Question about Sony Playstation 3 (PS3) Console
AUDIO/ VIDEO RESET ..ADUDIO WORKING BUT STILL NO VIDEDO
DID THE AUDIO/VIDEO RESET FOR PS3 POWERED UP UNIT AND AUDIO WORKED BUT STILL NO VIDEO
    President:
  • 2,653 Answers
It's probably a GPU problem that only Sony will be able to fix. Still you can try a few simple things just to make sure.
Check out my common PS3 problem and repair guide.
http://rescuetechla.blogspot.com/
Please feel free to email me any other questions and please don't forget to rate!
Thanks!
RescueTechLA
Posted on Feb 24, 2009
Not getting outout from the PS3 to the TV
Hold the power button on PS3 to reset. When switching from hdmi or s video the ps3 needs to be reset to acknowledge the different video connection. Wont change anything on ur system just video feed. Lots of info on utube re this...fyi
Oct 03, 2012 | Sony Playstation 3 (PS3) Console
The playstation's audio and visual is not working
Hello,you will want to reset the video output.First make sure the unit is off,the yellow video and red and white audio cords are connected to the tv then press and hold down the power button till you hear the second beep.The unit is now reset.
Jan 15, 2011 | Sony Playstation 3 (PS3) Console
When PS3 is powered on the TV states either no input or audio only, blue screen nothing else.
Try this: Power off the ps3 (red light) then hold down the power button until you hear 2 beeps and let go. that should work, you just needed to reset the ps3 to work on your tv from HD to the AV cable or vice versa
Jan 05, 2011 | Sony Playstation 3 (PS3) Console
I just bought a ps3 and have never hooked up one before. I can't get it to hook up to the tv. I have hooked it up and it looks like it should be working but I don't get audio or video. I have tried it...
Step 1. Turn the PS3 off into standby (red light on)
Step 2. Press and hold the power button. It will beep as soon as you press it and then about 5 seconds later it will beep again. Let go of the power button when you hear this second beep.
Step 3. Wait for your PS3 to start.
This solution basically resets the video output back to standard definition. If this does not work then it is probably down to a faulty Graphics Processing Unit on the motherboard which is unfortunately terminal.
Hope this helps and thank you for using FixYa
Sep 06, 2010 | Sony Playstation 3 (PS3) Console
Just bought an older 80 gig ps3 from a pawn shop. I received hdmi, power audio and video cable, and 1 wireless controller with usb cord. when I power up the unit it says detected an hdmi source.. but I...
you need to plug the usb cord in to the ps3 and the controller. then press the ps button then it should work. if it does not then keep it plugged in and press the small reset button with a pin on the back of the controller and then repeat the first step.
Jun 08, 2010 | Sony Playstation 3 (PS3) Console
My ps3 does not work after i used the hdmi cable on my friends new t.v. when i came back to my house i put in back on my older tv to use the regular cable and the screen is just black. what could be wrong...
This is because the PS3 is trying to outpur in Digital... you have to reset the video output to work on your analog tv again... try this.
turn the unit off... if it is on hold the power button on the unit.
while the unit is off hold the power button untill it beeps, then go into the setup and reset the proper settings for your tv.
Jan 28, 2010 | Sony Playstation 3 (PS3) Console
Hi ......... I do have no audio from my PS3, every thing ealse works in correct order
Your video and audio settings have been incorrectly setup.
With the console in standby, hold the power button for about 5 seconds until you hear 2 beeps then let go, this resets the video settings of the PS3 and as you are using HDMI I presume, the audio settings are set by the HDMI wizard.
Now go in to the video settings and go through the wizard again and the PS3 will auto detect your HD and audio settings and set them up.
Thanks
Sep 01, 2009 | Sony Playstation 3 (PS3) Console
My ps3 wont power up
try powering the system up by HOLDING the on;off button , it will reset all your audio and video settings . then plug the system using the AV cables (default) .
else, you should take it to an assastance centre for hardware issues checking . can be a problem with your RAM or GPU units that makes the system unable to startup it's firmware .
Jul 27, 2009 | Sony Playstation 3 (PS3) Console
I TURN ON MY PS3
Try reseting the video following these steps:
Power off your PS3.
Turn on your PS3 by holding down the power button until you hear TWO beeps, then let go immediately.
This will reset it back to the default video settings.
If that doesn't work then you probably have a problem with the RSX (Video Chip) on the motherboard. You'll have to call Sony @ 1-800-345-SONY for service.
Feb 19, 2009 | Sony Playstation 3 (PS3) Console
No surround sound from my PS3 through the Onkyo 5100. Video OK
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
thanks.
Jan 24, 2009 | Onkyo Audio Players & Recorders
Sony Playstation 3 (PS3) Console Logo
26 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
