Question about Denon Audio Players & Recorders
No rotation. Hi, I have a DP 315 F turnatble that has been sitting idle for MANY years. It hasn't been in service for about 10 years, but it was functioning perfectly back then. It has always been stored and transported properly (in the original box and packing material and with the locking screws in place). Unfortunately, after unpacking it this last time I find that it will not turn. The function buttons light up, the tone arm lifts and settles back on the post, but no rotation. I have no doubt that this problem stems from non-use, but I know nothing about electronics. Any suggestions? TIA! Tim
  • tjhartney Mar 01, 2009
    Hi rockdiary,
    Unfortunately, this is a direct drive turntable so no belt. I figure either the motor itself went south or somehow the electronics are not allwoing anj juice to get to the motor...problem is I have ne equipment for testing this.
    I tried spinning the turntable manually several times (it spins freely and smoothly btw) in hopes that if it was the motor just needing to be "awakened", but no luck...just dead as a doornail.
    Thanks for giving it a shot, bud!
    New Friend:
  • 27 Answers
The only thing i can think of is that the belt dries out after years of storage. kind of like tire rot. the tension or the grip in the belt is no longer there and there for no rotation. check "LP gear" for the replacement parts. do a search
Posted on Feb 27, 2009
50cc scooter repair
Hi, Anonymous if your bike has been idle for months or years and does not want to start you will have to deal with a few remedies:
1. Drain and flush fuel tank, google " how to clean a motorcycle gas tank" find a couple forums to view the different options available.
2. Remove your air cleaner and clean and re-oil per Mfg. specifications.
3. Remove the carburetor, disassemble and decontaminate with a carb dip or if you have EFI remove injectors and clean with carb spray and compressed air
4. Remove fuel valve and filter disassemble and clean as necessary, remove fuel lines and replace with new ones.
5. Replace spark plug with a new one and check for spark.
For more information about your question please visit the website below. Good luck and have a nice day.
Toyota 3A Engine start up after sitting for 10 years prep work Vespa Scooter starts after 10 years of sitting
Sep 11, 2013 | Beta Motorcycles
I'm restoring an 1989 s-10 blazer 4.3. Its been
could have bad battery ground cable or have starter solenoid and starter checked out at any auto parts stores.
Jun 16, 2013 | Cars & Trucks
EM 3500 Will start, then stalls after 30 minutes, starts again and continues to staff after 5 to 10 minutes. Oil is fine.
With regrets, I do not have any personal experience with generator troubleshooting. However, I have been informed by some people that have good experience with them that a generator needs to be run for a couple of hours every month to keep the system in proper order. Should a generator sit idle for ten months, the fuel can actually "shellac" inside the carburetor and lines. This will then travel to areas that will gum up - thus the necessity to drain the tank and carburetor completely.
Here is their advice:
http://powerequipment.honda.ca/parts-service/storage-tips
Your service person(s) may not be aware of the time the unit sits idle, and if they are aware - then they are not giving you straight facts (in my opinion). I would suggest contacting Honda customer service directly, and explain this situation to them - they will probably be more then happy to have a technician assist you properly. Contact the 'customer relations' number, and they will direct you from there. Here is the link:
http://honda.ca/contact_us
I am sorry I couldn't be of more help.
Dec 11, 2011 | Honda 3000 Watt Portable Generator
Hi! GE top load washer model number wwse5240 is leaving grease stains inside the machine after laundering and of course on clothes. Not sure how old this machine is.
Your transmission is leaking oil. It's probably 10 to 15 years old for the transmission to be leaking. It can be replaced but it's not a small job. Part 320 in this diagram is your transmission. http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5224109&diagram_id=22255027#d22255027
Jan 30, 2010 | GE WDSR2080D Top Load Washer
My dp-01 wont power up. it just sits idle on the reading song screen...is there anything i can do? or will i have to have it serviced? i have owned it for 4 years so no warranty.its just the basic unit no...
That looks like the same kind I have. They have a hard disk inside. You can try what I sometime do with laptops. Lift it up a few inches on one side, and let it drop on the table. Sometimes that helps. Do not rop it to high though!! only enough to kinda shake the harddrive a bit.
Nov 28, 2009 | Tascam DP01 All-In-One Recording Package...
Should i buy an 83' mustang 5.0 gt thats been sitting for 10 years in a garage and needs new belts?
car just sitting idle for ten years is bit not advisable to get.as you mentioned that it needs new belts that is ok.but if its confirmed that only belts needs replacement.and everything else is ok checked then its ok.you can go for it.as mostly car sitting idle for ten years has lots of rust and parts replacement problem later.
Jul 12, 2009 | 1984 Ford Mustang
Glowing exhaust header yamaha wr250f
It won't be valve timing or clearance. The fuel/air mix would be the culprit. Clean the carburetor with special attention to the idle circuit. Remount the carb with new manifold gaskets. A manifold air leak will mess up the mixture. Also, get a new spark plug one heat range colder than stock. Hope this helps out!
Please rate this solution. Thanks!
Apr 07, 2009 | 2003 Yamaha WR 250 F
125 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Dennis McCollum
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
