Was welding fine until the tip plugged. Wire would not feed and was tripping welder when feed trigger pressed. I thought maybe it was over heated so I let it cool down. Plugged it in this pm and it trips the 30 amp wall breaker immediately with the welder switch turned off?
SOURCE: I have a Hobart 135 Handler wire feed welder that
Get a volt meter, go to ohms setting , check transformer to ground for low to zero ohms reading. also look closely at transformer windings for foreign objects in between them, never know what you my find. If transformer is shorted to ground probably time to say some nice words over it before burial. Also just for kicks try a new gun on it, (there is a reason i'm asking you to do(this) see if you can find someone that has spare. A good honest repair shop would probably be reasonable if all else fails. to a least let you know if the transformers a problem. good luck
Signed
Former Miller Certified Tech.
