Maytag washing machine, fill problem
The machine keeps filling with water if the lid is left open. The model is a LAT5005AAW, 05-top
  • 52 Answers
You have a bad lid switch. You don't NEED to replace it. Well wait a minute... have you had this machine for a while? Because if it's new to you, there are some washer's that fill while open. BUT if this is a new problem, it's definately the lid switch!
Posted on Feb 24, 2009
I have may tag wash model nu mav5920eww i just hooked it up tried reg wash it filled with water then would not continue to wash went to pause mode
Maytag & Whirlpool washer diagnostic - Fills with water then ...
? 3:03
https://www.youtube.com/watch?v=71zySSScDPE
Jul 11, 2013 - Uploaded by ApplianceVideo.com
Troubleshoot your trusty Maytag Washer that has some of the ...washer diagnostic - Fills with water then cycle stops - LAT8014AAE .... Not agitating Maytag 2 belts top load washers - Duration: 26:55. by theapplianceman 23,820 views. 26:55.Washing Machine Keeps Filling With Water and Will Not Agitate ...
Maytag top loading washing machine stopped working & filled with
Dec 02, 2015 | Maytag MAV5920E Top Load Washer
GTWN5050M0WS won't fill
There is a small glass fuse on the left inside the front panel. Replace it.
Jun 24, 2014 | Maytag LSE7806A Top Load Stacked...
Fills with water, skips wash and rinse cycle, starts spin cycle and sprays water out of the top
I would look at lid switch on this model and plunger to lid .Under lid is spray flume that can be damaged by large loads ,check that close. put it in wash full and drop lid hard it may come on.
Nov 19, 2013 | Maytag Dependable Care LAT9206
Our washer is filling with water but will not run the cycle after it fills. We were able open and close the lid and it would start but now it only fills with water...Please help!!!
the lid switch is buggered the lid can be open while its filling but when it goes to start washing the lid needs to be shut so the lid switch isnt working so the machine thinks the lids open.
Jan 05, 2011 | Maytag Washing Machines
Overfilling maytag centennial - brand new?
Sounds like a hose off pressure switch or faulty switch/ however make sure drain connected ok 1st....
Oct 02, 2009 | Maytag Centennial 3.2 cu. ft. SuperSize...
Maytag washer, model: LAT8415AAE top loader. Washer fills with water but will not start agitating,spin or drain.
Check lid switch. Most will not run with lid open and the switch may not be pressed down when door is closed
May 17, 2009 | Washing Machines
Washing machine fills, but won't agitate
maytag washer dryer stack unit , model # lse7806ace washer fills with water but won't agitate or do anything else. I had the same problem a year ago and replace the lid switch asssemby and fuse and it worked fine until now. the switch clicks when I open and close the lid and the pink and orange wires show continuity with the lid closed.
Aug 29, 2008 | Maytag LSE7806A Top Load Stacked...
Top loading Maytag washer Model #A9700 washer fills with water then stops, no washing, no spinning
When the machine worked would the machine stop in the wash cycle when you lift the lid? If so you might check your lid switch.
Jul 16, 2008 | Maytag Washing Machines
Maytag neptune TL (TOP LOAD) fav6800aww washer
was absolutely the corrosion in the left lid lock, had eaten right through the wire. this site was awesome....always check te left first, it has the sensor to tell the machine it is open.
Mar 29, 2007 | Maytag Neptune FAV6800AW Top Load Washer
Washing Machines Logo
62 people viewed this question
Top Washing Machines Experts
