Question about ZT Group Cisnet PC Desktop
No sound from the computer
No sound is coming from the programs with audios. I removed a defective dvd drive, after replacing it after I thought I repaired it - to no avail.
  • sybelharvey Feb 24, 2009
    I DID REINSTALL THE DRIVER, YET THE SOUND IS NOT PROJECTING
    Genius:
  • 1,226 Answers
Hello.
REinstall all the driver of your computer. Every hardware there should be a software for it. so install that driver.
melnavz
Posted on Feb 24, 2009
  • Emelio Navaja
    Emelio Navaja Feb 25, 2009
    What ports did you use the back panel or in the front panel. did you try this both connection.
    try start, click run and the type: "devmgmt.msc" and then click OK.
    show me a picture of this dialog box.
    if you see some question mark or error in it. that's needed to install the driver.
Audio stopped working
It sounds like a computer problem. Every time you shut down, the audio chip reboots. Then when it warms up, it fails again. If it's still under warranty, I'd take it in for a chip replacement. If not, you may be SOL and have to replace the whole thing (or replace the faulty circuitboard or chip yourself..
Oct 02, 2017 | Subaru Outback Cars & Trucks
Realtek audio sound distorted when playing dvd
The dvd drive has a cable that goes to your sound card. The sound card plays the audio that comes out of the DVD drive. I would try a CD in the drive, alternately try another drive (if using a desktop computer), or try another sound card if you have one. Try another DVD player application (software), it could be a bad codec used for that player.
Sep 19, 2013 | Computers & Internet
Dvd has no sound.
hi check first if the problem is not with in the tv monitor. if the tv is not the problem check the connector coming from audio jack of the dvd player replace if defective.re solder audio out jack terminal at the board of dvd player. then make sure you have proper wiring of connector from audio out jack of dvd player going to audio input of tv monitor.thanks good luck.
Jun 16, 2011 | Toshiba Televison & Video
No sound at all
click start control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you will see options to update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
make sure that the cd-dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
or if these fail to resolve the problem
It could be a problem with the lens, you should try cleaning the lens, it's already gone bad there is no harm in trying If you take a little risk can solve . follow the instruction: Don't panic its very simply. 1. When running your pc , open the drawer.> 2. switch off the ac power 3. remove power cable & sata or pata cable 4. remove all the screw from the back side 5. press clip to open the font panel 6. reverse the cd/dvd rw 7. just remove the cover 8. clean the optical lance 9. use a little( not much )oil place on two steel shaft 10.cover all the equipment 11.now you can fit to your pc Ifit does the same problem please change the cd/dvd rw because the lance has defected
hope this helps
don
Feb 22, 2011 | Creative Labs Sound Blaster 4.1 Digital...
Hi, i have an asus laptop, the cd player wont play anything. its spinning and sounds as though its about to load in but nothing comes up not even an error!! itunes, realplayer or windows wont pull it...
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
hope this helps
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Dec 28, 2010 | ASUS CB-5216A (90D70001UAYZ) CD-RW/DVD-ROM...
ASUS DRW 1608 P3S will not load CD Rom computer program disks (it makes clicking sounds then green light goes off and nothing happens). It will play movies but there is no audio, however it will play CD's...
the lazer is not reading try cleaning it with a lazer disc cleaner. but remember most pc burners need replacing after just 2 yrs of work as there lazers burn out fast
hope this helps
Dec 28, 2010 | ASUS (GENEIRC DRW-1608P BLACK)...
No picture on computer
i think you have a bad mnitor
Jan 10, 2009 | Pinnacle Dazzle DVD Recorder
Not copying program
I updated my firmware from 1413 to 1416 found on avforums. This is for european units. I suggest you also complain to Toshiba Japan as there are known issues with the xs32. We all need a firmware update. See AVforums.
My unit will not recognise RAM discs anymore - even those that I had previously used.
Have you thought of replacing the DVD drive. See AVforums.
Sep 06, 2007 | Toshiba RD-XS32 DVD Recorder
Sound??!!
you need a dvd player program that is designed for dvd playback I use Cyberlink powerdvd to play dvd's on my pc you could look for another player out there but windows needs a codec to play dvds with sound. hope this solves your problem
Feb 16, 2007 | Pioneer DVR-111D (DVR111DBK) DVD RW Dual...
ZT Group Cisnet  PC Desktop Logo
Top ZT Group Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Kyocera HP Expert
Are you a ZT Group Computer and Internet Expert? Answer questions, earn points and help others
