Question about Electric Door Light Switch
No electricity to passenger side windows, seat, or airconditioner
The windows on the passenger side will not go up or down and the lock wont work or the seat. Also the airconditioner has no electricity either - is their a wiring harness that is disconnected or what? new capreting was put in before i got it and did they bump somethng ?
2007 mazda 6 front and rear driver and rear passenger windows not working.
The windows need to be re-learned.
- Park the car on level floor. Shift the gear lever to P or N. Pull up the hand brake. Start the engine.
- Sit on driver's seat. Lower the driver side window. Keep the button pressed for three to four Seconds after the window glass sits completely.
- Move up the window glass and do the same as above.
- Do the same with passenger side window glass while sitting on the passenger seat.
- Repeat the same procedure for rear windows one by one from their own buttons.
- Sit on a drivers seat and operate all the windows one by one.
Note:
If the problem persists, pull up the body diagnostic error codes with Diagnostic computer or re-learn the windows with the same machine.
Mar 07, 2014 | 2007 Mazda 6
Window goes down not up
try spraying switch with electrical contact cleaner,can be purchaced at local Radio Shack,Gary
Oct 23, 2013 | Dodge Cars & Trucks
2006 VW New Beetle passenger seat
Check the spring which puts tension on the lever to hold it in the lock position this may have dislodged itself or be broken or possibly bent.
Jun 06, 2013 | Cars & Trucks
Hi the passenger side window rolled down one day and wouldnt roll back up so we did some checking and discovered the motor was good so we figured,and was told it probably was the master switch on the...
Need to get a wiring diagram. Buy a book and follow the wiring schematic. It should help you out majorly. Can't really work on electrical issues without one.
Mar 17, 2013 | 2000 Oldsmobile Silhouette
I have a 2008 Chevrolet Silverado 1500, extended cab, automatic truck.......PROBLEM, the drivers side has a power seat, it will not move in any direction and the passenger side front and rear power windows...
How to diagnose this problem ? Viewing wiring diagrams to see what all is invovled in these electrical circuit's , check power supply's an ground connection's using a DMM - digital multimeter !
What type power seat's ? does it have memory ,heated an cooled etc ?
Power Seats System Description and Operation
There are 2 options of power seat systems available in full size trucks. The first is 6 way driver and passenger power seats without memory. The second is an 8-way driver seat plus 4-way lumbar with memory, heat and optional cool function. While the passenger has 8-way power seats with heat and optional cool function. For the driver memory seat operation, refer to Memory Seats Description and Operation. Power seats without memory are completely controlled through the power seat switch. Battery voltage is supplied to the power seat switch through the power seat circuit breaker. While the seat adjuster switches are in an inactive state the switch contacts are closed to the power seat switch ground circuit. When a power seat switch is pressed to an active state the switch contact is closed to the battery voltage supply circuit. Each seat adjuster motor is controlled by the power seat switch through 2 motor control circuits. The seat adjuster motors are bidirectional and the direction of adjuster motor rotation is determined by which of the adjuster motor control circuits is switched to battery voltage while the other remains grounded.
If it has memory seat's there is a control module !
Battery voltage is supplied to the driver seat module through a 25 A circuit breaker. The driver seat module supplies the seat adjuster switch assembly with a battery positive reference voltage. While the seat adjuster switches are in an inactive state the switch contacts are closed to the adjuster switch common circuit.
Both right side windows have a seperate power supply from the left side window's ,has RT DOORS circuit breaker CB1 - 25amp. location left instrument panel fuse block . Circuit breaker's very rarely fail .Do the door lock's work on that side of the vehicle ? The windows won't work with their own switche's ?
The DDS controls the passenger window through a GMLAN message to the PDS. When a power window switch is activated in the up or down positions the PDS supplies power and ground to the window motor control circuits to drive the window motor in the required direction. Prior to activating a power window motor the PDS will supply the control circuit with a low current bias voltage in order to determine that a short to ground condition does not exist, and during window motor operation the PDS continues to monitor the motor current to verify proper window motor operation. (Scan tool support is available for this system)
Check PDM fuse 4 15 amp ,this supply's B+ voltage to the DOORLOCK/WINDOW switch passenger side . Check for broken wires inside the flex boot from the body to the passenger door .
Nov 18, 2017 | Chevrolet Silverado 1500 Cars & Trucks
07 scion tc passenger window wont roll down when lock by driver..
thats cause that what the lock is for so it wont go down
Jun 06, 2009 | 2007 Scion tC Coupe
ELECTRIC SEATS &PASSENGER SIDE WINDOWS DONT WORK
2003 surbarban driver seat and passenger windows have common fuse/breaker under hood in fuse panel. 50 Amp fuse upper left of box, marked mped this is a big fuse not the little ones.
May 20, 2009 | 2003 Chevrolet Suburban 1500
My electric windows and automatic seat belt do not work
Its time to stop being afraid of the unknown. there is no doubt that you will need to remove the inner door panel to access the electrical modules behind the buttons. https://www.youtube.com/watch?v=p2_f7NkjH8E hope this helps.
Oct 13, 2017 | 1989 Toyota Camry
Electric Door Light Switch Logo
35 people viewed this question
Top Electrical Supplies Experts
ashburton
Steve
Mike Carew
Are you an Electrical Supply Expert? Answer questions, earn points and help others
