Question about Whirlpool LEQ9858P Electric Dryer
I ran the dryer last week. Today, i find moisture
I ran the dryer last week. Today, i find moisture in the dryer. There is no lint in the dryer.
  • 547 Answers
If your dryer vent is bent or to long this will happen
Posted on Feb 24, 2009
The lint trap on my GE dryer is moist.
Check the venting, if it is blocked or if the venting is bend it will not allow the moisture to leave the dryer and it will end up in the lint trap and on the door
Jul 26, 2012 | Maytag Neptune MDG5500AW Gas Dryer
Clothes smell after drying
I don't think the problem lies with the dryer, I would suspect the washer has mold, this is especially true on front load washer, they make products designed just for this problem, check with a large retailer, not sure who makes the mold and mildew remover, I think Home Depot or Lowes may have the product or know about it..
Jan 29, 2012 | GE Profile DPXH46EA Electric Dryer
Puddle of water in the dryer
The water comes from condensation inside the dryer ducting and drum. Heavy condensation can occur when the dryer exhaust ducting becomes clogged.
As your dryer runs, it exhausts warm moist air from your clothing. If lint becomes trapped inside the ducting, or if the ducting is kinked, this moisture has no where to go, but condensate inside the walls of the ducting and/or drum. If lint becomes accumulated it can act as a sponge and absorb this moisture.
The following link explains some common causes and potential problems you may encounter:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Read through the link provided and let me know if you have additional questions. I hope this can help you.
Jun 11, 2010 | Maytag PYE2300AY Electric Dryer
The dryer stayes full of moisture and is not drying the clothes. It gets hot but not dry? Help! I just bought this dryer last night. thanks Michaele
Clean the lint filter and the exhaust line is full of lint too. Unhook it from the back and pull the lint out.
Nov 05, 2009 | LG DLG2525S Electric Dryer
Not drying - indicator show AF
you might need to replace the heating element
Sep 05, 2009 | Dryers
Whirlpool wed8300sw0 runs thru the cycle and will then add time(Clothers are dry) to it but not all the time. moisture senor is working. in the motor and heat test i dont get any of the codes shown on hte...
I ran into this last week. Customer said that when on auto dry. Unit would run for a long time. When he checked the unit, the display showed 1:40 left but he opened and checked. Clothes were bone dry. His last power bill was $400.00 when normal was $210.00. I called factory and ran the internal codes. The first thing that came up was F1. Meaning bad main board. I'm waiting on part so I can install on customers unit.
Please rate solution.
Aug 27, 2009 | Whirlpool WED8300S Dryer
Water in the air vent
In a unrestricted rigid metal vent no water will accumulate. A dryer is exhausting hot and humid air to the outdoors. If the vent becomes restricted with a lint buildup, that lint can become wet. The more restricted the airflow is, the less airflow is available to remove the moisture. if there are low spots, or a flexible vent is used, pockets of moisture can accumulate......especially on a longer vent run.
Apr 28, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Hotpoint NVL333EY Electric dryer blows thermal fuse
I had the same thing happen, I replaced the thermal cutoff and made sure no lint build up. It lasted a week then blew again. I then replaced it again and got to thinking why it would blow. I then took apart the exaust inside the dryer running fron the drum to the motor and right before the motor was a build up of lint ane particals that was almost like compressed sawdust which was blocking half of the line. I cleaned this out and it seemed to work much better.
Jan 04, 2008 | Hotpoint NVL333EY Electric Dryer
Kenmore gas dryer
lots of people point the finger at the dryer when they have a problem you could have bad thermal cutoffs on the back of the flame tube BUT is your washer spinning properly to remove the majorityof water from the clothes
Jan 02, 2008 | Kenmore 75944 Gas Dryer
Lint filter going off after 5 minutes then shutdown
Hello folks try this if you have not gotten this resolved. Your dryers have 2 sensor systems, the first one test the clothes for moisture, the second for the heat. The 1 sensor system drops resistance when the wet clothes are put in the dryer. the shutting down after 5 minutes and lint filter light coming on could be that the dryer isn't sensing the moisture. Now for the fun part, the entire inside of the drum and paddles is the moisture sensor. Try cleaning the inside of the drum with a cleaner to remove any detergent or fabric softner residue. This is crucial if you are using fabric softner sheets as they coat the drum. Also wash the lint filter with soap and water so the water goes straight thru instead of puddling up. Remember to also clean the condenser as this can trigger this issue as well. Hope this helps
Jan 02, 2008 | Bosch Axxis WTL 5410 Electric Dryer
Whirlpool LEQ9858P Electric Dryer Logo
85 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
