Question about Coleman Powermate Premium Plus 6250W Portable Generator
Generator produces no power
The motor runs fine but produces no power.
  • 3 more comments
  • ajones2664 Feb 24, 2009
    Thanks for your interest. The problem has been solved. The generator needed to be flashed. Thanks again.
  • Jerry Rushing Sr.
    Jerry Rushing Sr. Mar 15, 2009
    How do you make it flash?
  • kibob Mar 27, 2009
    Generator will start but does not produce power.
  • Do you use the generator alot ? or has it been packed away ?
  • Anonymous Mar 18, 2014
    motor run but generator not producing wattage
  • 169 Answers
Glad to hear it was easy :-)
Here is a link to my trouble shoot solution so that this will get marked as solved.
Posted on Mar 04, 2009
U How do you fix a Honda generator 1000i engine runs but no power at 120 out let.
if the motor engine is working and no power output then you need to check is there any power out from the generator motor directly (not in the power out put box I hope you already checked in there) generator motor coils could have busted due to over loads. so even the engine is rotating the generator it can't produce any volts.
Jul 31, 2015 | Honda Electrical Supplies
Generator producing 104 volt out of receptacles
need to increase rpm to 3400 if still then the high pot need adjustment which is in the regulator assy
Dec 21, 2013 | Electrical Supplies
I have an onan marquis 5500 watt RV generator that runs fine ,but won't generate.
Call Onan and tell them the Inverter Board is bad. If you're not producing AC Power, have them send you a new board or warranty the entire genset. It's unusual for Onan products to go out like that, but not unlikely that this is the source of the problem.
Typically, the DC motor outputs at 12 volts, so the leads going in to the inverter are only going to be a ground and a positive lead. Should be very simple to replace. Worst case scenario is you can hook an external inverter up to the DC leads on the front of that generator. Might not get the full 5.5kw from the system, but you'll be able to produce some power.
Oct 16, 2013 | RTO Cummins Onan HomeSite Power 5500
Ex 5000 sx generator, no power
Hello dear, would you consider buying a new generator? Generator Diesel Generator Cummins Generator Volvo Generator Perkins...
If you can start your generator normally, you can analyze the reasons through the following article:
Why Diesel Generator Fail to Start
Simple Ways to Deal with Diesel Generator Failure
Hope it works for you.
Sep 21, 2017 | Honda Electrical Supplies
Starts fine...no juice....sat for 10 years in the box...started using it 3 weeks ago...worked fine until yesterday....starts...runs..no juice...no circuit breakers blown...what's up?
Colemans were known for losing what is known as "residual magnetism", especially when sitting for long periods of time without use. This residual magnetism is necessary for exciting the field to produce electricity. Here is what you can try: Plug a 110v drill into one of the 110 outlets. While the engine/generator is running, with an open hand (not fingers wrapped around it) spin the chuck while holding the drill trigger in the run position. Many times this small amount of current that will be produced by spinning the drill motor will restore the residual magnetism and excite the field. Keep in mind that if this works, the drill motor will begin to spin immediately since it is plugged into the outlet. Hope this helps.
Mar 04, 2011 | Coleman Powermate Powermate 5000W...
Homelite generator model # LR 5500 not producing electricity
I have the same unit and same problem.
I have lost my owners manual. Did you figure out what needs to be done to correct the no output issue.
Mar 07, 2010 | Electrical Supplies
My coleman powermate 6250 generator just stopped producing electricity. It was running all day. Motor still runs just no juice.
check the reset-- if power to reset line, switch bad if no power -check feed out from generator if no out put then possible internal problem --winding or short
Mar 02, 2010 | Coleman Powermate Premium Plus 6250W...
5500 generator stopped producing eletric after
First check with the dealer and see if it is still under warranty. If it is not, make sure nothing is blocking the air flow around where the control modules are located. This could cause the voltage regulator and other electronic parts to overheat. Next check the brushes and make sure they are free of any dust or build up preventing them from making contact.
If everything is OK the next thing I would do is change the voltage regulator.
Nov 17, 2009 | Coleman Powermate Powermate 5000W...
Coleman 5KW gen motor shuts down when A/C switch turned on
Sounds like a problem with the wiring of the outlets after the circuit breaksr. Take apart the outlet box and have a look for burned or broken wires, melted outlets, and/or small critters stuck in the wiring.
I recently had to repair a generator that had its voltage regulator taken out by a frog!
Regards,
Carl
Feb 28, 2009 | Coleman Powermate Premium Plus 6250W...
Coleman Powermate Premium Plus 6250W Portable Generator Logo
587 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Phil Walker
Phil Walker
Tim Garcia
Tim Garcia
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
