Question about Canon PIXMA MP830 All-In-One InkJet Printer
The scanner/fax on our canon mp830 isn't feeding the paper through? any help???
  • 2,035 Answers
Try these solution :
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck under the black guide plate, this may work it loose.
Posted on Feb 24, 2009
Canon MP830 Error Code 6AOO
The error seems to indicate a failed sheet feed, check the paper path to see for any stuck bits of paper, however I have heard that this can also be caused by a flaky sensor in the paper path.....
apparently the best way to deal with this is to turn it upside down and give it a shake.
hope this helps
Jul 21, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Fax output error
Pretty sure your paper tray button is set to get paper from the bottom paper cassette which is the tray that slides into the bottom of the printer.
If you switch the paper tray selection button* to use the rear feed tray you'll probably find it will print faxes sucessfully or you can put paper in the cassette tray...
*The paper tray selection button is just under (and slightly right of) the "Memory Card" button and has an icon image of the printer with two LED's (top and bottom). These lights indicate which of the trays is currently selected...
Hope that helps.
Mar 27, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Paper feed feeds 10 sheets at a time rather than one
It sounds like your seperation pads are worn out. They will need replacing.You will need a service technician to do this.
It will probably be cheaper to buy a new machine.
Dec 09, 2009 | Canon MP830 All-In-One Printer
I run a Mac OSX Leopard My Canon MP830 seems to be having a paper feed problem. I also get the Error 5010. This happened right after using the scanner. It starts to work ok, but then a noisy clicking...
Is the message 5100. Paper jam? This indicates that the printer head carrier is being interferred with. Open the cover and check the slide bar and the paper path to see if there is something obstructing movement. If the drive belt has slipped it needs to be reseated.
Apr 28, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Scanning problem
I checked with the Canon Help Desk and wass told to uninstall driver for the Canon MP830 (unplug the USB Cable) and thn reinstall it. Hint: make sure you have your disc to reinstall befoe you uninstall, just in case.
Feb 23, 2009 | Canon PIXMA MP830 All-In-One InkJet...
MP830 canon 3in1 scanner lock.
my mp830 will print, copy, fax but it will not scan to the computer. Please help
Sep 10, 2008 | Canon MP830 All-In-One Printer
Scanner is not operating correctly...
You have to download MP Navigator if you want to scan
May 13, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Copying and fax sending problem
  1. Just check & clean the dust in the original feeding area.
  2. if not solved, clean the Document feed sensor or replace the same. But for this you need to open the body of the fax machine.
Mar 11, 2008 | Canon FAX-B820 Plain Paper Bubblejet
Pixma mp830
see if you can open a back door on the feed side. sounds like a paper is not feeding properly inside and must be removed.
Would be nice to know the model, make.
Jan 07, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon PIXMA MP830 All-In-One InkJet Printer Logo
174 people viewed this question
old marine
old marine
