Question about Maytag PYE2300AY Electric Dryer
MAYTAG DEPENDABLE CARE PLUS I DRYER LDE8704ACE MAKES NOISES. ROLLERS ?
  • Anonymous Mar 08, 2009
    Loud noise during start of tumbling, gets quieter as it runs.
  • petrol76 Apr 07, 2009
    Same issue, what is the fix for said dry bearing?
  • 686 Answers
Rear bearing is dry
Posted on Feb 27, 2009
I have a Maytag Dependable Care Heavy Duty dryer and it makes an awful noise when it runs, also it isn't heating what should I do?
the knocking is either a belt that is going or one of the wheels is broken(they ride on three or four wheels). and those fixes are fairly inexpensive. but if it is also not heating, that can be inexpensive or not. maybe a new one, or fairly new via craigslist. how old is your dryer. over 10-12 years, maybe replace this one
Mar 15, 2015 | Maytag Dryers
My Maytag Depenable Care Gas Dryer has become very squeaky when the barrell spins. i took off the front panel and sprayed WD-40 on the backsides with the Plastic wheels and it went away for about 10...
Probably best to grease the wheels (called drum support rollers) rather than use WD-40 because that strips away the lubrication. It will also pay to check the drum support glides under the front of the drum. Worst case you may have to replace the support rollers.
Jun 26, 2011 | Maytag Dependable Care LAT9706
My Maytag Dependable Care dryer, model MDE9206AYW has begun sueaking very loudly when running. The noise sounds like it may be a rubbing-type of a noise, or possibly a belt. I have not tried to take...
Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.Here is a link to the part in case you need it.
Dec 31, 2010 | Maytag Dryers
I have a Maytag Dependable Care Plus/Heavy Duty dryer (LDE8704ACE) that has served me well with no problems for more than 16 years. Yesterday, it started making a thumping noise that sounded like a huge...
hi look at the lower bottom of front there are 2 screws pull from bottom hing out watch for door switch wires swing front around. look in side top left and right corners 2 5/16 or 3/8 bolts pull them out. lift top up you will see screws that hold fin. oh turn power off hope this helps jim
Oct 13, 2010 | Maytag PYE2300AY Electric Dryer
My maytag dependable care plus electric dryer doesn't shut off
Does the timer move when it's almost ready to shut off if not most likely need a timer. Can you turn it by hand to finish the cycle and shut it off. If not must be timer.
Hope this helps
Apr 24, 2010 | Maytag MDG7600AW Gas Dryer
Thumping/Screeching sound, MD:LDE8616ACE. Rollers? Idler Pulley?
Your description sounds like one or both of the rear drum supports (rollers) is bad. A quiet thumping is almost always present as the weld in the drum comes in contact with the drum supports. A binding support will squeal, and the thumping could be worse at that time. After running the dryer until the noises are present, once disassembled, you can tell if a support is bunding or rolling normally by spinning it by hand. The same goes for the idler pulley. Make sure power is disconnected from the unit befor attempting any repairs.
While the unit is disassembled for repair, make sure your your old cat is not inside.
Sep 11, 2009 | Maytag PYE2300AY Electric Dryer
Should I buy a gently used Maytag dependable care plus model# LAT8824AAE washer? What's the reliability of this machine?
Maytag makes very dependable machines. They are fairly easy to repair and parts are easy to find. If I was in the market for a used washer, a Maytag would be my first choice. Since its used there is no guaranty that the thing isn't going to need repairs. If you can see it run through a cycle before buying it would be a plus. My first washer was a mid seventies model Maytag. I had two minor repairs twice in 15 years and its been working ever since at my buddy's. I hope this helps you.
Aug 27, 2009 | Maytag LAT3600A Top Load Washer
Maytag dependable care plus washer (Model LAT
The belt turn the pulley, but the height of the pulley is worn out so it didn't push up a mechanism to release the brake and to engage with the clutch to make the spin.
You have to takethe shaft out to study how it works then it makes sense on what I 'm talking.
The pulley cost only $11 but it is a major laboring exercise. It is a good learning to have hands on to this problem. Good luck on replacing the pulley.
Aug 08, 2009 | Maytag Dependable Care LAT9706
Maytag dryer not heating up thus not drying clothes
This is usually a simple heating coil malfunction. The coil may have breaks in it causing it not to work. It could also have something to do with 1 of several heating sensors that may be broken, telling the dryer's heating coil that the dryer is too hot, in effect turning off the heating coil. If your dryer has a round lint filter in the rear of the drum, it was 1 of 2 models of Dependable care dryers produced in the 1970's. If this is the case, i supose it would be up to you whether you want to try and get it repaired or not. If you have one of the more recent models,,, the lint filter is directly behind the door, at the front of the drum. and in this case it would probably be a good idea to get it looked at it as Maytag is a relatively dependable brand.
Mar 13, 2009 | Maytag Dependable Care LAT9706
Maytag PYE2300AY Electric Dryer Logo
1,266 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
