Question about Yamaha RX-V800 Receiver
YAMAHA RX-V800 Sound but NO picture after power failure
After a power flicker I have sound but NO picture .... this has happened before & my service tech simply RESET something ???? Can't figure it out
SOURCE: Rx-v800 shuts off after few seconds
Hi, You should try to see, on main board, the ground G2(TP00385), just to make sure if the screw is too tight. Its location on Schematic Diagram (Main) is E8. All the best, Rasgador
Posted on Sep 17, 2007
SOURCE: Yamaha RX-V800 Remote Control
Change the batteries
Posted on Nov 13, 2007
  • 236 Answers
SOURCE: Yamaha RX-V 800
Go to yamaha service direct they should have the parts. impossible for this model to be phased out. this is a model about 6 years ago only. they still have the parts for that. Power output and driver transistors are industry standard, replaceable too byt other newer model. you just need to find a real good techie for yamaha... i mean yamaha expert
Posted on Mar 19, 2008
drumbanger
  • 1199 Answers
SOURCE: Yamaha RX-V800 volume knob on receiver not working.
It sounds like the volume control pod has gone bad and needs replaced (The knob shaft connects to the pod main body and the inside of the volume pod is what controls the rate of volume,If the inside becomes worn ,broken or dirty the volume will become erratic) Replace volume pod ! ..You may try cleaning by taking off the volume knob and getting a can of pressure air and blowing the dust out!
Please rate response!!
Posted on Jan 06, 2009
  • 10 Answers
SOURCE: how do i reset a Yamaha RX-V465 back
sledge hammer
Posted on Apr 06, 2010
Yamaha RX-V800 shuts down when any control button is pressed
What if you DON'T use the remote? Does it shut down when just using it?
If SO, you have a bigger problem.
If NOT, it sounds like the remote is hosed - sending a code to shut off.
Do you have another remote of any brand that you could set to do something simple, like change volume? Don't train it from the original, though, or it would do the same thing.
Feb 13, 2010 | Yamaha RX-V800 Receiver
Yamaha RX-v800 av receiver will not power up. Was playing and just shut off & will not powere up again. Was in a stereo/tv cabinet with closed glass doors. Cabinet compartment has vent holes in back....
Mine did the same thing two days ago. No reason to suspect overheat as mine is in the open. Could be the power supply? Mine comes on after sitting for a while.
Nov 18, 2009 | Yamaha RX-V800 Receiver
Rx-v800, have a problem when i swtich the input mode, it will turn off. after leave it for few months, now no problem but not sound.
Test an audio source like "DVD" connected to the "Direct" input with left,center,right,rear,andsub input. put the receiver in "Direct mode" if you get audio, the main DSP chip is bad, get an estimate first since it can only be verified by bench testing the unit. It's not a cheap repair 400-500 range. Most new Yamaha receiver's in the modest range run 500-800- new. Hope this helps
Nov 08, 2009 | Yamaha RX-V800 Receiver
No picture from wii
The RX-V800 switches the various video signal types separately.
Since you are feeding S-Video to the TV the composite (yellow) input from your Wii is not going anywhere.
If you cant get S-Video output from the Wii then I'd suggest a simple Composite to S-video adaptor plug ($5 say). It worked for me with a Game Cube.
Cheers
BJ
Mar 19, 2009 | Yamaha RX-V800 Receiver
Config Problems After Repair
Sounds like they centre has configured your speakers to "none". You need to hook it up to a tV or monitor and go through the menu to "speaker settings" and make sure you select either "sml" or "lrg" for the speaker type. Also ensure on the LFE settings that you select either "swoofr" or "both."
Nov 02, 2008 | Yamaha RX-V800 Receiver
Yamaha RX-V 800
give me more details of trouble... let me give you advise if it can be done. 800 does not have industry standard parts mostly by yamaha only or made to order by yamaha. I have the same unit before, i have the manual too.
i use to work with yamaha service saudi arabia 6 years
Feb 24, 2008 | Yamaha RX-V800 Receiver
Yamaha RX-V800 Composite Video Signal Problem
Hey there fontdude, I will begin assuming you are running your a/v cable into your receiver and then out to the TV or Monitor. If this is the case, I suggest you run the video cable direct from DVD or VCR device to Tv/monitor. You can still run the audio through your receiver. The nature of your problem was probably related to video signal strength being weakened as it ran through your receiver. Good Luck! Let me know how it works for you.
Feb 09, 2008 | Yamaha RX-V800 Receiver
Yamaha RX-V800 - No audio on left and right channels
I too am experiencing this problem.... and my receiver is only 5 months old. Its a RX-V661
Oct 30, 2007 | Yamaha RX-V2500 Receiver
Problem in yamaha rx v800
Hello!!! Are you electronic technician? You should see the transistors Q22A, Q22C, Q19C e Q19A and its drivers on Main Board. All the best, Rasgador
Aug 03, 2007 | Yamaha RX-V800 Receiver
Yamaha RX-V800 Receiver Logo
73 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
