Question about HP COMPAQ Presario SR5410F Pentium dual-core E2160 1GB DDR2 320GB Intel GMA 3100 Wind... PC Desktop
USB Mouse is jumpy
I have a usb mouse and keyboard. They worked great until I had to restore windows to factory settings. Now the keyboard works fine but about 50% of the time, the mouse is jumpy. I changed batteries in both and that did not help.
  • 4 more comments
  • ntfd67 Feb 24, 2009
    I am running Vista 32bit Premium Home. I checked mouse settings in control panel. Doesn't look like anything in there would cause the the Mouse to be jumpy. It looks like my systems resources are being taxed from time to time, which is causing the jumpy mouse. It didn't do this until I wiped out my computer and started over.
    Just found PDF manual for Wireless USB keyband mouse. Looks looks like I need installation CD. Can't seem to find that. Model #62904120
    Just found the Mfr website and emailed them. Thanks.
  • ntfd67 Feb 26, 2009
    MFR is sendingme new installation CD. We'll see if that fixes it.
  • Sean Foley May 11, 2010
    What version of windows are you running?
  • jim beckwith May 11, 2010
    check the mouse setting on the control panel
    Sergeant:
    Champion:
  • 357 Answers
Try resetting the channel and see if that helps.
You could probably get the driver from the manufacturer's web site.
Good Luck.
Posted on Feb 24, 2009
  • John Sparozich Feb 26, 2009
    I hope it helps.
    Good Luck.
Using Windows 7 - My USB logitech M-BJ58 mouse keeps disconnecting/reconnecting. It works fine on my old XP system. I've tried different USB ports, but I'll be working fine then heard the USB disconnect...
I am thinking you may have to do a system restore to before you got the update. Did you update the drivers for the mouse for Windows 7? Sometimes the older OS drivers get buggy on Win 7. You can get the drivers for free from Logitech's website. One other thing to check, make sure the USB connector is not worn, sloppy or has a broken wire under the rubber cover. It can happen. You should be able to remove the last Win update then you will know if that is the culprit. Hope that helps.
Aug 06, 2013 | Logitech M-Bj58 OPTICAL WHEEL MOUSE...
USB Mouse works, keyboard does not
You will need to update the drivers on the computer for the docking station. It will be the windows seven drivers or lack of them that is causing a failure to remap the usb ports that the wireless dongle is plugged into.
May 25, 2017 | IOGear GCS632U 2-port KVM Switch
I replaced my hard drive in my hp pavilion desktop a1520n windows loads and then reads that i will have to register my copy of windows But my keyboard and usb ports dont have power so i cant do a...
A lot depends on where the keyboard and mouse are plugged in. I have seen in the past that the USB in the back works better than the front. Are these the original keyboard and mouse? If not, use the original until after Windows loads the desktop.
Mar 21, 2010 | HP P2360AA Keyboard/Mouse
My (2005) wireless ce0560 mouse is jumpy and slow to work, my wireless keyboard is great. both run on a desktop usb send/receive unit. what mouse puchased today would work on same usb receiver as keyboard.
Does the mouse act the same whether or not you:
  • replace or recharge its batteries
  • clean the optics
  • use a mousing surface with good optical diversity, e.g. magazine cover or laminated pencil board as opposed to a mirror or mica sheet?
Mar 14, 2010 | Computers & Internet
Slow Keyboard and mouse, DPC's problems
switch everything over to usb...mouse and keyboard... or by a ps2 to usb adapter and test it out... one usb to ps2 adapter can handle both keyboard and mouse... if that doesn't work its either a virus or memory...
Dec 22, 2009 | Acer Aspire 3050-1733 Notebook
Mouse works fine but cant get keyboard to sync
Might be a defective keyboard. Check and make sure its compatible for windows vista but all keyboards should work with any system.. As well maybe the port on the computer is bad..
Jul 26, 2009 | Sakar 62150 Keyboard
I have keyboard and mouse does not work and usb port too
Does the keyboard respond upon system boot. It should.
Press F8 repeatedly until you come to a black screen with text and select command line with safe mode or command line depending on the type of operating system you have.
If it is Windows XP, type in the command prompt: c:\windows\system32\restore\rstrui.exe and restore windows to a time when it was working properly.
If it is Windows Vista, type c:\windows\system32\rstrui.exe.
Jul 25, 2009 | Computers & Internet
Same prolem with a m8s dell dimension 3100
Every Device connected would lit up while you start the computer,power on self test.Set the BIOS to Default.
Jul 06, 2009 | Dell Dimension 3100 PC Desktop
Ir-700 mouse
Reinstall your CD software program for your mouse because it was wiped out when you went back to factory settings.
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Nov 25, 2007 | i-rocks IR-7100 Mouse
HP COMPAQ Presario SR5410F Pentium dual-core E2160 1GB DDR2 320GB Intel GMA 3100 Wind... PC Desktop Logo
160 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
