Question about Dell Lattitude D600 W/XP Pr Notebook
Dell d410 laptop won't charge battery charger doesn't like the ba
Dell D410 laptop works perfect with power supply and no battery, it works perfectly with a fully charged battery with no power supply, if I plug in the power supply when the battery is attached the power supply shuts down and won't charge the battery. I have tried different batteries and different power supplies same issue
Perry Eves
  • 2,653 Answers
There's a problem with the motherboard.
I would say try a bios update, but I believe it requires both battery and power adapter to be present before it will flash the rom.
The above probably won't work but it's always good to try the easy stuff first.
More than likely you'll just have to replace the board.
If you have any more questions, feel free to ask.
Posted on Feb 24, 2009
Dell Latitude D410 screen
Check your power settings as your system may have gone completely into sleep mode and even powered down the drive. It takes time for these to reappear.
Feb 07, 2018 | Dell Latitude D410 Notebook
Where can i find the process to change a D410 inverter
If the screen on your laptop is dimming or not working at all, the fault may lie in the Dell Latitude D410 Inverter --the device that powers the screen's backlight. Replacing an Dell Latitude D410 LCD inverter will require some finesse, but you do not need a technical background. If you are comfortable with opening up your laptop, then this is a do-it-yourself project.
1. Unplug your laptop and remove the battery pack.
2. Locate the rubber screw covers around your laptop screen. There are typically four, but some models may have more.
3. Remove the screw covers. Take care not to lose any. They pop off and, if you are not careful, could go flying.
4. Place your fingers between the front bezel (the plastic piece around the LCD screen) and the screen. Gently work your way around the screen to remove the front bezel and expose the screen assembly.
5. Remove the inverter from the screen assembly. It is held on by tape in most models. In some models the Dell Latitude D410 Inverter may be right at the bottom of the screen assembly, below the actual LCD. Other models have the Dell Latitude D410 LCD inverter behind the screen. To disassemble the screen, you will need to either unscrew the screen from its metal holder, or just lift the screen out to expose the inverter.
6. Disconnect the wires leading from the Dell Latitude D410 Inverter. One wire goes to the backlight, while the other goes to the video card.
7. Look on the back of the Dell Latitude D410 LCD inverter for a model number or serial number. Having this exact number will make it easier to order a replacement.
8. Connect the video wire and the backlight wire into the new inverter and affix it using the tape that held the original in place. If you do not have that tape anymore, or it has lost its adhesiveness, you can buy more from computer parts retailers.
9. Put the screen back in place if you need to, and snap the front bezel back on.
10. Screw the front bezel screws back in, and place the screw covers back in place.
Apr 07, 2011 | Dell Latitude D410 Notebook
I cant start my dell latitude d410, more precise i can start it in like 1 time out of 50 tries, regardless if i plug in battery or try just with ac power. it lites 1st led for main power, just flashes...
From what you describe, the boot failure is most likely a failing hard disk drive that is very slow to get up to speed. As far as the battery, since the D410 has been out of production for several years and the battery expectancy is about 30 months, the battery and HDD like both need replacement
Sep 24, 2010 | Dell Latitude D410 Notebook
I've just replaced the battery in my d410. It charges fully, monitor shows time left, but the computer shuts down with 30% charge bleft. At first I thought it was an overheating problem, but it happens...
Go to and click drivers and download. Select your type of product and download the latest BIOS for your system. Please follow the instructions carefully and DO NOT power down the system while the BIOS is being updated.
Jun 12, 2010 | Dell Latitude D410 Notebook
Here's a link to the service manual for the Dell Latitude D410:
This service manual describes in step-by-step how to disassemble/re-assemble this laptop model.
Laptop wont charge battery
its a comment fualt with laptops the micro switch that switches between charge and main power goes faulty on them, you could be acutally onto some thing here because ther eis alot of people with laptops that wont charge at all, and if they knew ur little sequence you got going on there maybe you could save their laptops been door stoppers.
Dec 01, 2009 | Dell Latitude D410 Notebook
I'm looking for instructions on how to change my Dell D410 laptop hinges. I have the hinges, just need to figure out how to get at them!
make sure you have a flat pliers then get a 1/2inc metallic plate preferable from a tin, cut into two hold with glue; get two strew to hold them in between to get a perfect bond.
Nov 16, 2009 | Dell Latitude D410 Notebook
No power..battery OK. Is there a fuse?
remove the battery and plug in the transformer and try to boot the computer.
Oct 21, 2009 | Dell Latitude D410 Notebook
Battery Problems
If the battery is over a year old, then odds are you need to replace the battery.
Sep 02, 2008 | Dell Latitude D410 Notebook
Dell Lattitude D600 W/XP Pr Notebook Logo
262 people viewed this question
Alun Cox
