinstalling software, test the printer on a different computer , the printer is faulty.
If you have lost the printer CD you can download driver from links below.
Follow instructions, start installation with printer unplugged from USB, and set the printer as default when asked.
If the printer is connected through a network cable instead of USB, then things are different.
Posted on Feb 24, 2009
    Guru:
  • 832 Answers
Hi there!
Pls go to Control Panel > Click Printers & Faxes > then view your Brother printer > right click > then check if its on as Default Printer > and then click the Use Printer Online.
by this option, you will turn it to Online Mode.
Hope it helps...
let me know...
  • Dennis Jambalos
    Dennis Jambalos Feb 24, 2009
    and try to check your USB cables that connect to your pc and printer. check the connections...and restart the printer and your pc...
    Sergeant:
  • 326 Answers
Go to click ----start>then click settings >then click printer and faxes .>  where the printer icon is mentioned.just right  click that printer icon the options will pop up.inthat option there will be 1 option also called printer off line.just click trhat option once it will become online.then the printer will work properly.keep the printer ON and connected to the pc/laptop while doing this.then only it will work.
  • 495 Answers
Use this commands,
open command prompt and type
net stop spooler and net start spooler.
    Genius:
  • 2,035 Answers
Right click and check if there are any print job in queue and delete them .
Select printer to online ...If this does not work then try this step..
Stop and then restart 'printer spooler' service from control panel>administrative tool>services.Then restart your pc.Your print job will get canceled. If this did not work uninstall and reinstall the printer drivers ..
Good luck...
  • 13,433 Answers
Right click on the printer in printers and faxes and select use printer online. if this doesn't work delete the printer and all the software related and then reinstall it. also use a diffrent usb port, restart maybe required.
HP laserJet printer 4100 is locked in idle or offline won't print
hi
· Step 1
Open the Start menu and click on the "Printers and Faxes" icon. This will open a window with a list of the printers currently set up on your computer.
· Step 2
Double-click on the icon of the printer you want to change to online. A pop-up window detailing all current print jobs will open.
· Step 3
Go to Printer in the menu bar of the pop-up window and uncheck "Use Printer Offline." This action will change the printer from offline to online.
Mac Instructions · Step 1
Open System Preferences by clicking on the icon in the Dock.
· Step 2
Go to the Print & Fax control panel under the Hardware category.
· Step 3
Select the printer you want to take online from the list on the left side of the screen. Then click on the "Open Print Queue" button.
· Step 4
Click on the "Resume Printer" button at the top of the queue window to change the printer from offline to online.
Jul 16, 2010 | Brother MFC 240C All-In-One InkJet Printer
My printer (MFC-490-CW)print status is offline change online
If you want to make it online, than make sure it is on and connected to your computer, Once you are sure about this than
Go to control panel than Printers and Faxes
There You need to right click on printer and than Use printer online
IT will Put you printer back online.
Nov 10, 2009 | Brother MFC 490cw Color Inkjet...
The printer shows up on my computer and says it is offline and for some reason i can not turn it back online
go to my printer and faxes right click your printer and then select "make printer online" this should do it make sure you turn on your printer, hope this helps
Oct 19, 2009 | Brother MFC 490cw Color Inkjet...
The Printer will not come online
Usualy you have to set up the wirless in the printer driver settings before you go wireless. I suggest pluging the printer in make sure the drivers are installed and before the disconnect choose these settings in your advanced printer driver settings (if it is wireless) and then disconnect and reboot.
Sep 29, 2009 | Brother MFC 490cw Color Inkjet...
Same Problem - Printer Says Offline
try reinstalling all drivers,, and cancell all prints. before.. take an test print from , control panel ---printer-- print a test page..
Sep 27, 2009 | Brother MFC-410CN All-In-One InkJet...
Brother mfc-440cn cannot get control center 3 to run with it
Verify that it is still installed.
Click the start button on the task bar to view the programs, then look for The Brother submenu and follow it to the icon representing the control Center 3 and press enter. It will activate and an icon will show on the task bar.
Hope it helps.
Jul 21, 2009 | Brother MultiFunction Center MFC-440CN...
My printer has recently gone offline. I have
Try and shut down the printer and turning it back on. Hold down the power key for 5 seconds or so. Then turn it back on to see if you have your connection showing on your task bar on the bottom of the screen. there should be a green halo around the printer. You may need to reboot your router too.
Jul 13, 2009 | Brother MFC 490cw Color Inkjet...
Brother mfc-490cw is offline
If you are running Vista and SNMP is turned off
1. Check to see if SNMP is turned off this is a component of Vista
a- Control Panel
b- Program and Features
c- Left side of screen you should see turn windows features on or off
d- Click on this a window box should open scroll down and see if SNMP feature is checked if it is then turn it off (unchecked) follow these steps
e- Under printers select Brother MFC-940CW printer right click
f- Select run as administrator
g- Select properties
h- Select ports
i- Select button configure ports
j- Under port settings uncheck enable SNMP
k- Click ok printer should be on line
l- To find MAC address for MAC filtering on router
m- Run the brother remote setup program and note the IP address
n- Run the command prompt as an administrator at the prompt type the following “apr –a” without the quotes and then hit return and note the physical address (MAC) for the above IP address you noted. Log on to your router and enter the MAC address from the step above and save.
o- Run the brother remote setup program again and change TCP/IP from “auto to static” please note you must have box checked at the top of the window edit network settings.
p- Restart the computer
Apr 07, 2009 | Brother MFC 490cw Color Inkjet...
24 people viewed this question
jasbo
jasbo
