Question about eMachines W4685 PC Desktop
When I attempt to log on to my computer, I get message "Loading personal settings", but it immediately changes to "Logging off"...I can't even log on.....HELP!!! I am using an emachines w4685....
    Novelist:
  • 121 Answers
My Name is ArmyMason, I am here to help you. Are you seeing any flash of Blue Screen before it reboots? If not it sounds like you have a boot virus. If you can't boot to Safe Mode best the way to fix this is to pull out the hard drive and put it into another computer that has up to date Antivirus. On the hard drive are pins with a little plastic piece attached to them above that should be a diagram SL = Slave, MS = Master, CS = Cable Select. Depending on the Setting the persons harddrive that is in the computer you are about to put that Hard Drive into depends on the setting you need for your Hard Drive. So remember or right down the setting of your hard drive. If there hard drive is set to Master set your hard drive to slave. If there hard drive is set to Cable Select set yours to Calbe select. With the computer off and unplugged, locate the cable that the hard drive is connected to and take your hard drive and connect it to the second connector which is in the middle of the cable. This is where all slave hard drives go. Note: Dont worry you wont infect the host computer with a virus, because its not an active partition. <--- techy info... Now boot the computer and once the Hard Drive is detected run the Antivirus program on that drive.
There are other solutions, but this is one way you can remove the virus without having to format your computer and start over. If its a Blue Screen please make a post with blue screen issues so that we can figure out exactly what the error is.
Posted on Feb 24, 2009
My computer had been infected by a virus a few days ago then I run a full system scan in my computer and deleted all virus infected files then I restarted my computer and log in using my username and...
When you turn on your computer press F8 for the startup options and choose Safe Mode. When the computer enters Safe Mode run another system scan and then restart. If you are unable to enter your account again, try to do a System Restore (Start\All Programs\Accessories\System) to a date before the infection happened and then do another full system scan.
Mar 09, 2011 | Microsoft Computers & Internet
Every time i try to log in to fb, the page starts loading but then i always get deferred to a page saying "you must log in to see this page" . Sometimes it even says that my password is wrong...
Kindly check the email address you used in logging in to Facebook, is it a valid one.. also checked if you have hit the caps lock key in your keyboard, this can also cause wrong passwords.. :)
or if you want me to check your account, kindly pm me.. :) thanks!
Feb 03, 2011 | Facebook Social Network
My boyfriend has a HP Pavilion ZV5000 laptop running Windows XP. Everything loads fine. then he trys to log into his user name, puts in the password... it sais loading your personal settings, then the...
Starting point would be to turn the computer right off including taking out the battery unplug the power supply wait a while and then reconnect power supply and restart holding down the key that allows you to enter the BIOS. Reset the BIOS to default settings and then restart. If this works then reinsert the battery and hopefully this will fix your problem.
Sep 11, 2010 | HP Pavilion zd7000 zx5000 zv5000 presario...
Completing a recovery without a disk?
This is a common virus attack that will throw you out everytime you login, or licensing issues
For virus problem is bit tricky and needs to deal with registry settings and also need network computer
Try following
Log on to a networked computer.
Run Regedit.exe
Point your cursor to HKEY_LOCAL_MACHINE
Select File > Connect Remote Registry
Type computer name (infected computer)
Navigate to the following location in registry of destination or infected computer
HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
Edit below two values in right pane:
Shell
Userinit
Change the two values to
Shell=explorer.exe
Userinit = c:\windows\system32\userinit.exe
close the Registry
Restart Infected computer.
You should be able to log on to computer. if it not work then go to back steps and just copy and overwrite the file userinit.exe from installation source.
May 17, 2010 | E-Machines eMachines Desktop PC
Stuck In A Loop
sir re-install your operating system base on my experience they infected with a virus. the virus is password_viewer..
Feb 09, 2010 | HP Pavilion ze2000 Notebook
When I try logging in to my computer at the Welcome screen I get "loading your personal settings" then it flashes and comes back to welcome screen then says "Logging Off" "Saving your settings". It seems...
Your computer has likely gotten a virus which is causing this to happen. This post in a bleepingcomputer.com forum lists several ways to remove it. Once you get the computer to start up again, download the free version of Malwarebytes' AntiMalware program. Run it and let it scan your computer. It's a very effective program to clean out bad software.
Hope you're back up and running soon. Thanks for using Fixya!
Jan 21, 2010 | HP Pavilion ze2000 Notebook
Stuck on loading personal srttings
Your user account is corrupt. First try logging in with a different user ID. If you can't do that, then reinstall Windows.
Oct 22, 2009 | Gateway CX200S Tablet PC
System won't log on
try safe mode. If it works, use system restore to go back to a previous working configuration. If safe mode does not work, try the last known-good configuration. Restart the computer, then as soon as the Dell logo shows up on the screen, press the F8 key repeatedly until you enter the Advanced Options Menu. Use the arrow keys to select Last Known-Good Configuration, then press Enter.
Jan 11, 2009 | Dell Inspiron 1150 Notebook
eMachines W4685  PC Desktop Logo
88 people viewed this question
Top eMachines Computers & Internet Experts
Michael Vincent Cruz
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
