Question about Samsung DLP HL-P5663W 56" TV
Samsung 56"TV lamp burned out
My Samsung 56" TV has apparently burned out another lamp, or the same one as before. Last time it cost $500 to replace it. I see I can get the lamp for $157. It that something that the consumer can replace themselves? The TV is about 6 years old. It it worth another $500?
The lamp replacement is a do it yourself fix.
Posted on Mar 03, 2009
Bought Samsung dlp h-l 5667w new in 2005. Replaced lamp, fan, and color wheel in 2008. Now lamp lights up and lamp indicator on front lights up, fans turn on, but tv picture will not show. After a few...
It time to replaced the tv projection lamp again,the tv projection lamp life span have ended.The tv projection lamp life span only last 2000 hrs.Average out like 1 1/2 or 2 years max for tv on watches 4 or 5 hrs of tv every days.
Jul 07, 2011 | Samsung HLR5667W 56" Rear Projection HDTV
Tv lost picture, when you shut it off, it turns back on with a line in picture and lamp light is flashing. Is this just the lamp or something else? I was told this is common on this tv
Lamp will last Appox 2 years with 6 hour a day use or 4000 hours. If it's the blub shop it online use TV model # Cost $75-$100 Not sure what to do call a TV tech.
Good Luck!
Oct 11, 2010 | Samsung DLP HL-P5663W 56" TV
Samsung 50 inch tv blew last night burning smell at time not getting any picture just a clicking sound
It sounds like either the lamp has blown or the ballast for the lamp has blown. You can call 1-800-samsung for nearest service center.
Feb 23, 2010 | Samsung DLP HL-P5663W 56" TV
Please Help. I have a 56" DLP Samsung and the lights just flash
Sounds like the lamp might be burned out. The Lamp should be replaced every couple years. If they are not replaced they will eventually burn out. Replacement is not that difficult and just requires a screwdriver. The lamp is located at the back of the DLP TV on the left side. The lamp can be purchased online from Samsung for about $130 dollars. You might be able to find a aftermarket one for less. Just use your telivision's model number located on the right side of the TV on sticker to cross reference the bulb that is needed or there might be a sticker on the back at the lamp housing that has the lamp part number. And make sure to spend the extra money and get the Lamp with the housing together. You can buy just the lamp for cheaper but that will require you to remove the old lamp from the housing and they are fragile. Much easier installation with the housing/lamp combo.
Jan 12, 2010 | Samsung DLP HL-P5663W 56" TV
TV screen goes black, 43 lites appear and TV shuts off after 2 to 3 hrs of operation. It will restart OK however. 56" set is 4 yrs old, orig lamp in TV
If you have never replaced the lamp it is most likely to be the problem.Most lamps last 2-3 years under normal use.
Nov 22, 2009 | Samsung DLP HL-P5663W 56" TV
TV turns off..lamp light flashs
I have one of these. It sounds like your projection light bulb has burned out & it needs to be replaced. Last time I checked (2 years ago), they were about $200. They are not hard to change if you are handy. Follow the directions, do NOT touch the bulb with your bare hands, use gloves or the oil from your hand will cause it to burn out prematurely. If you are not handy, call for a repair person.
May 05, 2009 | Samsung HLN567W 56" Rear Projection HDTV
TV won't stay on
Hello Fonzell!
Regarding the tv turning, my question is, do you hear a clicking sound? if so, it's most probable tio be your ballast, that might not have enough voltage to keep on with your lamp, and that's why it shuts off.
You could try replacing it and seeing if it resolves your issue, I believe they're running around 70 dlls..
have a great one ! :)
Apr 21, 2009 | Samsung DLP HL-P5663W 56" TV
TV Stopped turning on.
Apparently you can fix the issue by replacing a few faulty capacitors. I haven't done this yet, but plan to try it out next week.
http://www.bking01.com/Samsung_HLS5679.htm
http://www.avsforum.com/avs-vb/showpost.php?p=12845033&postcount=2060
Apr 03, 2009 | Samsung HL-S5679W 56" HDTV
Same problem
call him he might tell you, if he wants to take food off his table.
Apr 07, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung DLP HL-P5663W 56" TV Logo
141 people viewed this question
Henry  Thomas
Henry Thomas
