Question about Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
Error 50 after jammed paper on brother MFC-240c
  • 10 Answers
I had this too, I had to open the back of the machine, it is meant to open and pull out and clear the jam (pull out the crinkled paper) but everytime I tried to print again it kept saying that it still had the jam, I opened and closed it several times and it did not seem to register that I HAD CLEARED THE JAM, so what I did was unplug it from the wall and then plug it back in and then it was fine. I wonder if this is AN ACTUAL DEFECT with this machine, if ater a paper jam it cannot detect that it has been resolved without having to unplug it and plug it back in, HOPE THIS WORKS FOR YOU.
Posted on Jun 19, 2009
SOURCE: paper jam in brother MFC 240C
the paper ripped at the corner in little pices and it is jamed in the printer how can I remove it
Posted on May 31, 2008
SOURCE: paper jam, and I don't
I had the same problem.  I had removed all the visible paper and when it came back on made some awful noises and flashed "paper jam".
I even moved the roller forward and backward (after having uplugged the device.  I did this repeatedly and the "paper jam" alert continued (along with the awful noise).
As a last resort I thought I would just take it apart and hope to get it back together but figured it was a sensor or something along that line if I could not find any paper anywhere
with the machine unplugged (it would not shut down), I opened the lid I used a flashligt to look around trying to figure out how to take it apart.
It then dawned on me that I had not moved the print head over and using a screwdriver I gently pushed it to the center of the bar.  When I looked inside with a flashlight, there was the paper jam way inside under the cover.
I used some needlenose to reach in and took the paper out and it is now working fine.
I hope this helps, but you may have to search really deep into the device.
Posted on Dec 10, 2008
  • 526 Answers
SOURCE: BROTHER MFC-240C,UNABLE TO CHANGE 50
This error is usually caused by the Carriage Encoder Strip being dislodged from
the sensor mounted on the Print Head/Carriage Assembly.
Unfortunately, you will need to remove the scanner assembly, and top cover assembly to check to see if the encoder strip has come out of the printhead assembly.
Posted on May 05, 2009
Bappa170873
  • 505 Answers
SOURCE: Error 30 after jammed paper on brother MFC-240c
Open the front and the rear panel and make sure there is no bit of paper jammed. Also make sure there is no dirt in the printer roller
Posted on Jul 03, 2009
pineworks
  • 4041 Answers
SOURCE: Print Unable 30 Error...
Several conditions may cause the error message Machine Error 30, 33, 34 or 35 to be displayed on the LCD. This error may be the result of one of the following:
  • The print head carriage is failing to return to its home position to the far right of the unit.
  • Both of the springs located on each side of the carriage is out of place.
  • The cartridge covers may not be locked securely in place.
Please follow the instructions listed below to correct this problem:
  1. Press the INK button on the Control Panel.
  2. Using the dial pad, press 2 (Replace Ink). The display will prompt you PLS OPEN COVER.
  3. Pull the Scanner Cover release lever located under the Control Panel and lift the Scanner cover. The carriage should move to the left in order to replace the ink. If the carriage does not move to the left, your machine will require service.
    If your machine is still within warranty, click here to locate a Brother Authorized Service Center in your area or click here to obtain contact information for the appropriate Brother Customer Service Center. If you are out of warranty, use the link to locate a Brother Authorized Service Center in your area.
  4. After the carriage moves to the left, press down each cartridge cover and remove all ink cartridges from the machine. There are 2 springs located on each side of the carriage that hold the print head against the carriage assembly. They are thin silver springs approximately 2 1/2 inches, set at an angle.
  5. If the spring is out of place, press the spring back into place. You can use the spring on the opposite side of the carriage as a guide as to the correct position.
  6. If the spring is not out of place, reinstall each ink cartridge.
  7. After installing the ink cartridges, close the covers and verify they are securely locked into place. Your machine then prepares for a head cleaning and goes online. The LCD screen prompts you to verify if a new ink cartridge was inserted for each color you removed. For example, DID YOU CHANGE BLCK 1. YES 2. NO.
  8. Press 2 (No).
Note If you decided to place a new ink cartridge in for any of the colors when uninstalling and reinstalling the cartridges in the above process, press 1 (Yes). The machine will automatically go through a cleaning cycle.
Also this might be handy for you. To reset purge counter
1) Enter machine maintenance mode (on MFC240C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine’s log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Please call back and gave us a vote. All The Best: Pineworks
Posted on Mar 02, 2010
"Clean Unable 51" error. I
Click the link below to download the Service / Repair Manual ( Brother MFC-240C) :http://www.mediafire.com/?l39vz2fiqqkl73y
You must have Adobe Acrobat Reader installed to view PDF files. The reader is a free plug-in available at the Adobe web site
Jul 04, 2011 | Brother MFC 240C All-In-One InkJet Printer
Brother printer mfc 240 error 50?
this error is due to the machine does not work due to a paper jam.Clear the paper jam or may some mechanism not functioning properly check it ....
Dec 12, 2009 | Brother MFC 240C All-In-One InkJet Printer
Jul 03, 2009 | Brother Multi-Function Center MFC-240C...
Message unable to print 50
Machine Error 50 either means that there is a loose object inside the machine (usually piece of paper), or that there is a mechanical error which would need you to have the machine sent to service.
Jun 02, 2009 | Brother MFC 240C All-In-One InkJet Printer
May 05, 2009 | Brother Multi-Function Center MFC-240C...
How to solvc machine error 50?
sounds like you have print error. if it under 1 year, yyou still have warranrt, then take the machine to a service center brother tech. ps you can not do this by yoursekf!
Nov 22, 2008 | Brother MFC 240C All-In-One InkJet Printer
Print error 50
Is there a door at the back? My 640 has one and you must open it to clear the jam.
Aug 04, 2008 | Brother Multi-Function Center MFC-240C...
Error messages
I can't help directly but if you go here to the (Australian) support site
http://www.brother.com.au/customersupport/customersupport.asp
you may find your answer.
Note You may need to contact them direct to get your answer.
Good luck.
May 11, 2008 | Brother Multi-Function Center MFC-240C...
Brothe MFC-240C paper jam error msg won't clear
**, it is not fixed. I followed instructions on Brother web site and was able to find a piece of paper near the printhead, so I removed it. The printer makes a grinding sound when it tries to print and the same paper jam error returns and can't be cleared. I beleive that the printer repair cost will be more expensive than replacing it with a different printer, and it won't be Brother brand. I probably would not be able or have the tools to do any complicated repair job.
Mar 08, 2008 | Computers & Internet
Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
597 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
