The bottom stitch is producting amount of thread from the bobbin. You can sew for awhile and then it starts up again.
Seems like the same problem I haad so I tried changing the needle looking for burrs or bent needle. maybe a piece of broken needle in the bobbin holder. or maybe the fabric requires a certain needle or the needle size is too big for the fabric you are using. or the machine needs cleaning I have started using canned air for this. and then if this fails then you should note the tension position and then try adjusting it one point at a time. always puting it back to where it was to start with good luck
two other things to try: 1) dig the bobbin out of the machine and take the black shuttle case out of the machine. Now look for a clump of lint, maybe hiding under the metal on the center left. Remove with tweezers if necessary. Go ahead and put one drop of machine oil in the middle before replacing the bobbin case. Now place the bobbin in the machine making sure the thread is rolling off the bobbin spool from the top and towards the left. If the thread is in the proper place the bobbin will turn counter-clockwise when pulled. 2) The spool of thread at the top of the machine must roll freely off the spool from the bottom towards the back of the machine. Your other things to consider is quality thread, a sharp
