Question about Samsung SyncMaster 710N 17" LCD Monitor
I have the syncmaster 710N. I recently had a
I have the syncmaster 710N. I recently had a computer built and tried to hook it up with the monitor. It's like the computer doesnt know the monitors there or something. the monitor recognizes the pc though! PLease help!
  • Nerijus Mazuolis May 11, 2010
    does your monitor turns on and green led is blinking ?
    Scholar:
  • 36 Answers
Hi
I am a technician-informatic. I have repaired about 60 Lcd Samsung monitors with thees problems - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
if you are interested check it on eBay.
Samsung monitor repair manual guide 710n,913v,510n more
or just enter number in search field: 220409788372
thank you
Posted on May 15, 2009
  • Nerijus Mazuolis May 15, 2009
    hi
    monitors.The repair process is very easy and simple 10-30min. does not
    if you are interested check it.
    thank you
  • 5 Answers
SOURCE: No video output
Add a 50 ohm between pin 5 and 6 of the NT68F63LG IC.
Go to this link to learn the details. http://translate.google.com/translate?hl=en&sl=es&u=http://www.dtforum.net/index.php%3Ftopic%3D55304.msg1010695085%3Btopicseen&sa=X&oi=translate&resnum=3&ct=result&prev=/search%3Fq%3DNT68F63LG%2B50%2Bohm%26hl%3Den%26rlz%3D1T4SUNA_enUS219US220
I tried this fix on my monitor and it works now.
Posted on Aug 25, 2008
  • 43 Answers
SOURCE: problem with brightness of monitors SyncMaster 710n
Dear siela,
100% brightness in monitor is not at all the problem.That tablet apperars becoz of the virus it seems.so just download some antivirus software and instal it.i sugestion is kaspersky antivirus. ANd for brightness of computer itsyour wish. optimum is 90%. below this it will b dull.
Posted on Sep 06, 2008
SOURCE: No display Samsung SyncMaster 710N 17" LCD Monitor
same problem here...
here is a translated version of a webpage discussing the repair for this error...
http://72.14.235.104/translate_c?hl=en&sl=es&u=http://www.dtforum.net/index.php%3Ftopic%3D55304.msg1010695085%3Btopicseen&prev=/search%3Fq%3DNT68F63LG%2B50%2Bohm%26hl%3Den%26rlz%3D1T4SUNA_enUS219US220&usg=ALkJrhiRO8V09Lo7lnjqW47LE8IE653r7w
solder a 50 ohm resistor on pins 5 & 6 of Novatek NT68F63LG chip...
good if you can DIY, best if a qualified technician do it for you..
Posted on Oct 22, 2008
SOURCE: Samsung SyncMaster [Monitor] (22.0 - I need best settings
hi , any has got the drivers for this monitor , kindly let me know to download it . regrads
Posted on Nov 10, 2008
  • 63 Answers
SOURCE: 710n "non optimum mode"
I give you this link, but you must know about electronics that you can do this. If you can´t find wath you want, just write and I will give you everything about that in file (word). Do not be afraid do this because it´s working I try that.
Posted on Jan 05, 2009
When I open the Monitor (samsung syncmaster 710n) everything is OK! As I soon as I connect the vga cable from my pc the monitor turns on stanb by mode and does not react to any buttons!
It sounds like you are connecting with the power on. NEVER do this!
Shut off your computer AND your monitor. When both are off, THEN connect your cable.
Then you can turn the PC and monitor on (the proven old school way is to turn on monitor first, then PC)
If nothing was damaged from connecting them "live", you should be OK.
Feb 10, 2011 | Samsung SyncMaster 710N 17" LCD Monitor
My syncmaster 710n is not working. I get the box where it ses what resolution si the right one, but the syncmaster 710v works normaly. Does that means my 710n can`t be repared anymore? Thanks
Not completely sure what you're saying. Here's what I got out of your problem:
You have a Syncmaster 710n that displays a box saying the best resolution is _____ x _____, but your Syncmaster 710v doesn't show that message.
The main question I have to ask you is whether or not you see the screen or display behind the message on the Syncmaster 710n.
In either case, I doubt that this is a hardware problem. I also highly doubt that your monitor cannot be repaired. Try the following:
1) If you see the display/screen is showing behind the message box, this is almost definitely a setting issue. You need to press the menu button on your monitor and look for an option that says something like "display resolution message" or "ideal resolution message", or something else like that. Then you need to change the setting for that option, for example if "Yes" is selected, then you need to change it to "No" or if "Enable" is selected you need to change it to "Disable".
If you have the manual for the monitor, it should make it easier to know what setting to change. If not then go here:
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=05020100&prd_mdl_cd=&prd_mdl_name=710N&prd_ia_sub_class_cd=P
and download the Manual that you need.
2) If nothing is being displayed behind the message, try to change the display settings of your computer. While using a different monitor, try the following: If in XP, right-click on the desktop and go to Properties, and select the tab for display settings and adjust the resolution to something compatible with your monitor (like the one it suggests you to change it to). If in Vista/7, right-click the desktop and select Screen Resolution/Display Settings and adjust it there.
Good luck. Let us know how it goes.
Feb 16, 2010 | Samsung SyncMaster 710N 17 in. Flat Panel...
Jan 03, 2009 | Samsung SyncMaster 710N 17 in. Flat Panel...
Driver of samsung monitor
I will go with Cropp on this one however if you cant find it at that site you may also try driver guide.com
Jun 06, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
hi
I am a technician-informatic. I have repaired about 40 Lcd Samsung monitors with thees problems - not optimal resolution mode and dark screen problem. So i decided to made manual how to repair lcd samsung monitors.The repair process is very simple 10-30min. does not need a lot of experience in electronics and expensive instruments.
thank you
Oct 29, 2007 | Samsung SyncMaster 710N 17 in. Flat Panel...
Syncmaster 710N resolution problem
no,
the LCD display don't harm the eyes cause don't spreed radiation.
preferred resolution 1280x1024 at refresh rate of 60Hz is not optimal.
the samsung 710N can easy handle 75Hz at 1280x1024 so just change it.
Jan 30, 2007 | Samsung 710N V2 (Ivory) 17 in. Flat Panel...
Samsung SyncMaster 710N 17" LCD Monitor Logo
593 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
