Question about Eagle FishElite 320 GPS Receiver
Cuda 300 The unit works fine as long you are in neutral but, the second you shift into gear the unit shuts off. Its powered thru the ignition switch. I dont know what would cause this, let me know if you have an idea.
  • 1 more comment
  • kjg345 Feb 25, 2009
    Its an imboard mercruiser 140hp engine. I just replaced the batteries before the trip so they are new. Any other thoughts?
  • kjg345 Feb 26, 2009
    No it will not operate in gear at all.
    Novelist:
  • 113 Answers
Marine electronics should never be powered through an ignition switch. A sudden drop in voltage will cause it to shut off. If your boat is powered by a four stroke outboard it probably is not generating enough current to meet the demands of the engine and the electronics. Four stroke outboards generally have to run at high rpms to generate enough current to charge the battery. Old or poorly maintained batteries could also contribute to your problem.
Posted on Feb 24, 2009
  • Paul Hyde
    Paul Hyde Feb 25, 2009
    After you shift into gear and the unit shuts off, can you turn the unit on while it is still in gear? Putting the engine under load could be causing a temporary voltage drop which will cause most electronics to shut off. Since you have more than one battery, one should be designated as the starting battery and the other should be designated as the house battery. The starting battery should be the one you use just for starting the motor. No electronics should be attached to that battery via the ignition switch. Your electronics should be attached to the house battery via a direct feed from the battery to a power distribution buss. A battery isolator should be used along with a battery switch to make sure that the house battery gets charged by the engine but remains isolated from the starting battery. The switch allows you to use the house battery for starting if the the starting battery goes dead.
  • Paul Hyde
    Paul Hyde Feb 26, 2009
    Is this a new development or have you always had this problem?
    Since it only happens when your engine is in gear, that suggests it is a problem with the engine's charging system, not the fishfinder itself.
    It can only be one of two things, low voltage or electrical interference/noise from the charging system. I can't offer any more advice without actually getting on the boat. You should have a mechanic check out your alternator, voltage regulator (if there is one), and your battery wiring.
    Even if you can find and repair the problem with the charging system, you will probably find that you will have to move the Fishfinder off the ignition circuit.
I have a 2007 sportster that seems to skip neutral goin from first to second gear and from second to first both with the engine on and off. The gage N light doesnt even flash when passing through those...
Hey chris , i wouldnt worry about the neutral light coming on when your shifting thru the gears on acceleration. If your light isnt working or you missing neutral , try adjusting your clutch. Then if that isnt the probably find your neutral switch connector and ground the terminals together and your light should pop on . If not replace the switch. Im not sure what gauge you have there might be bulb for the neutral light also .
Mar 09, 2015 | Motorcycles
Honda 300 fourtrax
Shifting to neutral is a bit tricky until you get the hang of it. From first gear, shift only halfway. From second downshift only halfway. Don't do a full pull on the shifter just lightly. It takes some finesse and practice, but you will get it in no time.
Feb 08, 2014 | Honda Motorcycles
I HAVE A 1990 LS 400 WHEN TURNING KEY NO CRANKING AND HAVE GOOD BATTERY POWER. NO POWER TO STARTER WIRE ON STARTER SELINOD.WHAT CAN IT BE
It could be a bad ignition switch or bad starter wire from the starter switch, or the PNP is not adjusted correctly:
Here are instructions on how to remove and replace the PNP, but read over it to understand how to adjust:
Park/Neutral Safety Switch REMOVAL AND INSTALLATION ES300 1993-94 Models
  1. With the ignition switch in the LOCK position, disconnect the negative battery terminal. If equipped with an air bag system, wait at least 90 seconds or longer before performing any other work.
  2. Raise and safely support the vehicle.
  3. Disconnect the Park/Neutral switch connector.
  4. Remove the clip from the shift control cable.
  5. Remove the nut and control cable.
  6. Remove the bolts and pull out the Park/Neutral switch. To install:
  7. Install the Park/Neutral switch and loosely install the bolts.
  8. Adjust the switch and torque the bolts to 48 inch lbs. (5 Nm).
  9. Install the control shaft lever.
  10. Install the control shaft cable and torque the nut to 9 ft. lbs. (13 Nm). Fig. 1: The transaxle control shaft lever has a nut and washer to retain it - 1993-94 ES300 54617.gif
    Fig. 2: Removing the Park/Neutral switch - 1993-94 ES300 54618.gif
  11. Install the clip to the shift control cable.
  12. Lower the vehicle.
  13. Connect the negative battery cable.
  14. Make sure the vehicle will start only in the PARK or NEUTRAL position.
1995-97 Models Fig. 3: Aligning the neutral base line and groove - 1995-97 ES300 293716.gif
Fig. 4: Park/Neutral switch removal and installation - GS300, LS400, SC300 and SC400 300569.gif
Fig. 5: Park/Neutral switch adjustment - GS300, LS400, SC300 and SC400 300571.gif
  1. With the ignition switch OFF, disconnect the battery cables, negative terminal first. Allow 90 seconds to elapse before performing any other work.
  2. Apply the parking brake fully and block the rear wheels.
  3. Disconnect the electrical connector from the Park/Neutral position switch.
  4. Remove the locknut and disconnect the control cable from the manual shift lever.
  5. Remove the clip from the holding the control cable to the bracket.
  6. Remove the nut, washer and the manual shift lever from the manual valve shaft.
  7. Using a flat bladed tool, bend the lock washer back away from the nut.
  8. Remove the nut and lock washer from the Park/Neutral switch.
  9. Remove the two bolts and the Park/Neutral position switch. To install:
  10. Install the Park/Neutral position switch to the manual valve shaft. Leave the two bolts loose at this time.
  11. Install the lock washer and nut. Torque the nut to 61 inch lbs. (7 Nm).
  12. Using a flat bladed tool, bend the lock washer over the nut to secure the nut in place.
  13. Adjust the Park/Neutral as follows:
    1. Install the manual shift lever to the Park/Neutral switch and set the shift lever to the neutral ( N) position.
    2. Align the groove and the neutral basic line on the Park/Neutral switch.
    3. Hold the Park/Neutral switch in this position and tighten the two bolts to 48 inch lbs. (5 Nm).
  14. Install the manual shift lever with washer and nut.
  15. Install the control cable to the manual shift lever and install the nut. Torque the nut to 11 ft. lbs. (15 Nm).
  16. Install the control cable to the bracket by installing the clip.
  17. Connect the electrical connector to the Park/Neutral switch.
  18. Lower the vehicle and check the vehicles shifting positions.
  19. Connect the negative battery cable to the battery.
  20. Verify that the vehicle only starts in PARK or NEUTRAL.
  3. If necessary, remove the front exhaust pipe.
  4. Disconnect the neutral start switch connector.
  5. Remove the control shaft shift lever.
  6. Pry off the washer and remove the nut.
  7. Remove the bolt and pull out the neutral start switch. To install:
  8. Install the Park/Neutral switch and loosely install the bolt.
  9. Adjust the switch as follows:
    1. Loosen the neutral start switch bolt and place the shift lever in the N position.
    2. Align the groove and the neutral basic line.
    3. Hold in position and tighten the bolt to 9 ft. lbs. (13 Nm).
  10. Install the nut and washer.
  11. Install the control shaft shift lever.
  12. Connect the electrical connector.
  13. Install the front exhaust pipe. Torque the front nuts to 46 ft. lbs. (62 Nm). Torque the pipe support bracket to bolts to 32 ft. lbs. (43 Nm). Torque the No. 2 front exhaust pipe to the front exhaust pipe bolts to 32 ft. lbs. (43 Nm).
  14. Lower the vehicle.
  15. Connect the negative battery cable to the battery.
  16. Verify that the vehicle will only start in the N or P positions.
Maybe try to press the brake pedal and run the gear shift throughout the full range of gears while the car is on level ground, and retry the starter to see if there is a faulty PNP adjustment.
Try to start in Neutral not Park, and jiggle the gear shift back and forth to see if the PNP is not adjusted right.
Good luck on this repair.
Nov 09, 2010 | 1992 Lexus Ls 400
Cant push the button to put in gear
CHECK MAKE SURE BATTERY FULLY CHARGED IT HAS TO BE 12.5 VOLTS BEFORE THE BRAKE TRANSMISSION SHIFT INTERLOCK SOLENOID WORKS.IF BATTERY POWER GOOD CHECK BRAKE LIGHTS TO SEE IF BRAKE LIGHTS SWITCH IS WORKING.IF NO CHECK FUSE.IF FUSE GOOD BRAKE LIGHT SWITCH IS FAULTY. IT CONTROL THE BRAKE TRANSMISSION SHIFT SOLENOID ALSO THE NEUTRAL SAFETY SWITCH.IF FUSE AND BRAKE LIGHT SWITCH IS GOOD.YOUR PROBLEM COULD BE A FAULTY NEUTRAL SAFETY SWITCH OR BRAKE TRANSMISSION SHIFT SOLENOID FAULTY.
May 05, 2010 | 2001 Chevrolet Cavalier
My 1998 gs lexus 300, wont start i think it has something to do with the anti theft , help please!
Test the neutral safety switch.
Put your foot on the brake.
Move gear lever to "N"
Start the car
If it start then it's a defective neutral safety switch.
Shift to PARK and shut off engine.
Dec 11, 2009 | 1998 Lexus Gs 300
When I turn on my Eagle Cuda 300, it goes straight to silulator mode. When I turn off the simulator, it won't display the bottom and the depth reads way deeper that actual. I've tried changing settings,...
Try this, hard reset-FYI-This will delete saved data
1. Turn unit OFF-Press and hold the UP arrown key
2. Press power, unit will enter production keyboard test mode
3. Release the buttons
4. Press PWR/CLEAR key 7 times. (SYSTEM INFO SCREEN)
5. Press MENU/DOWN and unit will shut off
Hope this helps
Jul 12, 2009 | Eagle Cuda 242 Fishfinder
Hard shifting
Hello;
The age of your truck could indicate a common problem with the transmission. The ignition switch or the neutral safety switch could be the fault here. I lean more towards the ignition switch. When the trans, tach and speedo start to go haywire, the switch needs to be replaced.
Thanks for listing;
Rich
RPM Northwest
Jul 01, 2009 | 1997 GMC Sierra
99% of the time when i power unit up, it gets stuck on 54.8 feet
After testing everything out, I went out and bought the new Eagle Cuda 300 model. I hooked that up and made sure it worked, then tried the Cuda 242 unit on the new transducer. That did it, it worked fine. The problem was a bad transducer. Might have been that -30 deg weather last winter, I'm taking that off the boat this winter. Transducer cost about $50-$60, new Cuda 300 cost about $80.
Mar 22, 2009 | Eagle Cuda 242 Fishfinder
Eagle FishElite 320 GPS Receiver Logo
247 people viewed this question
Top Eagle GPS Experts
fordexpert
Computer Links
carl blood sr
Are you an Eagle GPS Expert? Answer questions, earn points and help others
