Question about Hobart ET27 4-Slice Toaster
How do you replace the elements in a Hobart 4 slot toaster? I took off the bottom but there must be something I am missing. It's awfully small in there to manuever. There has to be a trick. Please share.
    Scholar:
  • 109 Answers
No Tricks. The elements are loaded and removed from the top.
DISCONNECT THE POWER CORD
Remove the crumb dtrawers, they are handy to put the parts on so the don't roll away.Remove the temperature knob after releasing the set screw, remove the lever knob after removing the pivot screw. Remove the 3 front and 4 rear cover screws with a philips driver. note the length of the screws from the locations.
Locate the element to change, disconnect the connections at front and back on the top of the element. With a small flat bladed screw driver, open the crimp tabs on each end of the bread guides and lift up. They come out of alignment holes in the lower frame. Replace the element/s, with the correct voltage replacement. 208 and 240 elements are different numbers. Reassemble in reverse order. Be carefull not to catch the element with the bread guard wires. It's common to see a bit of smoke during burnin of new elements for a short time.
Posted on Aug 08, 2009
Hobart toaster et27 one side does not work. Tested all elements, all showing resistance. 125V at all terminals when control is down. I am stumped
Check for corrosion at the contact points.
I suggest not "fiddle" with a toaster and instead replace it for safety reasons.
Nov 28, 2017 | Hobart Kitchen Appliances - Others
My ET-26 Hobart toaster will not cook 2 slices on either side unless both handles are pushed down !
That is strange, both sides are completely seperate electrically. Problems I have seen in the past are that some Hobart toasters are bun toasters and only toast one side of the bread. If that was the case you could look down into the toaster and see that only one side of each slot has a heating element. The other common problem is when someone changes a 220 volt to a 110 volt toaster by running the elements in series instead of paralle. at the terminal block. I am stumped on this one. I can't think of a fix for that. I am going to look at the wiring diagram again. If your question is still up, I will get back to you.
Sep 20, 2010 | Hobart ET26 – 4-Slice Bread Toaster
One side of my dualit 4 slot toaster is not working can you help?
Inside your toaster there are eight heating element plates six in the center and one in left end and one in right end.
Just switch on the toaster without any bread at maximum time and visualy inspect to see which side is becoming red and which not. Then you need to replace the element plates you see that they don't become red.
Remember that the six in center are the same called "CENTER" and the other two on ends are the same called "END"
They can easily be removed if you remove the bottom panel.
Good Luck
Jan 19, 2010 | Dualit CBF4M Stainless Steel Buffet...
All slots not heating
Remember that the two in center are the same called "CENTER" and the other two on ends are the same called "END"
Good Luck
Nov 16, 2009 | Dualit Vario 4 Slices Toaster
The toast gets done on one side and not the other
No way to replace it your Dualit toaster is a toaster for life you just need to replace some element plates and this is normal every some years. My Dualit toaster is 18 years old I have replace a couple of times the element but is always working perfect and with st. steel finish look perfectly new and impresive.
Good Luck
Jul 12, 2009 | Dualit CTS4E 4-Slice Toaster
The heating element doesn't work in two of the slots.
If its a Dualit model then you should be able to get it repaired. Generally replacing parts on a Dualit is not easy but spares are usually available thanks to the fact that its one of the most well known commercial toasters on the market. Google and see if there's a repairer in your area.
Apr 05, 2009 | Dualit CTS4E 4-Slice Toaster
One side will not heat
check your timer board at the back of unit
Nov 27, 2008 | Hobart ET27 4-Slice Toaster
Only toast one side of the bread
The other side that isn't toasting has an open element. Usually, the good side will burn twice as hot, and may have stressed that element. You might want to replace both in that slot. make sure you check the voltage rating plate. 208 and 240 volt toasters use different elements.
I just posted the procedure to replace elements, in a similar post here.
Oct 12, 2007 | Hobart ET27 4-Slice Toaster
Hobart ET27 4-Slice Toaster Logo
202 people viewed this question
Top Hobart Kitchen Appliances - Others Experts
Treefrog15
Treefrog15
atva20
Level 1 Expert
Colin Stickland
Colin Stickland
Are you a Hobart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
