Question about Samsung LN-T4665F 46 in. LCD Television
Can hear sound perfect but no picture just stripes I'm having the same problem and have noticed a couple of the capacitors partially blown, the 2200 micro farad caps to be exact. Are these the only ones that should be replaced or should all of them go? Also, would you recommend replacing them with a higher temperature life capacitor? I would LOVE to fix this problem permanently by improving the design but I don't want to save a capacitor and lose a house due to a fire caused by my T.V. lol. Thanks a lot for the info.
  • 1 more comment
  • vincentdeo Feb 24, 2009
    Thank you. The reply was really fast. I'm glad I'm going in the right direction. I'm just a little confused with what and where the STK Ics are. If you can please elaborate I'd appreciate it. Thanks again.
  • vincentdeo Feb 26, 2009
    Thanks for all the advise so far. Right now I'm ready to start replacing capacitors, I just need to ask a crucial question. The existing 2200micro farad capacitors are 10V 105degrees. The only ones I could find at Radio Shack were 35V 85degrees. Would it be safe to proceed or do I need to be exact on the voltage and temp rating? If so, any suggestions on where I can find these components? Thanks.
  • Sibananda Jena
    Sibananda Jena May 11, 2010
    This is a common problem with this model. There are some bad capacitors
    in the power supply. This is the the feed voltage for the signal board.
    Just replacing those capacitor will fix your unit
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
If your concern is on a Samsung LNT4665F 46′ LCD HDTV, then no display could be:
  • inverter (most likely);
  • power supply (likely);
  • lamp/inverter controller (least likely);
  • CCF (cold cathode florescent) lamps (still a possibility but unlikely).
Since apparently you would be performing a DIY (do-it-yourself) component level repair, rather than board replacement, it would be to your advantage that:
  • replace all the capacitors with the same ratings specs in the same area. They most likely share the same manufacturing batch, the same working conditions and therefore would share more or less the same failure rate;
  • your idea of a higher temp rating would be toyour added advantage;
  • be reminded of polarity of the legs;
  • explore the idea of adding a blower fan similar to those used in desktop computers.
Good luck and thank you for using FixYa.
Posted on Feb 24, 2009
    Genius:
  • 2,035 Answers
If like to replace the capacitors go for the solid capacitors which are used
in today's motherboards has they have 6 times life span compared to the
electrolytic capacitors used. Try to use these capacitor rather than going for high value which will create unwanted results on the TV...
Good luck...
    Brigadier General:
  • 8,619 Answers
Hi
The problem is with the covergence circuit goin bad. You need to replace the STK Ics as wwell as the 2200 micro farad caps.
  • 2 more comments
  • Rylee Smith
    Rylee Smith Feb 24, 2009
    Before replacing any components on your Samsung try using HDMI Cable and then see is it makes any diffrence. Also, try and reset it by locating a small reset hole button on back side.
    Use a pen tip to depress if you can locate it.
  • Rylee Smith
    And, if still found it the same way then--
    1. First remove the switch mode power transformer.
    2. Also, make sure you discharge the filter capacitor first before checking on others components. After the filter capacitor voltage already discharged , I used **** smith flyback tester to measure across the primary winding of the switch mode power transformer to see if there are any short circuit occurred.
    3. Replace the 2200 microfarad(would be of 25 volt rating) electrolytic capacitor in the primary side.
    4. A shorted power ic (this monitor is using the 4 pins 5L0365R power ic) in the primary section or a shorted diode in the secondary section would pull down the flyback tester LED bar to the minimum.
    5. Also check main board and inverter board.
    6. Also, check the the fuse (3amp). As, this capacitor(Burnt 220 microfarad capacitor) was located at the same line with the fuse.
    7. Also, check A6J (PNP digital transistor) and the A8J (NPN digital transistor placed near to the fuse.
    Please ask for further clarifications.
    Thanks
    Rylee
  • Rylee Smith
    Rylee Smith Feb 27, 2009
    No, don't replace the 2200micro farad cap.s with 35v, 85 degree rating as they will burn out when you will switch on the tv.
    It wouldn't be safe to proceed. You can buy these capacitors from this link---
    Capacitor 2200 microfarad
    Capacitors 2200 microfarad 10v,105c
    Thanks
    Rylee
  • Rylee Smith
    Also, see this link for buying the capacitors--
    Link 3, 2200 microfarad cap.s
My tv turns on !! no picture but has sound ??? Helpppp !!
Likely you have a partial failure of the power board in your TV. If you hear sound, this means that your tuner circuit is running ok, but the picture power has failed. Check the power board for any blown capacitors or other components.
Feb 01, 2015 | Televison & Video
My Coby 32'' LCD TV comes on but no picture.
Hi Chris,
Sounds like a popped capacitor......if you look inside again, try looking to see if any of the Capacitors are blown...
Jan 29, 2013 | Televison & Video
Ive been using my ps3 on my lg 42'' lcd tv for 3 yrs now perfectly then this past few when playing a game i keep getting lots of lines distorting my picture after about 5mins of that it goes b
Sounds like a blown capacitor on your board to me. Its a common problem in Samsung TV's and is typically an easy fix, but I think in the LG's its a bit more expense and not as easy as swapping out a Capacitor. I think the main board may have to be replaced there. What actually happens is the capacitor bursts at the top and oozes liquid that solidifies, its caused when the capacitor that is used is underrated for the application (basically some engineer's solution to making us have to buy a new tv in 3-4 years, a slightly underrated capacitor will have a shelf life of use, kind of like a timer, they all do it belive me) eventually the set will not rendure any picture at all and the board will have to be replaced.
Mar 01, 2012 | LG 42LG30 42 in. LCD HDTV
I have a Vizio VO74L TV almost 3 years old. Last night it popped and the screen went black and lost sound. It turns on and you can hear it click but still no sound and a dead screen. Opened it up and...
If the capacitors have blown then it would not cost much to change them all, Capacitors in LCD tv's are a common faulty due to poor chemical compounds used to make them and heat exhaustion, especially with the tvs that have the same chassis. Try changing them all and see if it makes any difference. Vizio or other manufacturers wont say anything as its not under warranty and they dont like people looking inside their tvs :).
Mar 22, 2011 | Vizio VO47L 47 in. LCD TV
The picture and sound on my 55 inch Sony disappears momentarily
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is XL-2200.You can find it here: http://www.discount-merchant.com/Sony-XL-2200-TV-Bare-Lamp-Bulb-p/sony_xl-2200u_a1601753a_lamp.htm?Click=48173 Have a blessed one!
Apr 02, 2010 | Sony Grand WEGA KDF-55WF655 36" Rear...
Lg 37lc7d with no picture or sound but green light comes on . popping noise preceeded problem. no obvious blown capacitors
Ur tuner board is dead.Replaced this board to get picture back.Tries Shopjimmy.com,Ebay.com for the board part.
Feb 10, 2010 | LG 37LC7D 37 in. LCD HDTV
SanyoTV-blk screen w/thin line of light across screen great sound
Your Vertical Amp is probably Blown (bad) , but before you change that check all capacitors around the vertical amp IC and / or resolder resistors and diodes around vertical amplifier.
And NO it is NOT the Picture Tube
Good Luck
JG
Apr 18, 2009 | Sanyo DS27820 27" TV
Hello dod2470,
This is a common problem with this model. There are some bad capacitors in the power supply. This is the the feed voltage for the signal board. Just replacing those capacitor will fix your unit
Dec 11, 2008 | Samsung LN-T4665F 46 in. LCD Television
Underexposed, grainy images with a light stripe running down the center
Sounds like your shutter curtain is malfunctioning. Did you bump the curtain when u loaded film & bed it... Take a close look to see if it is binding. This is a very fragile area to monkey with & should be done by a qualified repairman
Jun 26, 2007 | Canon EOS Rebel K2 35mm SLR Camera
Samsung LN-T4665F 46 in. LCD Television Logo
164 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
