Question about ASUS P4S800-MX Motherboard
My dos command & reg edit was disabled by adminitrator,how to solve this problem?
    Novelist:
  • 121 Answers
First I must ask who is the Administrator of your computer? If this belongs to you then I would suggest making a boot disk with a password cracker on it. Without being able to access Regedit you can't modify the CMD Prompt or anything else. So the only solution is to ask who ever has the Admin password to up your rights or for you to wipe the sam password for the admin account. I don't have a link for the software I use, but you could try out this one. http://www.rixler.com/windows-password-recovery-bootdisk.htm Once you wipe the password for the Admin account go in and raise the rights on your account. That way if the Admin account gets a new password you will still have elevated rights to your account.
Thanks
ArmyMason.
Posted on Feb 24, 2009
Bootmgr is missing on my computer and I don't know how to fix it
You will need a operatingsystem disk or a repair disk to fix it. Insert it in the drive then bootfrom it. You want to get to a dos command prompt (black screen with whitelettering) and type the following commands. Press ENTER after eachcommand.
bootrec.exe /fixmbr
bootrec.exe /fixboot
bootrec.exe /rebuildbcd
Reboot and see if the problem is solved. If not get back to the doscommand prompt and run the check disk utility.Torun the check disk utility you will need a repair disc or a operating systemdisc. Put the disc in the cd drive and boot from it. You want toget to the Dos Command Prompt (Black screen with white letters) and type thefollowing command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
Jun 01, 2012 | Computers & Internet
Biostar m7ncd pro freezes up
Run the check disk utility.
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
May 29, 2012 | Computers & Internet
My mercury PI945GCM motherboard gets stuck on the mercury logo itself. I cant enter BIOS also. Plz help
Try running the check disk utility.
May 25, 2012 | Mercury Computers & Internet
Computer shuts down while loading windows
Try the Check Disk Utility.
May 23, 2012 | EliteGroup Computers & Internet
How ca i format the pc
Try running the check disk utility instead of reformatting and reloading everything.
If all fails and you want to reformat as your say, just reinstall windows, it will reformat and delete everything for you.
May 21, 2012 | IBM (74P1644) Motherboard
CMOS checksum error
Try running the Check Disk Utility.
May 15, 2012 | Foxconn FC-G31MXP-K Motherboard
Check point (VMGR) error in boot screen
Run the Check Disk Utility.
May 10, 2012 | Dell OPTIPLEX GX60 Motherboard
Where i can find the controls like command button and how can i find its code ?
dos commands
click start run you have to type cmd then type something in then press enter eg: regedit will take you into the registry or chkdsk/f is the check disk utility this is called DOS there are lots of dos commands to fix a computer
in xp
hope this helps
Mar 09, 2011 | Computers & Internet
For Dos Command
Download a program called Belarc Advisor. There isn't a command that will allow you get the system board number from the DOS prompt without running a 3rd party application.
Jul 11, 2009 | Computers & Internet
Hi i'm A ojt technician of computer and I encomtered the problem of computer the problem is system halted... what is the possible deffect of that problem. . .
it cannot find COMMAND.COM
Explanation: When you boot up DOS, you are placed at what is commonly called the "C: prompt", where you can type commands or run programs. The part of DOS that reads what you type and executes commands is called the command interpreter, which is stored in the file "COMMAND.COM". This interpreter is loaded when you start the system or when you start an MS-DOS session under Windows 95, and is also reloaded in some cases when you finish running a program. In this case, the system was unable to find COMMAND.COM and therefore halted the system.
try this
  • Make sure that COMMAND.COM is in the C:\ root directory, or if it somewhere else, that there is a line in AUTOEXEC.BAT that reads "COMSPEC=X:\PATH" where "X:\PATH" is wherever COMMAND.COM resides.
  • Edit the PATH command in your AUTOEXEC.BAT file, if you are trying to run a command in another directory that should be accessible from anywhere.
please send me a feed back if this works out thnk you.
Dec 12, 2008 | ASUS A7N8X-E Deluxe Motherboard
ASUS P4S800-MX Motherboard Logo
202 people viewed this question
Top ASUS Computers & Internet Experts
Brian Sullivan
Brian Sullivan
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
