Question about Vertex FNB-27SM, YAESU,FT-26,FT-76,FT-415,FT-416,FT-815,FT-816,FT-530, 12v 1500mAh NiMH 2-Way Radio
Yaesu FT-416 not Transmitting
At first it was not transmitting intermittently now when I press PTT all bars are lit but I cannot hit repeater and when someone does tone the repeater I have a very weak signal.
Check the connection going to the BNC antenna connector from the circuit board. I have seen this wire break before. KB9EKH
Posted on Aug 26, 2009
Yaesu 270 not transmitting nor receiving
Hi this can be down to many reasons, radio keypad locked, receive on tone squelch, set on "Relay" or "Repeater", or even radio failure. Without the radio I cannot help, but that may give you some ideas.
Feb 14, 2015 | Yaesu Ft-270r Vhf Ft 270r Ft 270 R
FT-90R Pl 136.5 does not open repeaters. Other radio detects the tone. Other PLs work.
check to see that your radio is set to encode or send the 136.5 tone and that it is not set to decode. Most ham repeaters do not transmit the tone so if your radio is set to decode 136.5 and the repeater is not transmitting the tone it will mute and you wont hear anything.
Jun 13, 2014 | Yaesu Radio Communications
How to turn beep off when transmitting
all the beep is for is so people can tell when you are done transmitting. There should be a push knob or button or just a plain old knob that has R.B. printed next to it . Turn it off.
Apr 12, 2014 | Yaesu FT-2900R 75 Watt 2 Meter VHF Mobile...
Yaesu ft 416 ver a2 need reset to get extended receive
You may find detailed instructions for this on www.mods.dk
Jul 03, 2011 | Vertex FNB-27SM,...
How do i get expanded freqs on my ft1802 yaesu tranceiver
The FT-1802 is a 50 watt 2 meter FM transceiver. It can transmit anywhere between 144 - 148 Mhz (the FM portion) of the 2 meter ham band. It can receive anywhere between 136 - 174 Mhz without any modifications. There is a modification to enable transmit "out of band" below:
http://www.ham.dmz.ro/yaesu/ft-1802-extended-transmit-modification.php
There are few details about the results of this mod - typically these provide for transmitting on frequencies outside (above, below or both) of the 2 meter ham band. Transmitting outside of the ham band without a proper license for the frequencies in the U.S. is a violation of FCC rules.
Sep 08, 2009 | Yaesu Radio Communications
FT-920: When the TUNER switch is pressed, the
Have you tired performing a general reset (see page 92 of your Operator's Manual). If you have tried this and still have had no luck, be sure that you have established a good ground to earth and that you are not getting a lot of RF back into your 920.
If you do not have a manual for your rig, one can be downloaded here http://www.download.n7tgb.net/yaesu/FT920/man_ft-920.pdf
You can also call Yaesu Tech Support for free/additional help at 714-827-7600, or join the Yahoo FT-920 User's Group at http://groups.yahoo.com/group/YaesuFT920/
Hope this helps......
Jun 25, 2009 | Yaesu Radio Communications
Yaesu ft-815
Double check that "TSQ" is not enabled. In the menus you can fine "SQL" and select the type of squelch. If you have "TSQ" selected you'll only hear signals from radios that a re transmitting the CTCSS tone selected.
Jan 21, 2009 | Vertex FNB-27SM,...
Yaesu ft 50r
The FT-50R is an extended receive, but dual band (UHF & VHF) amateur transceiver. It is capable of transmitting between approximately 144Mhz - 148Mhz VHF and 430Mhz - 450Mhz UHF.
Typically, the radio will provide an audible warning whenever attempting to operate outside of its intended range(s). The manual has a section on maximizing battery life, and can be downloaded below:
http://www.radioamateur.eu/schemi/FT50_user.pdf
May 25, 2008 | Yaesu NABC NABC LMR NICD BATTERY FNB-V47...
Radio Communications Logo
385 people viewed this question
Top Vertex Radio Communications Experts
Steve
eradiostore
eradiostore
k24674
Are you a Vertex Radio Communication Expert? Answer questions, earn points and help others
