Question about eMachines W4620 Keyboard
Emachines keyboard Q, A, Z keys not working
Was working and now these three letters are not.  sometimes makes a funny noise when it is plugged into the computer.   just notice all this today.
  • Anonymous Apr 01, 2009
    I have also same problem.
put key boqrd in french version
Posted on Feb 24, 2009
The "v" key is malfunctional. It does not input if I key it alone. The letter appears when I type a word with the letter v in it, but the spelling is wrong. It shows up after three letters or so. Sometimes...
Is this a laptop, phone, or a pc keyboard?
If it's a PC keyboard you might be able to pop the key out and clean under it. I have went as far to clean PC keyboards in the dishwasher. (low heat, no soap, no high temp dry... and then shake all excess water out... and let dry for a week or two.. before you plug it back up.) But do this at your own risk.
If this is a phone, and it is on a touch screen, then try going into settings and changing from samsung keyboard to default android keyboard.. or vice versa.
Sep 25, 2017 | Samsung Computers & Internet
My L button on my keyboard is showing three and so is some other letters they are showing numbers instead of letters
You probably have accidently turned on numlk which turns mjkluio789 into 0123456789
Most laptops require a two key combination of Fn (function key) and NumLk (numeric lock key) to toggle it off and on. Sometimes there is a seperate NumLk by itself as it is on most desktop keyboards.
If this doesn't do it let me know the make and model of your laptop and I'll see if I can help further.
Sep 10, 2010 | Dell Inspiron 8100 Notebook
Some times my keys work sometimes they dont and the ones that do seem to change out with the ones that dont work.i.e. i press the number two key yesterday it worked. Today i cant use the one-four keys. and...
You possibly have a flaky keyboard matrix, This is quite common. See if an external keyboard has same problem to rule out the PC. Otherwise I think you may have to replace the keyboard. A relatively simple task. It simply plugs in to a socket with a ribbon cable.
Feb 03, 2010 | Compaq Keyboard
LETTERS STICK ON keyBOArD.. have to us shift key to get most of the letters to work. Sometimes using the shift keydonnt work.
either buy a new keyboard or check the batteries and make sure they're not dead i lean towards the first option
Nov 06, 2009 | Labtec Wireless Desktop Keyboard/Mouse...
Toshiba qosmio E-10 noises keyboard and start up
Sound like you have a stuck key and the bip noise is the keyboard buffer pverloading.
If you can't unstick this key, you need a new keyboard.
Apr 13, 2009 | Toshiba QOSMIO E15-AV101 Notebook
maybe num-key is on.
hp's are realy funny sometimes they have so many hidden keys that do wonders, try the onscreen keyboard and see if that does the same.
Start/all programs / accessories / accessebility / on screen keyboard
Mar 02, 2009 | HP Compaq Presario V6000T Notebook
Keyboard doesn't work properly
Turn on your computer, go to the control panel, if you are using Windows XP, click on switch to classic control panel" and then go to Accessibility Options. There is a keyboard tab that the settings can be changed to help people with disabilities operate their keyboards better but if you hold down certian keys for more than a few seconds, Windows XP will activate these settings. Sounds like your son accidently turned on "FilterKeys" There is a check box on the Keyboard tab of Accessibility Options that turns off FilterKeys. If "Use FilterKeys" is checked, uncheck that box and then click "OK" and see if that helps.
Good Luck!
Nov 13, 2008 | E-Machines eMachines Desktop PC
Laptop problems.......................Sony Vaio PCG9L2P
Using a USB keyboard should pose no problem, just plug it in and it should work fine.
The other problems are difficult to diagnose without using tools to work on it.
First make sure you don't have a stuck key.
Checking whether the laptop keyboard/cable is seated correctly or removing it and reseating it may stop the problem.
If you do this be sure the laptop is not plugged in and the battery is removed.
I'm not familiar with sony laptops though most laptops if you remove the panel with the power button, sometimes held on by screws beneath the battery, you can remove two or three screws to remove the keyboard.
Doing this may solve your problem though I've never seen such a problem before. You either have a bad keyboard or motherboard.
I would guess the keyboard first since C does not work and you have to press Prt Scr/Print Screen to make it boot to stop a ringing noise. It kind of sounds like you may have a stuck key and since C does not work it would most likely be C that is stuck.
Sep 09, 2008 | Sony Computers & Internet
eMachines W4620 Keyboard  Logo
855 people viewed this question
Top eMachines Computers & Internet Experts
Michael Vincent Cruz
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
