Question about Garmin StreetPilot 2820 GPS
I am attempting to connect my Garmin 2820 on a BMW Navigator II motorcycle mount, I need to connect my Phone (Motorola Razr x3), a Zune mp3 player and an Escort radar detector through the garmin to use it as a Bluetooth interface to my stereo bluetooth helmet.
  • 504 Answers
SOURCE: Bluetooth enabling
Does it work properly otherwise? Is this the only place it gets stuck?
Posted on Jan 21, 2008
Maanita
  • 1142 Answers
SOURCE: garmin 760 is stuck on enabling bluetooth
refer to this link
http://www.garmin.com/garmin/cms/site/us/lang/en/searchsupport
Posted on Aug 17, 2008
SOURCE: Garmin Bluetooth connection problem
I got this finally fixed by updating the software. Goto http://www8.garmin.com/products/webupdater/howtoinstall.jsp and follow the instructions. But it is important that you don't only update the Garmin software but also the GPS software (or firmware). After doing this, I couldn't make it fail anymore. Good luck!
Posted on Oct 18, 2008
SOURCE: garmin bluetooth won't disconnect call
Solution below works for NUVI660 as well; ignore everything after step 6 but DO reboot and delete previously existing connections.
good luck
All,
I was having the same problem with my Curve and Nuvi 680. What has fixed this for me is downgrading the Bluetooth firmware version on the Nuvi itself. I was running version 3.0 (you can check your version by going to Settings -> System -> About on the Nuvi) -- I had success after downgrading to version 2.4.
It's a bit of a convoluted process, but here is the procedure I followed:
1. Download the old Nuvi BT firmware from the Garmin Italy website:
http://www.garmin.it/files/FileBluetooth.zip
2. Connect your Nuvi to your PC.
3. Go into the X:GarminRemoteSW and look for a file called 006B055301.GCD (where X: is your Nuvi drive)
4. Back up that file to your
computer, and delete it from the Nuvi.
5. Extract the file in the zip downloaded in step 1 to the X:GarminRemoteSW directory
6. Disconnect your Nuvi from your computer, and let it
reboot
7. Click on "View Map," then touch the "Speed" in the lower left corner.
8. You should have the "Dashboard" view up. Touch and hold the "Moving Average" box for ~15 seconds until the diagnostic screen appears.
9. Press the "next" button until you arrive at the "Bluetooth Status" screen (5-6 screens in)
10. Click "Updt PR" and then click "Yes"
11. Reboot the Nuvi, delete the existing bluetooth pairing, and attempt to re-pair with your BlackBerry.
Seems to work perfectly now -- please let me know if you have any questions. Good luck!
Posted on Feb 21, 2009
SOURCE: Pairing bluetooth motorola W755 phone to Garmin nuvi 760
I left the Garmin in passive mode and had just the phone do a search for new bluetooth devices and it worked fine. So my advice is , if the Garmin instructions don't work, try this method.
Posted on Apr 02, 2009
Can i sync my 30 gb zune with my new head set Motoral a9dp hd
No you cant sync files from motorola head set to your zune directly.First you connect your both things to your PC and then tranfer files to each other. Thankyou.. :) Please give high ratings if you like.
Jan 02, 2010 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
My Zune says there was a error when I try to download the upgrade
well i assume that you either connected the zune to your pc or attempted to connect it to wifi, either way if there is an error downloading the upgrade then it could just be the site, and if you were able to dl it then you may not even need to upgrade. i recommend either restoring the zune to a previous version if the update was not successful or looking for an alternate dl site for the upgrade.
Sep 25, 2009 | Microsoft ZUNE JS8BRPBDLUG MP3 Player
Integration mp3 player to 2005 x3
call a BMW dealer and talk to either your salesman or parts. ask them if they can run your VIN to see if it is prewired for a CD changer (assuming you don't see the wiring in the rear compartment). all they will need is the last 7 digits of the VIN.
BMW does sell an IPOD controller, but i think DICE makes a better one. check them out here:
http://www.x5world.com/vendor-forum/58741-eas-dice-silverline-ipod-intergration-kits-free-installer-tools-special.html
Mar 18, 2009 | 2005 BMW 3 Series
TRYING TO INSTALL MY ZUNE MP3 80GB
You need to download the software from www.zune.com before connecting your zune. Follow the setup instructions. After installation you connect your zune to the PC and the software should automatically detect it and continue the setup and update process.
Oct 03, 2008 | Microsoft Zune JS8-00001 Digital Media...
Motorola v3x
Motorola RAZR V3x Cellular Phone MP3 PLAYER IS NOT WORKING PLEASE REP ANE PLAYER
Aug 06, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Connect MP3 player to cellphone
Can you be more specific:
Are you trying to play the cellphone through the MP3 player,
or vice versa.
If your goal is simply to transfer jingles and tunes, the best
way to do this is to use a computer. The Motorola phone has
USB and Bluetooth connectivity, see:
http://en.wikipedia.org/wiki/Motorola_RAZR_V3
With the right software, you should be able to transfer
songs and jingles between your PC and the computer.
(Check Motorola for downloads)
The same is true for the MP3 Player.
The only glitch you may find is the compatibility of
the two devices' media file structures.
You may need to download two separate audio file
converters:
Cellphone <==> Windows WAV format
MP3 player <==> Windows WAV format
Finally either (or both) devices may have built-in DRM
(Digital Rights Management) copy protection,
so you may need to download some hacker/ripper
software to recover the original audio.
Google for copy protection by brand name.
Hope this sends you in the right direction.
Martin
Apr 24, 2008 | Motorola Mobility RAZR V3
The software is crazy....
You must be connected to the internet, or the update will not load
Apr 14, 2008 | Microsoft Zune JS8-00001 Digital Media...
Reinstall mp3 player Motorola SLVR L7
how to reinstal mp3 player on motorola SLVR L7, it was deleted accidentally
Feb 22, 2008 | Motorola Mobility SLVR L7 Cellular Phone
Motorola razr v3i itunes problem
As I know iTunes downloaded audio files (M4P - "protected AAC") have DRM protection which prevent users from converting it to other formats or playing iTunes media with other incompatible players such as PSP, Zune, Creative Zen, cell phone like Motorola, etc..
So, you will need a professional DRM converter to convert the DRM M4P files to Motorola compatible formats.
Free download this converter, drag and drop the protected files to it:
http://www.wmatomp3-converter.com/digital-music-converter.html#123
It can convert the DRM protected music (wma,m4p) to any other formats and extract audios from DRM video (wmv, m4v, asf, etc).
Jan 28, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Bmw bluetooth cannot get number off radio
remove battery from phone for 12 secs and reinstall battery then try
Jan 14, 2008 | Motorola Mobility RAZR V3
Garmin StreetPilot 2820 GPS Logo
183 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
