Question about Acer Aspire 3000 Notebook
Screen Contrast localwonder wrote + <→> Contrast up Increases the screen Contrast + <←> Contrast down Decreases the screen Contrast. What do I press after the +? I tried the fn key at the bottom along with the + key and hit the < and > keys with no result. Should I use one of the function keys? f5 and f7 change the screen but I don't know which one is the contrast.
  • aarterry Mar 08, 2009
    I tried holding the blue fn key and pressing the up (to) arrow and the down (bottom) arrow and I cannot see any change in the screen at all. If I hold the fn key and use the right and left arrows it makes the screen lighter and darker. I thought that was the brightness, which I think is different than contrast. I still can't calibrate my screen with Adobe Gamma.
    Problem Solver:
  • 9 Answers
On, your keyboard, there is the FN key in blue. hold it and go over to the four arrows pointing. up,down,left and right. the top and bottom arrows is what you use to change your comeputer's contrast.
Posted on Mar 08, 2009
  • Baht Simpson
    Baht Simpson Sep 23, 2015
    Rubbish! That's the brightness, not the contrast.
I have a set Motorola Canopy 2400BH but i forgot ip address and username and password, how can i access it for using.
You need to user an Override Plug, which can be fabricated this way:
To fabricate an override plug: 1. Install an RJ-11 6-pin connector onto a 6-inch length of CAT 5 cable. 2. Pin out all 6-pins. 3. Short (solder together) Pins 4 and 6 on the other end. Do not connect any other wires to anything. The result should be as follows: Pin 1 ? white / orange ? Pin 1 Pin 2 ? white / green ? Pin 2 Pin 3 ? white / blue ? Pin 3 Pin 4 ? green ? Pin 6 Pin 5 ? blue ? Pin 5
Regaining access to the module To use the override plug 1. Insert the override plug into the RJ-11 GPS sync port of the AP. 2. Apply power to the module through the Ethernet cable. RESULT: The module reboots with the default IP address of 169.254.1.1, password fields blank, and all other configuration values as previously set. 3. Set passwords as desired. 4. Change configuration values if desired. 5. Save the settings. 6. Remove the override plug. 7. Power cycle the module.
You can view more details at:
http://www.canopy-wireless-solutions.com/AppicationNotes/APManualIss5.pdf
Apr 30, 2011 | Motorola CANOPY 2400AP (2400APBC)
Is there any way to brighten my screen on my acer aspire 5601 lap top
Examine the keyboard. There should be a symbol on most of the function keys (F1, F2, etc.). Look for one that looks like a sun or lightbulb, either with an arrow pointing up or with the sun/lighbulb filled in. Hold the 'Fn' key, and tap the up/bright sun/lightbulb key a few times. The screen should increase in brightness.
If you cannot find the specified keys, you may be able to adjust brightness from inside Windows. Right click on the battery icon in the taskbar and open 'power options'. Look for a sun and moon with a sliding bar between them. You might also be able to adjust brightness by customizing your desktop (right click on the desktop and look for the proper menu).
Mar 22, 2011 | Acer Aspire 5600 Series 5630-6951 Laptop
I have model 0155671 but it doesnt look like the model online mine has four buttons across set time plus minus next riw is rnd ctd bottom is manual i dont understand when it says select 12 or 24...
A) 12-24 hour choice >> just use the 24 hour display.
That gives you day and night hours
I don't know why these companies offer 12hr-24hr option on timers.
B) Military time vs Regular time (military time does not use am and pm)
1 1am
2 2am
7 7am
11 11am
12 12noon
13 1pm
14 2pm
20 8pm
23 11pm
24 12midnight
C) Utilitec 0155671 is same as Woods 59377
Before Woods made 59377, they made 49566 (which is also called TD1101 and TD1300)
I think you have Woods 49566
Manual for Woods 49566:
http://waterheatertimer.org/pdf/Woods-49556-TD1300.pdf
Add a comment at any time.
D) How to program timer.
Plug timer in until rechargeable battery is charged and display shows.
Unplug timer to program
1) Set current time.
Hold in reset button for two seconds to clear memory
Press and hold TIME button to select 24 hours so there is no problem. Release Time button.
Press and hold SET button.
MO is flashing, and represents MOnday. TU for TUesday. WE TH FI SA SU
Continue holding down SET button, and press ? ? until current day displays.
Release SET button.
Press and hold SET button again, and Hours will flash
Continue holding down SET button, and press ? ? until current hour displays.
Release SET button.
Press and hold SET button again, and Minutes will flash
Continue holding down SET button, and press ? ? until current minute displays.
Release SET button.
Press SET button again and current time and day will display.
2) Program review:
Set up to 20 on-off programs.
You can select individual days, or groups of days, or all days of the week
For example MO-SU is all days of the week
For each ON time, you also must set OFF time.
So program1 ON is set, then program1 OFF is set
Each ON is set for day, hour and minute
Each OFF is set for day, hour and minute (select same days for OFF and that you chose for ON)
For example if you want timer to turn ON all days MO-SU, make sure OFF time is also set for all days MO-SU.
3) Program the timer:
ON
Press arrow? until display shows PROG 1 ON
This is program1 ON.
Press SET button, but do not hold set button down as you did when setting current time.
The days for program1 ON will be flashing on display.
Press ? ? to select day, or groups of days that you want for program1 ON.
Press SET button again, and program1 ON hour will start flashing
Press ? ? to select hour that you want for program1 ON.
Press SET button again, and program1 ON minute will start flashing
Press ? ? to select minute that you want for program1 ON.
program1 ON is set, next you will set program1 OFF
OFF
Press arrow? until display shows PROG 1 OFF
This is program1 OFF.
The days for program1 OFF will be flashing on display.
Press ? ? to select day, or groups of days that you want for program1 OFF.
Press SET button again, and program1 OFF hour will start flashing
Press ? ? to select hour that you want for program1 OFF.
Press SET button again, and program1 OFF minute will start flashing
Press ? ? to select minute that you want for program1 OFF.
program1 ON and OFF are set, next you will set program2 ON by repeating steps above.
If you do not want to set more programs, that is fine.
Timer lets you set up to 20 programs.
Finish programming: when program ON-OFFs are set, press TIME button and current time displays.
4) Last step:
Push manual override button until AUTO is displayed. This will let timer turn lights on and off.
Plug lamp into timer.
Lamp must be turned ON.
Plug timer into wall.
Dec 05, 2010 | Hardware & Accessories
Unable to adjust the settings for brightness and contrast .
To adjust the display settings:
1. Press the flywheel control. The main menu appears.
The current display settings appear across the top of the main menu.
2. Rotate the flywheel to highlight an option. The name of the
highlighted option appears in the center of the menu.
3. Press the flywheel control to select the highlighted option, then
rotate the flywheel to adjust it.
Some options can only be enabled or disabled. There are also some
options that contain additional menus.
4. Repeat Steps 2 and 3 until you have made all your changes.
5. Rotate the flywheel control until Exit is highlighted, then press
it to exit the OSD control system.
OSD OPTIONS:
Contrast increases or decreases display image contrast.
Brightness increases or decreases display image brightness.
Horizontal Size increases or decreases the width of the display image.
Horizontal Position moves display image to the left or right side of
the screen.
Vertical Size increases or decreases the height of the display image.
Vertical Position moves display image to the top or bottom of the
screen,
Pincushion curves the sides of the display image inward or outward.
Trapezoid increases or decreases the trapezoid distortion of the
display image.
Degauss removes magnetic discoloration from the display image.
Recall returns most options to the original factory default settings
if the monitor is currently using a preset video mode. (See the “Video
modes” section in this guide for information about the factory preset
modes.)
Advanced Option opens the Advanced Option menu. Color opens the Color
Manager menu.
Language changes the display language for the OSD control system.
User displays information about the monitor’s preset modes.
OSD Manager moves the OSD control window on the screen.
Exit closes OSD control system.
Jun 21, 2010 | Gateway EV 910 19" CRT Monitor
Adjust screen Contrast
<Fn> +
<Fn> +
Contrast
down
This will help you achieve this adjustment.
Feb 23, 2009 | Acer Aspire 3000 Notebook
Screen is too dark
<Fn> + <→> Brightness up Increases the screen brightness.
<Fn> + <←> Brightness down Decreases the screen brightness.
Jun 05, 2008 | Acer Aspire 5100 Notebook
No soun thru speakers
First try resetting the unit. If that don't work try this:
Press and hold the SETUP button for at least 3
seconds.
2 Press the UP button repeatedly to select
“mute”.
Each press of the UP button changes the
modes as shown:
NOTE
If you press the DN button the display scrolls in
reverse sequence.
3 Press the TUNE button to toggle the mode
between MUTE ON and MUTE OFF
4 Press the SETUP button to set the selected
mode.
→ NORMAL/HI-FI → AMBER* → DIM → SUB
DEMO ← AUX ← SCR ← MUTE ←BEEP ←
May 30, 2008 | Alpine CDA-7876RB CD Player
Set
Setting Time
In the Clock priority mode, press and hold the DISP/
TITLE
button for at least 3 seconds while the time is
displayed. The time indication will blink.
2 Turn the Rotary encoder to adjust the hours while the
time indication is blinking.
3 When the hour has been adjusted, press the Rotary
encoder
4 Turn the Rotary encoder to adjust the minutes while
the time indication is blinking. The time is automatically
set 5 seconds after the minute adjustment. The time
can also be manually set by pressing the Rotary
encoder
→ Radio frequency → Clock priority → TITLE mode
mode
Playing time
mode → DISC TEXT
→Clock priority→mode
mode
TRACK
TITLE mode ← TEXT mode ←
DISP/TITLE
→ BALANCE → FADER → DEFEAT
SUBWOOFER*← VOLUME ←
Jan 15, 2008 | Alpine CDA-9827 CD Player
Faint screen image
when you first power on using lower right (power) button, wait 6 seconds for the intro screen to finish. The upper left (up) button increases screen contrast. Hold this one down for a few seconds and the screen should darken. The middle left (down) button decreases contrast.
If this doesn't work, try turning off by holding the power button.
Hold down upper left AND upper right while turning unit on. This initiates diagnostic mode and contrast is darker by default. Bottom of screen is a button test area which darkens a symbol for each successful button press. Use it to diagnose a button problem. Turn off power and on again to leave diagnostic mode.
I wish you success playing with the Etrex.
Dec 07, 2007 | Garmin eTrex GPS Receiver
Screen`s brightness less
If tese dont work either your LCD lamp or board may be going bad.
Nov 18, 2007 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer Aspire 3000 Notebook Logo
395 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
