Question about LG Refrigerators
Need manual for LG refrig? model LRDN22711TT/ manufactured in Mexico 2003. Bought used bottom freezer, seems to run fine but would like a manual to go with it.
fridgetech
  • 473 Answers
SOURCE: I NEED TO DOWNLOAD OR OBTAIN THE OWNERS MANUAL FOR SAMSUNG REFRIG./FREEZER MODEL RS 2630 WW
Go to http://www.samsungparts.com/search/search.asp?searchflag=byonemodel&searchkey=rs2630ww&modelid=294604.  Part # is OMRS2630WW and cost is $13.00.
Posted on Oct 26, 2007
Krazytech
  • 725 Answers
SOURCE: My LG GRL207QVJA fridge is
I would check your owners manual but most LG only have a 12 month warranty .
check your Express or Fast Freezing Function is not turn on.
then you most like have a Thermistor/ control problem.
let me know
Posted on Apr 05, 2008
  • 1073 Answers
SOURCE: The refrig is Model ET8HKXM003
the drain tube on the machine has frozen in the freezer section
remove the back panel and with a hair dryer thaw the drain tube
you will see an alluminum sheild with a 1/2 inch hole in the bottom of the shield this is where you want to direct the heat
it may take 20-30- mins to unfreeze it to make sure it is unfrozen pour som water into the valley of the sheild if it runs into the drain pan it is unthawed if it pools up keep unthawing
Posted on Apr 16, 2008
Maanita
  • 1142 Answers
SOURCE: fan runs constantly, freezer ice melting, bottom drawer in refrig
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
  • Posted on Mar 24, 2009
    • 64 Answers
    SOURCE: bottom freezer door opens when top door is open and then closed
    the door pops open because freezer and frig. are connected together via duct. air pressure builds when you swing ref door closed. apply a small amount of vasoline to the surface of the hinge side of both gaskets. this will aid in door closure. also the unit may be not level
    Posted on Jul 02, 2009
    My Lg bottom freezer refrigerator, model # LFC21770ST leaks constantly down in the bottom of the freezer and comes out onto the floor. Ice dams build up under the freezer drawer. I take out the ice, but it...
    The drain for the auto defrost water is plugged up somewhere.You will need to look at the very back and bottom inside the freezer to see if you can locate it and clean it out.Also you may have to pull the refrig out from the wall and try to get to it from the back.Hope this aleast gets you looking in the right direction.
    Jun 29, 2011 | LG Bottom Freezer Refrigerator w/...
    Bottom freezer seem to be fine top refrig.is warm?
    couple things to start off with is make sure the fan from freezer section is still blowing...may have to with door open hold down door switch as they sometimes stop running when you open door...if the fan is still running,then is the back wall of freezer frosted up you could have a defrost problem a defrost thermostat, or a heater issue... last make sure you have a clear passage from the freezer to the refrig such as the airflow gap or damper assembly which will be either a manually damper or a automatic damper//this is the flap that opens and closes usually by temperature to let air from freezer to refrigerator side....also make sure the unit all together is running properly the freezer is the last part to give you a problem as this is where the coolant actually starts then is pushed into refrigerator....few things for you to check repost if you have anymore questions....good luck
    Jan 05, 2011 | Amana ARB2217CSR Bottom Freezer...
    My model is ARB 1914 CC nine years old.
    your "damper vent door" located between the refrigerator and freezer compartments is frozen open or the cold adjustment contron in the refrige is bad and not powering the door as you change the temp set for the refrige and leaving it open,if the door is frozen from ice/frost just de-ice it with a hair dryer and then set the temp adjust and see if it opens and closes with any adjustment
    Apr 03, 2010 | Amana ABB1927DE Bottom Freezer...
    Refrig compartment does not cool on my new Kemore Frig.
    Check and make sure the fan in the freezer is running. if not possible bad fan. If fan is running, check to see if you have any ice built up on back freezer wall. Normally frost type ice. If so, you may possibly have a bad defrost bi-metal mounted in the freezer section. Next could be a defrost timer control. Model number usally will help more in getting it right.
    Feb 28, 2010 | Kenmore Refrigerators
    Amana refrig refrig wont get lower than 42 degrees
    that is defrost timer every 8 hrs it turns on heater to defrost evap coils, unless there is major ice behind freezer panel after 1 day which i doubt, that would not be problem ...im trying to go through steps i would take as tech at your house
    Jan 03, 2010 | Amana Easy Reach 18.1 cu. ft. Bottom...
    MANUAL
    Hi!
    You can try www.manualzone.com! You will need brand and model!
    Good luck, I hope this is helpful!!
    Mar 02, 2009 | LG 42LC2D 42 in. LCD HDTV
    LG GR727RB Top Freezer ok but bottom fridge is not cool
    Hi softwaredude with an LG GR-727R refrig. The occasional build up of water on the bottom of the fresh foods sections tells me that the refrig is going through it's defrost cycle, but that the defrost drain is plugged. If you take the back off the refrig. you will see a plastic tube about 1/2 inch diameter with a few ribs on it going from the top of the compressor compartment to the bottom, which is a defrost water holding / evaporating pan. Look to see if that tube is plugged. If not, it is plugged further up, most likely where the defrost water drains off the evaporator (that the coils behind the freezer wall that do all the cooling). Take that back panel off and use a hair dryer to melt all the frost off. The frost is blocking air flow from the freezer section to the fresh foods section, thus poor or no cooling in the FF section. You should be able to spot where the defrost water is suppose to drain. If the water is not draining out, use a turkey baster with hot water to flush out the drain.
    Dec 04, 2008 | LG LRBN20510WW Bottom Freezer Refrigerator
    Compressor not starting
    the thermostat is in the fridge and fridge runs at about +4-6degC. if temp in the garage is about that value, appliance will not want to turn on
    Dec 01, 2008 | Amana DRB1901C Bottom Freezer Refrigerator
    Amana Refrigerator
    Is fan in freezer running? If not it is bad and needs replacing. Please leave feedback.
    Nov 27, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
    The refrig is Model ET8HKXM003 and Serial # E54044751 Manufactured 10/05. It is type 18TFA. The Temp is currently set on 3 (normal). The freezer appears to be leaking down into the refrig as I find...
    Apr 16, 2008 | Refrigerators
    Refrigerators Logo
    129 people viewed this question
    Top LG Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
    Dan Webster
    Dan Webster
    Are you a LG Refrigerator Expert? Answer questions, earn points and help others
