Question about Akai PT46DL10 46" HDTV-Ready Television
Won't show picture but has sound
We have an 46inch Akai PT46DL10 projection televison set. We can here the sound but there is not picture. The green power light just keep flashing like it is trying to come on but never does. Please help.
  • 32 Answers
You can have numerous problems. I have the exact same television in my shop awaiting parts because they are extremely hard to find. The service manual is useless unless you have the diagnositc software adn operational software to properly test the television, so do not attempt to buy a manual online you will waste your money. The television is actually pretty easy to check if you have a multimeter, T10 torx screwdriver or T10 socket, and a philips screw driver. First of all remove the back cover from the television, do not worry about the screen assembly, it is flimsy but it is mounted on the inside to not go anywhere when the back cover is removed. Next remove the black voer that is mounted by 4 torx screws, the cover that has the projector part of the engine assembly sticking through, be careful not to damage the black foam rubber that is around the projector head. Once you have those two covers off, unplug the ballast power supply wire which is the white and black wire on the bottom of the ballast, the ballast is the cicuit board that is mounted in front of the big fan on the right side Also has two wire coming from the top that plug into the lamp housing. With a multi meter check to see if you have power going into the ballast (TV has to be plugged in and turned on to do this step). If you have power going in then turn the television off and unplug it and and plug the power supply wire back into the ballast. Next remove the lamp which is secured into place with the one screw on the left side. See if you have power coming out. If you have power coming out than replace your lamp. If you do not have power going inot the lamp than replace the ballast. If you do not have power going into the Ballast than replace the power supply which is part number DVL-U2830XC good luck in finding that part. If you have power going through to the ballast, and to the lamp and have replaced the lamp than replace the video board Part Number B0001, good luck finding that part. If you have replaced the Video board, ballast, lamp, and power supply and it still fails part your television out and make parts available for other people because the last thing is the engine assembly which costs 2999.00, yes that number is right Two Thousand Nine Hundred and Ninety Nine Dollars. Again, parts are very hard to come by for that model and unless your a customer like that one I have that actually wants it fixed don't bother with it.
Posted on Mar 01, 2010
  • BugMeNot1 Nov 29, 2010
    what are the expected input and output voltages at the ballast?
  • evilpea Jun 15, 2011
    about 300 volts
Service manual for AKAI pt46dl10
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
http://schematicscom.blogspot.com/
Aug 19, 2017 | Akai Televison & Video
Green light flashing and no picture on our tv
2004-Model H 347 - 10839 Phillips big screen HDTV. The picture went 3-D.
Dec 25, 2009 | Akai PT46DL10 46" HDTV-Ready Television
Power and lamp lights flashing red and timer flashing green
Hi,normally when the 3 led lights show up they indicate its time to replace the lamp.The lamp that is inside your tv normally last around 3000 hrs 1-2 yrs .Pay attention to any weird sounds which could indicate another problem.
Dec 16, 2009 | Akai PT46DL10 46" HDTV-Ready Television
Akai, PT46DL10 Has sound, no picture
make sure all componet cables are in the right color coded spots on the back or side of the tv and you are on the right componet if using a cable box make sure using componet / monster cables not all cable companies support hdmi if that is how you are trying to hook up make sure to check with them
May 14, 2009 | Akai PT46DL10 46" HDTV-Ready Television
Code remote akai pt46dl10
had same problem tried all kinds of universal remotes but none were compatible look online and found only logitech Harmony® 550 Advanced Universal Remote is compatible with this model akai pt46dl10 bought one now works fine and was able to reset my lamp timer with it as i just replaced it paid $65 on craigslist for remote good luck
Apr 26, 2009 | Akai PT46DL10 46" HDTV-Ready Television
Green tint to picture when dvi cable is connected
The tv will show correctly in 720p mode. Cable box and PS3 must be set to display in 720p or the green tint will remain. For the PS3 I return it to 1080p when I am about to play a game, blu-rays and dvd's can only play in 720p.
Dec 15, 2008 | Akai PT46DL10 46" HDTV-Ready Television
FLASHING GREEN LIGHT CONTINUOS, NO PICTURE OR SOUND
check your lamp and see if it is either broken or the filament is black on any part
Aug 01, 2008 | Akai PT46DL10 46" HDTV-Ready Television
No picture Akai PTDLP46
It may be the ballast , I've the same problem in here in quebec, and i don't know where i can buy it. the part number is P306-0022. Normal Cost is $199.99
Apr 18, 2008 | Akai PT46DL10 46" HDTV-Ready Television
Akai PT46DL10 46" HDTV-Ready Television Logo
496 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
