Question about Craftsman Garden
Likage to carb to governor craftman 6.0
86 model craftman tiller,6.0 eng looking for linkage hook up from carb to governor
  • shortfusez Feb 25, 2009
    thank you,craftman 7070a 195ci mod,143976001
  • shortfusez Feb 26, 2009
    thank you again,,,,,,,,,but the eng, says craftmandont know what eles to give you
2 Suggested Answers
Dolfoff
  • 148 Answers
SOURCE: Where does the linkage and springs hook up on the
Click the "Engine Parts List" on THIS PAGE.
Hope this helps,
Dolf-
Posted on Oct 18, 2009
I have a troy built Rear tine Tiller It runs greAt but when it gets under a lload it bogs down and goes dead I have rebuilt the carb and it didn't help
Sounds like your governor is hanging up or disconnected.it is what supplies the extra power when needed under load..try this when it is under power reach down and manualy operate the governor linkage and see it the bogging stops if it does then most likely it is the linkage..make sure it is conected then try spraying card lingage cleaner all around your carb and governor linkage while manualy operating it..there are internal and external governors if external and still hanging up take off the top cover and locate the govenor fan located along side the cooling fin area on top of the motor and make sure it is not dirty and sticking..it operates on air supplied by the cooling fins to move the governor linkage..sounds like a lot but is not..just a lot of explanation..good luck
Mar 28, 2015 | Troy Garden
Throttle linkage diagram
maybe someone took off the linkage cable what you need here is
to find a schematic of your unit and that should tell you where everything goes on the unit .you should be able to download a
schematic from the web!
Nov 09, 2013 | Garden
Huskee snowblower help
so you only have idle speed ?
it must start hard
there is a governor but not normal to go out of adjustment
check carb linkage and springs
does your thottle lever move anything when you move it ( as far as throttle plate or any linkage?
Oct 14, 2013 | Tecumseh Snowblower Snow Blower Starter...
John Deere riding lawn mower model LA115. Light tension long spring came loose on carb. Where does it hook up to
I need more info. I need engine make, model, code, date of manufacture, etc. It sounds like a governor spring. Is it wrapped around a linkage going from carb to governor on engine? If it is, it goes in the same hole the likage goes. But to be sure get me the info above and I will check for you.
Aug 01, 2013 | John Deere Garden
Carburator linkage
The governor link hooks on the top right of this carb and the throttle linkage is on the left all this is you standing in front of engine looking toward the steering wheel with the hood off
Sep 03, 2012 | Briggs & Stratton Briggs Stratton Intek V...
I have a craftman 4 cycle mini tiller, running to slow. need to run at a faster speed. do not where to adjust.
If the carb has the "fixed" throttle control. Find the governor control lever with the small, long coiled spring attatched to it in the middle. It may be hooked to a metal tab that is on the back carburetor bolt. Bend the tab to your left to increase set speed or to the right (towards governor lever) to decrease.
Sep 05, 2011 | Craftsman Gas Mini - Tiller/Edger
Need diagram showing actual hook up of governor linkage and springs for b&s engine #130202 0135-01 77062810
This is the guy, right here...found this video, thought I might share it with ya...I'm gonna use it myself to check the linkage on my dad's old tiller!
http://www.youtube.com/watch?v=_IbFOEDMGGs
Mar 18, 2011 | Garden
I have a 9hp Tecumseh engine on my Sears chipper vac. I rebuilt the carb and forgot how the governor and throttle linkage hooks up. Could you send me a diagram showing what holes these linkages go in? The...
I will try again here.
1 wire link from the top hole in the governor arm to the throttle on the carb. There should also be a wire link with a spring that goes from the Governor arm to the speed control handle.
Oct 21, 2009 | Craftsman 6.5 Hp Chipper Vac
It looks as your looking into a tunnel
need linkage hook up for craftman tiller 6.0 eng from goveronor to carb
Feb 23, 2009 | Sony KP-51HW40 51" Rear Projection...
Garden Logo
659 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
