Question about Intel S875WP1-E Server Board Motherboard
How to setup Wake on lan on this intel server
How to setup Wake on lan on the intel server motherboard S875WP1-E?
    Novelist:
  • 121 Answers
I am ArmyMason, I found a PDF file that might be the answer to your question. It talks about Wake on LAN and is specific to your server. I hope this helps resolve your issues.
http://www.etomic.org/manuals/motherboard_s875wp1.pdf
Thanks,
ArmyMason
Posted on Feb 24, 2009
Download e139761 manual a10383
An old Intel entry server motherboard, that uses a Slot 1 Intel processor,
http://www.ebay.com/itm/Intel-S875WP1-E-Entry-Server-Motherboard-E139761-D33025-Free-Shipping-/321064089691?pt=US_Server_Boards&hash=item4ac0e9385b
Over by the white IDE connector on the Right side of the motherboard, (Motherboard installed in computer case), there is a 9-pin Front Panel header.
It is the usual Intel 9-pin Front Panel header,
http://www.findlaptopdriver.com/n-alvorix-rs880-uatx-front-panel-motherboard/
Regards,
joecoolvette
May 01, 2013 | IBM (73P0595) Motherboard
Need the pin settings for scsi led header for intel sever board s875wp1-e
SCSI Hard Drive Activity LED Connector
The SCSI hard drive activity LED connector is a 1 x 2-pin connector that allows an add-in SCSI controller to use the same LED as the on-board IDE controller. For proper operation, this connector should be wired to the LED output of the add-in SCSI controller. The LED indicates when data is being read from, or written to, both the add-in SCSI controller and the IDE controller.
Test the 2 pins using a multi-meter to determine which is + and which is -. Nowhere in the manual does it say which is which.
Mar 11, 2011 | Intel S875WP1-E Server Board Motherboard
Intel motherboard drivers s875wp1
try on this page:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Server+Products&ProductLine=Intel%C2%AE+Server+Boards&ProductProduct=Intel%C2%AE+Entry+Server+Board+S875WP1-E
If this helps orsolves the issue, please rate it and give a testimonial for myresponse.
Feb 25, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
I've got an Intel server entry board S875WP1-E and I've set the BIOS how I need it. Now that the jumper's been put back to normal operation there seems to be no boot up action from the board. The...
While the power is off at the wall. remove the BIOS battery for about a min, then reinstall in the correct orientation. Power on at the wall socket and turn on. Was the board working before you flashed the BIOS?
It is possible that the BIOS is now currupt and therefore doesn't work go to www.badflash.com for more information.
They may be able to replace your BIOS chip.
Your timeous rating of this solution is much apperciated.
Thanks
Nov 01, 2010 | Intel Server Board S875WP1-E Motherboard
ASUS P5KL-AM Mother Board. Cannot clear RTC (& BIOS) Have followed instructions in the manual; - Disonnected onboard battery - changed position of jumper from 1-2 to 2-3 for over 5 -10 seconds.
you can set wake on lan setup, as long that your computer in connected to ac power and lan connection is working and can ping from the server.
Apr 10, 2010 | ASUS A8N-E Motherboard
How to clear bios with jumpers intel s875wp1-e mobo
From the manufacturer's web-site:
http://www.intel.com/support/motherboards/server/s875wp1-e/
download the "specifications" document for your motherboard.
Jan 02, 2010 | Intel Server Board S875WP1-E (S875WP1LX)...
I cannot get the 2 x 4500Gb SATA drives to show up in the BIOS of a intel s875wp1 board. It is an older board and had the RAID setup in place - I just want the 2 x SATA drives as normal so turned off the...
ATA/IDE has nothing to do with SATA. Ignore.
Try plugging in the drives into the non RAID sata ports on the motherboard. I think when you disable raid you also disable the raid ports. You should have another set of sata ports on the motherboard, probably a different colour.
Nov 26, 2009 | Intel S875WP1-E Server Board Motherboard
Intel S875WP1-E Server Board Motherboard Logo
202 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
