Question about Porter Cable 8901 Router
Rowdy45176: the pin i am talking about is the pin that locks the shaft so you can change bits. i have mounted the router in a table and without the lock on the shaft i have to get under the table and wiggle the offset wrench to hold back on the nut that locks the bit.
  • Matthew Parker
    Matthew Parker Apr 23, 2012
    Grab the end of lock pin (where you push) with a pair of vise grips. gently tap either side of the grips with a hammer until the retainer comes out. Tap back in with a socket that fits just over the pin.
  • 2,176 Answers
OK looked at a breakdown with 400 mag, and it looks like the pin is held in place by a long lever that goes down the side of the motor, that lever has a cover over it with 2 screws to hold it in place. Look at the side and see if it if what I am describing and then the pin has a piece over it and a spring to push it away from the shaft. Let me know if this is not correct and I will call Porter Cable for you and get them involved
Posted on Feb 25, 2009
How do you put a router bit in a Makita router model 3612BR
Inserting the bit should be the same on all versions of the Makita 3612 router. It does depend on the bit size. Press the shaft lock to keep the shaft from turning. I think the lock is close to the handle on one side of the router when you hold the router with the bit/collet up. For small shaft bits, insert the appropriate collet sleeve into the collet cone. Then insert the bit completely into the sleeve. For larger shaft bits, insert the bit completely into the cone. Use the wrench to tighten the collet nut securely. Unlock the shaft lock. Do not over-tighten or leave the bit loose in the collet cone/sleeve. Over-tightening can break the collet cone. Leaving it loose can result in the bit flying out of the collet cone. Either way, injuries can occur. To remove a bit, loosen the collet nut and then remove the bit (or bit and collet sleeve).
The manual is available on the product page: https://www.makitatools.com/products/details/3612 . The direct link to the manual is https://cdn.makitatools.com/apps/cms/doc/prod/361/df12a409-2bd0-48c3-aa38-d635a480a76e_3612_IM.pdf . See page 8.
I hope this helps.
Jul 11, 2017 | Makita Drills
ThanksI had to remove the Latch arm shaft assembly. When trying to reinstall, I find that it is hard to see the engagement area, the shaft must engage the arm lock screw and at the same time fit into
Woah!
Your comment here is posted in isolation from any previous comments you made and there is no way to associate them.
As a result, I don't know what you are talking about.
Oct 08, 2014 | Saws
I have a Freud 2000E plunge router. It is about 10 years old, but I've never changed the router bit I have in it before. Now I want to remove the bit I have in, but cannot turn the bolt to remove it....
Hello Davis gr,My name is larry I am an auth Freud service tech.
The first thing to do before you attempt any repairs is of course to unplug.In the full plunged position make sure the router is locked in position out of the table on its side.You twist to loosen the bit nut
and tap gently on the side of the bit with a rubber hammer
turning it slowly and it will come loose to remove.
second--If the router will not spring up to its top position it is because
the posts that are spring loaded are dry.again you must remove the router from the table clean the postd with a dry cloth and while still locked lubricate with lite oil using a clean cloth the metel posts.
after that with the same rubber hammer tap the base plate and it will come loose
I hope this is some help
Larry in Canada larry_boccioletti@yahoo.ca
Sep 11, 2011 | Freud FT3000VCE Router
How does one change the bit in the B & D router?
Nearly all routers have a locking pin that you depress to lock the rotor then you should have a set of wrenches that came with the unit to loosen the mandrel and release the bit. Then just reverse the process to install the new bit.
Jun 25, 2011 | Black & Decker 11A 1 Router
I have Model RF1101 Router mounted in a router table and I'm trying to cut a dovetail groove in a workpiece. I first use a straight bit with 2 flutes to hog out a 1/4" deep groove. For some reason...
I've had this problem with off shore bits, where the machineing on the shaft is slightly under spec. The bit wobbles out of the chuck because it can't be tightened enough. Try a different bit.
Feb 02, 2011 | Saws
Aguired a black and decker model 7600 router tool. Did not come with instruction manual. I cannot determine how to change the bits.
They don't have an instruction manual online at the Black and Decker support site, but if you want a look at the exploded diagram, it's here.
Basically there's a collet nut that gets tightened down to hold the bit in place. You've got to loosen it up and you'll be able to pop bits in and out. You've got to have some way to lock the shaft while you're doing this though.
Most modern routers have a spring loaded shaft lock button. While you're holding it in, start turning the collet. When the shaft gets to the point where there's a little hole for the spring lock, you'll probably hear a little click, and the shaft will be locked so you can loosen the collet. If you take your finger off the shaft lock, it pops right back out again so hold it down while you're loosening and tightening.
If you don't see a shaft lock button, you may have a second hex nut at the base and with two wrenches, you can hold the hex nut and turn the collet loose that way.
If this answer was helpful, please give it a vote. Thanks.
Jun 15, 2010 | Black & Decker Tools & Hardware - Others
How do I mount the router to the B&D Router table?
If you are doing freehand routing, you need bits with a ball bearing on the end to track the un-machined edge of the work. Other complicated designs require some form of 'jig' or fence that controls the position of the bit. If you didn't receive an owner's manual with your bequest, it would be helpful to find some good how-to manuals at specialty wood-working stores which also give you ideas for projects, making jigs, using a router table, and other useful information. Use a decent respirator and safety glasses when routing as they produce prodigious amounts of fine wood dust. Don't smoke while using the router as the dust in the air is quite explosive if ignited. The pictures in these manuals show how the router is mounted in the table and how to use it properly. The bits that you use must be very sharp to make clean cuts without also making smoke. Hope you find this useful!
Dec 21, 2009 | Black & Decker 11A 1 Router
How to change the router bit on my router table 925479 by sears
raise router bit until collet nut is acessable lock rotar use open end wrench on nut turncounter clock wise. you might have to use a second wrench on rotar.
Oct 19, 2009 | Craftsman Tools & Hardware - Others
How do i change the bit on router?
On my older Sears router there is a lever on the base near the collet nut that you slide to engage the motor shaft to lock the motor shaft for bit changes. On newer models you may have a button or different mechanism to lock the shaft. After the shaft is locked you can use a small wrench to loosen the collet nut, usually by turning it counter-clockwise (viewed from the base). Once the nut is loose the bit should slide out (sometimes the bit is stuck in the collet and the nut may need to come all the way off to get them apart). Just replace the bit with a new bit with the same shaft diameter, tighten the nut, and you are set. If the new bit has a different shaft diameter than the old bit you may need to change the collet also (in general, different collets are used with different bit shaft diameters).
Oct 03, 2009 | Craftsman Tools & Hardware - Others
Porter Cable 8901 Router Logo
158 people viewed this question
Top Porter Cable Tools & Hardware - Others Experts
John Trevino
Jim Parker
Jim Parker
T bone 1963
Are you a Porter Cable Tool and Hardware - Other Expert? Answer questions, earn points and help others
