Question about All-Pro Forced Air Kerosene Space Heater SPC-K75
Unit will run around 10 mins then it quits burning. blows unburnt fuel then will shut down automaticaly. lost my manual and looking for a sourch to order parts for unit. i think my igniter is bad ? not sure. thankx 4 the info
  • 181 Answers
Mayby you have dirt and garbage in the fuel will pick up the garbage and it willn't get the proper amount of fuel to burn.spray pattern must be correct to keep burning correctly.does this unit have a glow bar or does it have a spark plug???? a place to get parts and break downs is
Posted on Feb 24, 2009
Had a Kohler 17.5 command installed on mower to replace failed 16 same. Will run about 10-15 min then just quit after waiting 30-45 runs ok nut quits again after 10-15 min. ??? Just changed oil.
sounds like the fuel cap may not be vented right or plugged. loosen the cap and try it if that is it replace the cap or clean the vents. be sure the fuel line is away from the engine and getting plenty of air flow off the engine. if the fuel gets to hot it may be boiling the fuel causing it to die till it cools off. if these don't help you may look into replacing the coil.
Jul 03, 2017 | Garden
I have JD 935 that runs fine for 10 mins then idles down. Never fully quits running. Changed fuel filters, lines, pump...
check for the cooling fins around the head and block are not blocked with grass clippings/ dirt/dust as it may be tending to overheat and boiling off the fuel in the mixture
Sep 16, 2014 | Cars & Trucks
Have a 1997 saturn dohc,,runs for 10 min,and shuts down,,wait 15 min starts right up and runs 10 more min have replaced coil and ecu,,
Check resistance across each of your fuel injectors.Assuming an sl2,resistance should be 11.5 to 12.5 ohms. Measure after it shuts down. You are looking for one that has low resistance. This is not for sure, but it's a good thing to eliminate.
Oct 22, 2011 | 1997 Saturn SL
After tractor runs a about 1 hr then it will shut down, but it will start back up and runs about 10 mins and shut off again. It has plenty of fuel.
A couple things #1 ignition coil failing when hot.
#2 more so, fuel restriction. fuel filter plugged, fuelline plugged at tank or fuel cap not venting.
Try loosening cap when it starts to quit.
Aug 15, 2009 | S&D International Harvester Cub Tractor...
Engine coughs and stops after about 15 min. of cutting
check the vacuum line from pump to crank case fo leaks
Apr 25, 2009 | Garden
Husqvarna 24 hp mower shuts down after about 5 or 10 min.
Mar 22, 2009 | Husqvarna Garden
Pro 110, runs 10 min., blows white smoke ,shuts off
the first thing you need to do is go back to useing K1 kerosene, diesel fuel not only burns dirty but also has a tendency to gel up in cold weather which could be makeing it hard for the heater to draw the proper amount of fuel. To reset the pressure you will need a gage, it should run at about 6-7 psi. you can order a pressure gage from mr. heater online, they are by far the cheapest I have found as they are the actual manufacturer or call 1-800-251-0001
Feb 05, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
'88 Ford Ranger has a bad miss in it
plugs to they sound marinaded in unburnt fuel!
Oct 23, 2008 | 1988 Chevrolet S-10
Toyostove laser 55
sequence of operation is just like the monitor. combustion blower comes on to purge chamber of fumes. after the delay, the solenoid pump comes on and deposits fuel to the burner mat, within 20 sec the igniter comes on, incandesces and ignites the fuel if there is no flame, the flame rod is supposed to shut down heater and go into a lockout condition until shut off or unplugged to reset. check solenoid pump first. you already know the igniter works. check the fuel filter in the fuel sump might be clogged. check the fuel sump float valve, might be stuck, supposed to hang free in the sump with needle valve open. thermostat is digital just starts and shuts down the burner and solenoid pump.
Dec 13, 2007 | Rinnai Toyostove Direct Vent Heater:...
All-Pro Forced Air Kerosene Space Heater SPC-K75 Logo
122 people viewed this question
Top All-Pro Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
T bone 1963
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
