Question about Panasonic Lumix DMC-TZ1 Digital Camera
DMC Tz3 will not power up. Battery is fully charged. sometimes when it does come on it will not read card and will have to reset date and time.
    Novelist:
  • 172 Answers
First remove the SD card in case it is defective itself causing the camera to act funny. Next, your symptoms are indicative of a bad, not fully charged, or intermittent battery contact with camera's contacts.
Clean batt contacts using a clean pencil erasure.
If this doesn't work, measure a fully charged battery's voltage on the battery pos(+) and neg(-) terminals. It should be 4VDC. If less than 3.8, I would be suspicious it is not taking a full charge.
New batteries on ebay are cheap, and would not be a loss since you can always use backup batteries if you get another TZ camera. Or, you could just sell your camera to a repairman in an ebay auction, keeping your batteries and accessories, and buying a used working one with accessories cheap.
Posted on Feb 27, 2009
Panasonic DMC-TZ3: one day it's working fine, next it won't power on. Tried the "Power Saver" reset technique posted ... didn't work. Battery is fully-charged.
Hello
Try removing the battery and the memory card for 1 minute then return them back. Make sure the battery is inserted properly. If that didn't work, try turning it on without the memory card.
Did you get any error message when you try to turn on your camera?
Sep 02, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
Cannot turn on anymore my Panasonic TZ3
If the battery is fully charged then there is nothing to do but take/ send it in for service. Contact Panasonic or your retailer to find out where the closest Authorized service agent is.
Sep 15, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
My DMC-TZ3 battery charger green light is flashing, why ?.
I have the same problem. When I try to charge a battery the green LED onthe charger flashes green and the battery does not charge. Any ideas?
Jul 08, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
After charging tz3 battery and put in camera it
Are you using the batteries recommended by the manufacturer? that is a very important fact, even though you can find other batteries that have the same specs, they make the cameras to where it will work best, and sometimes only, with the batteries recommended.
May 20, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Camera wont turn on
First thing is to be sure battery and its connection to camera terminals is good. Be sure the battery charges normally when plugged into its charger. Charger light should be green when charging, then go out when done.
Next is to clean the battery contacts with a clean pencil erasure to remove any potential contamination built up. Now, try to measure the battery charge across its pos (+) and neg (-) terminals. This means either finding someone who can do this for you if you don't have a Volt Meter, or buying one at RadioShack or any Auto Parts store. The simple ones are cheap and this is all you need. A fully charged battery should measure about 4V DC.
If the charger and battery are good, then with the battery out of the camera, cycle the camera power switch on/off several times to try to clean its contacts. Now install the battery and move the power switch to on and hold for a good 5 seconds. Repeat this a few times.
If no response, then camera is defective. Sell it on ebay auction to a repairman who will buy it to fix and resale. Now buy youself a used, refurb w/warranty, or new on on ebay. Prices are very good because many are for sale(this is a very popular camera and millions were sold) and the TZ3 has been replaced with the newer TZ5.
It is easy to post your camera on ebay. Just search for a TZ3 for sale and on its Ad Page, you will find a link that says "Sell one like this". This will set you up with a TZ3 Ad Template w/default picture and Specs, and you just follow the prompts for your Headline/price/shipping/ etc.
Feb 27, 2009 | Panasonic Lumix DMC-TZ3 Digital Camera
Lumix
my lumix dmc-lc1 just doesn't want to function suddenlu. no power when you switch it on even if the batteries are fully charge.
Aug 18, 2008 | Panasonic Lumix DMC-FZ18K Digital Camera
Cannot turn date stamp off and date keeps resetting
Try removing battery from camera then wait 10 seconds before installing. This action resets camera.
If no work, locate your camera software version. Procedure should be in manual, else could probably find it in a google search. Then locate latest version with a google search, or panasonic camera website, or call to customer service and ask.
It you do not have latest version, ask customer service how to download it.
Jan 20, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic Lumix DMC TZ3
Use your USB cable or a Card Reader. Read your manual to insert Date on pictures. Note date will show on pic and cannot be removed.
Best idea is to downloand you pics asap and change each pic file name to embed date taken in filename, not on the pic itself.
I recomment the San Disk MobileMate SD+ miniature Card Reader for SD and MicroSD card reading. Just a little larger than a Flash Thumb Drive. Saves lugging around a USB camera cable and saves your camera power otherwise needed to power a download via a USB cable. About $15 at RadioShack, Staples, etc retail stores selling cameras.
Jan 07, 2008 | Panasonic Lumix DMC-TZ3 Digital Camera
Error Message
Read previous post with similar problem, Try removing battery and reinserting after about a minutes waiting time. Resets camera.
Dec 24, 2007 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic Lumix DMC-TZ1 Digital Camera Logo
251 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
